3S40000260-Q
3S40000260-Q
    YL(惠伦晶体)
    SMD3225_4P
    无源晶振 40MHz 11pF -20℃~+105℃ SMD3225_4P 16Ω -3~+11ppm
3S40000260-Q 数据手册
SMD X'TAL 3.2×2. 5×0.7mm 3S Series ■ Features - 3.2 x 2.5 x 0.7 MAX. mm of surface mounted quartz crystal units. - Excellent reliability characteristics such as heat and mechanical shock. - Pb-free and satisfy RoHs requirements. - Reflow soldering is available. ■ Applications Digital Electronics, Consumer Products, Mobile Communications, Bluetooth, Wireless LAN and Automotive ■ Specifications Frequency range Overtone Order Frequency tolerance at 25℃ Operating temperature range and frequency stability Equivalent series resistance Shunt capacitance Load capacitance Drive level (Max.) Insulation resistance Aging at 25℃ Storage temperature range Measure instrument 8~96 MHz Fundamental ±10, ±15, ±20, ±30, ±50 ppm See Table 1 See Table 2 3 pF Max or specify 8, 16, 20 pF or specify 10, 100, 200 μW or specify 500MΩ Min. at DC 100V ±3 ppm / year Max -40 ~ +85 ℃ or -40 ~ +125 ℃ S&A 250B system with PI circuit ■ Table 1: Operating temperature range and frequency stability ppm Temp 0~+ 50 ℃ - 10~+ 60 ℃ - 20~+ 70 ℃ - 30~+ 85 ℃ - 40~+ 85 ℃ - 40~+ 125 ℃ ■ Table 2: Equivalent series resistance ±5 ±10 ±15 ±20 ±50 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● Frequency (MHz) 8~10 10~12 12~16 16~24 24~32 32~54 60~100 The mark “●” denotes our achieved level. ■ Dimensions (unit: mm) Overtone Order Fundamental Fundamental Fundamental Fundamental Fundamental Fundamental Fundamental ■ Land pattern (unit: mm) #4 #3 #3 #1 #2 #2 #4 #1 Pin #1 #2 #3 #4 Function Xtal Terminal (Input) GND Xtal Terminal (Output) GND ESR (Ω MAX) 500 300 80 60 40 30 30
3S40000260-Q
1. 物料型号:SMD X'TAL 3.2×2.5×0.7mm 3S系列,型号包括YL200和YNO3。
2. 器件简介:该系列为表面贴装石英晶体单元,具有优异的可靠性特性,如耐热和抗机械冲击,无铅且符合RoHS要求,可进行回流焊接。
3. 引脚分配:文档中提供了引脚功能,包括Xtal Terminal (Input)、GND和Xtal Terminal (Output)。
4. 参数特性:包括频率范围8~96 MHz,基频模式,频率容差±10至±50ppm,工作温度范围和频率稳定性,等效串联电阻,并联电容,负载电容,驱动电平,绝缘电阻,老化率,存储温度范围等。
5. 功能详解:文档提供了详细的规格说明,包括频率稳定性表和等效串联电阻表。
6. 应用信息:适用于数字电子、消费产品、移动通信、蓝牙、无线局域网和汽车等领域。
7. 封装信息:提供了尺寸图和焊盘图案尺寸。
3S40000260-Q 价格&库存
很抱歉,暂时无法提供与“3S40000260-Q”相匹配的价格&库存,您可以联系我们找货
