SMD X'TAL 5.0×3.2×0.9mm
5S Series
■ Features
- 5.0 x 3.2 x 0.9±0.15 mm of surface mounted quartz crystal units.
- Excellent reliability characteristics such as heat and mechanical shock.
- Pb-free and satisfy RoHs requirements.
- Reflow soldering is available.
■ Applications
Digital Electronics, Consumer Products, Mobile Communications,
Bluetooth, Wireless LAN and Automotive
■ Specifications
Frequency range
Overtone Order
Frequency tolerance at 25℃
Operating temperature range and frequency stability
Equivalent series resistance
Shunt capacitance
Load capacitance
Drive level (Max.)
Insulation resistance
Aging at 25℃
Storage temperature range
Measure instrument
8~100 MHz
Fundamental, 3rd overtone
±10, ±15, ±20, ±30, ±50 ppm
See Table 1
See Table 2
5 pF Max or specify
Series, 8, 16, 20 pF or specify
10, 100, 200 μW or specify
500MΩ Min. at DC 100V
±3 ppm / year Max
-40 ~ +85 ℃ or -40 ~ +125 ℃
S&A 250B system with PI circuit
■ Table 1: Operating temperature range and frequency stability
ppm
Temp
0~+ 50 ℃
- 10~+ 60 ℃
- 20~+ 70 ℃
- 30~+ 85 ℃
- 40~+ 85 ℃
- 40~+ 125 ℃
±5
±10
±15
±20
±50
■ Table 2: Equivalent series resistance
Frequency
Overtone
ESR
(MHz)
Order
(Ω MAX)
Fundamental
100
8~10
Fundamental
80
10~12
Fundamental
60
12~15
Fundamental
50
15~54
3rd overtone
100
40~80
3rd overtone
90
80~100
The mark “●” denotes our achieved level
■ Dimensions (unit: mm)
■ Land pattern (unit: mm)
5.00 0.15
2.6
2
#3
#3
#4
#1
#2
#2
#1
1.7
2
0.90 0.15
1
1.2
1.4
3.20 0.15
1.2
#4
Pin
#1
#2
#3
#4
Function
Xtal Terminal (Input)
GND
Xtal Terminal (Output)
GND
很抱歉,暂时无法提供与“5S27100016-Q”相匹配的价格&库存,您可以联系我们找货
