TS4148 RYG
Taiwan Semiconductor
150mA, 75V Switching Diode
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
Compliance to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF(AV)
150
mA
VRRM
75
V
IFSM
2
A
VF at IF=100mA
1.00
V
TJ Max.
175
°C
APPLICATIONS
Switching mode power supply (SMPS)
Adapters
Lighting application
On-board DC/DC converter
Package
0805 (Ceramics)
Configuration
Single die
MECHANICAL DATA
● Case: 0805(Ceramics)
● Molding compound meets UL flammability classification
rating 94HB
● Terminal: Matte tin plated leads, solderable per J-STD-002
● Meet JESD 201 class 1A whisker test
● Polarity: Indicated by cathode band
● Weight: 0.006g (approximately)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Repetitive peak reverse voltage
Forward current
tp = 1s square wave
Non-repetitive peak forward surge
current
tp = 8.3ms single half sine
wave
Junction temperature range
Storage temperature range
SYMBOL
VALUE
UNIT
VRRM
IF(AV)
75
150
V
mA
0.5
IFSM
A
2.0
TJ
-55 to +175
°C
TSTG
-55 to +175
°C
SYMBOL
TYP.
UNIT
RӨJA
375
°C/W
THERMAL PERFORMANCE
PARAMETER
Junction-to-ambient thermal resistance
1
Version:N1803
TS4148 RYG
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage per diode
CONDITIONS
(1)
IF=100mA, TJ=25°C
Reverse current @ rated VR per
diode
(2)
VR=20V TJ=25°C
VR=75V TJ=25°C
IF=10mA, IR=10mA,
Reverse recovery time
RL=100Ω
1 MHz, VR=0V
Junction capacitance
Notes:
1. Pulse test with PW=0.3 ms
2. Pulse test with PW=30 ms
SYMBOL
TYP.
MAX.
UNIT
VF
1
V
25
nA
5
µA
trr
4
ns
CJ
4
pF
IR
ORDERING INFORMATION
ORDERING CODE
PACKAGE
5K / 7" Reel
TS4148 RYG
0805
TS4148 RBG
PACKING
10K / 13" Reel
2
Version:N1803
TS4148 RYG
CHARACTERISTICS CURVES
Fig. 1 Typical Forward Characteristics
Fig. 2 Reverse Current VS. Reverse Voltage
100.00
100
TA=100oC
Reverse Current (uA)
Instantaneous Forward Current (mA)
1000
10
TA=25oC
1
TA=25oC
1.00
0.10
0.01
0.0
1.0
2.0
Instantaneous Forward Voltage (V)
40
60
80
100
120
Reverse Voltage (V)
Fig. 3 Admissible Power Dissipation Curve
Fig. 4 Typical Junction Capacitance
1.2
500
Junction Capacitance (pF)
Power Dissipation (mW)
1.1
400
300
200
1.0
0.9
0.8
100
0.7
50
75
100
125
150
Ambient Temperature (oC)
2
4
6
8
10
Reverse Voltage (V)
3
Version:N1803
TS4148 RYG
Fig. 5 Forward Resistance VS.
Forward Current
Dynamic Forward Resistance (Ohm)
10000
1000
100
10
1
0.01
0.1
1
10
100
4
Version:N1803
TS4148 RYG
PACKAGE OUTLINE DIMENSION
0805
DIM.
5
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
1.80
2.20
0.071
0.087
B
1.05
1.45
0.041
0.057
C
0.25
0.65
0.010
0.026
D
0.65
0.85
0.026
0.033
Version:N1803
TS4148 RYG
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version:N1803
很抱歉,暂时无法提供与“TS4148 RYG”相匹配的价格&库存,您可以联系我们找货
