2S27100018-Q
2S27100018-Q
    YL(惠伦晶体)
    SMD2520_4P
    无源晶振 40Ω 8pF ±10ppm -40℃~+85℃ 27.12MHz SMD2520_4P
2S27100018-Q 数据手册
SMD X'TAL 2.5×2.0×0.6mm 2S Series ■ Features - 2.5 x 2.0 x 0.6 MAX. mm of surface mounted quartz crystal units. - Excellent reliability characteristics such as heat and mechanical shock. - Pb-free and satisfy RoHs requirements. - Reflow soldering is available. ■ Applications Digital Electronics, Consumer Products, Mobile Communications, Bluetooth, Wireless LAN and Automotive ■ Specifications Frequency range Overtone Order Frequency tolerance at 25℃ Operating temperature range and frequency stability Equivalent series resistance Shunt capacitance Load capacitance Drive level (Max.) Insulation resistance Aging at 25℃ Storage temperature range Measure instrument 12~ 96 MHz Fundamental ±10, ±15, ±20, ±30, ±50 ppm See Table 1 See Table 2 3 pF Max or specify 8, 16, 20 pF or specify 10, 100, 200 μW or specify 500MΩ Min. at DC 100V ±3 ppm / year Max -40 ~ +85 ℃ or -40 ~ +125 ℃ S&A 250B system with PI circuit ■ Table 1: Operating temperature range and frequency stability ppm Temp 0~+ 50 ℃ - 10~+ 60 ℃ - 20~+ 70 ℃ - 30~+ 85 ℃ - 40~+ 85 ℃ - 40~+ 125 ℃ ±5 ±10 ±15 ±20 ±50 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ■ Table 2: Equivalent series resistance Frequency Overtone ESR (MHz) Order (Ω MAX) Fundamental 100 12~16 Fundamental 80 16~20 Fundamental 60 20~30 Fundamental 50 30~54 Fundamental 30 60~100 The mark “●” denotes our achieved level ■ Dimensions (unit: mm) ■ Land pattern (unit: mm) 1 0.9 2.5 0.1 #3 #3 #1 #2 #2 1 #4 0.6 Max. #1 Pin #1 #2 #3 #4 Function Xtal Terminal (Input) GND Xtal Terminal (Output) GND 0.65 0.9 0.7 2.0 0.1 0.9 #4 0.85
2S27100018-Q
物料型号:2S系列,型号包括YL200和YNO3。
器件简介:该系列是表面安装的石英晶体单元,尺寸为2.5 x 2.0 x 0.6毫米,具有出色的热冲击和机械冲击可靠性,无铅并满足RoHS要求,适用于回流焊接。
引脚分配:文档中提供了引脚功能,包括GND(接地)、Xtal Terminal(输入)和Xtal Terminal(输出)。
参数特性:包括频率范围12~96MHz,基频模式,频率容差,工作温度范围和频率稳定性,等效串联电阻,并联电容,负载电容,驱动电平,绝缘电阻,老化率,存储温度范围等。
功能详解:文档提供了详细的规格说明,包括频率稳定性表格和等效串联电阻表格。
应用信息:适用于数字电子、消费产品、移动通信、蓝牙、无线局域网和汽车等领域。
封装信息:提供了尺寸图和尺寸单位为毫米的土地模式图。
2S27100018-Q 价格&库存
很抱歉,暂时无法提供与“2S27100018-Q”相匹配的价格&库存,您可以联系我们找货
