IN-S128DATRG
Top View SMD LED 1210 PCB Type
Features
1210 1.1mm SMD LED
High Brightness
AlInGaP / InGaN Technology
Side View
High reliability
Clear Lens
Description
The IN-S128DATRG is a popular 1210 top view
package with versatile design capabilities. It is a PCB
type molding style LED which can be used in various
applications.
Recommended Solder Pattern
Applications
Consumer Electronics
Wearables
Automobile After Market
Industrial Equipment
Figure 1. IN-S128DATRG Solder Pattern
Package Dimensions in mm
Figure 2. IN-S128DATRG Package Dimensions
Inolux Corporation
Proprietary & Confidential
May 12, 2017
Page 1
www.inolux-corp.com
IN-S128DATRG
Absolute Maximum Rating at 25oC (Note 1)
Product
Emission
Color
Pd (mW)
IF (mA)
IFP* (mA)
Red
75
25
70
IN-S128DATRG
Green
75
25
VR (V)
TOP (oC)
TST (oC)
5
-30~+85
-40~+90
100
Notes
1. Condition for IFP is pulse of 1/10 duty and 0.1msec width
ESD Precaution
ATTENTION: Electrostatic Discharge (ESD) protection
The symbol above denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even
though they are relatively safe in the presence of low static-electric discharge. Parts built with AlInGaP, GaN, or/and InGaN based
chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly.
If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process.
Please be advised that normal static precautions should be taken in the handling and assembly of this device to prevent damage or degradation
which may be induced by electrostatic discharge (ESD).
Electrical Characteristics T
Product
A
IF
Emission
Color
(mA)
= 25°C (Note 1)
VF(V)
Viewing
λ(nm)
Angle
I*V(mcd)
typ.
max
λD
λP
△λ
2θ1/2
Typ.
Red
2.6
622
630
140
Green
3.6
522
530
35
130
560
IN-S128DATRG
Notes
1. Performance guaranteed only under conditions listed in above tables.
Inolux Corporation
May 12, 2017
Page 2
www.inolux-corp.com
IN-S128DATRG
Typical Characteristic Curves – YG, Y, A, R
Inolux Corporation
May 12, 2017
Page 3
www.inolux-corp.com
IN-S128DATRG
Typical Characteristic Curves – B, G, W
Inolux Corporation
May 12, 2017
Page 4
www.inolux-corp.com
IN-S128DATRG
Typical Characteristic Curves – Radiation Pattern
Ordering Information
Product
Technology
Test Current
IF (mA)
Luminous Intensity
IV (mcd)
(Typ.)
Forward
Voltage
VF (V)
(Typ.)
Red
AllnGaP
2.2
Green
InGaN
3.2
Emission
Color
IN-S128DATRG
Inolux Corporation
Orderable
Part Number
IN-S128DATRG
May 12, 2017
Page 5
www.inolux-corp.com
IN-S128DATRG
Label Specifications
Inolux P/N:
I
N
S
1
Material
Inolux
SMD
S = PCB
Type
2
Package
8
D
A
Variation
128DA = 3.2 x 2.7 x 1.1mm
Tri-Chip
T
R
Orientation
Current
Lens
T=
Top Mount
(Blank) =
20mA
(Blank) =
Clear
G
Color
X
X
X
X
Customized
Stamp-off
R=630nm
G=530nm
Lot No.:
Z
Internal
Tracker
Inolux Corporation
2
7
Year (2017, 2018, …..)
01
24
001
Month
Date
Serial
May 12, 2017
Page 6
www.inolux-corp.com
IN-S128DATRG
Packaging Information: 3000pcs Per Reel
Tape Dimension
Unit: mm Tolerance: +/-0.10 mm
Reel Dimension
Unit: mm Tolerance: +/-0.15mm
Inolux Corporation
May 12, 2017
Page 7
www.inolux-corp.com
IN-S128DATRG
Packing Dimension
5 boxes per carton are available depending on shipment quantity.
Specification
Material
Quantity
Carrier tape
Per EIA 481-1A specs
Conductive black tape
3000pcs per reel
Reel
Conductive black
Label
IN standard
Paper
Packing bag
220x240mm
Aluminum laminated bag/ no-zipper
One reel per bag
Carton
IN standard
Paper
Non-specified
Others:
Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same
bin combinations of Iv, λD and Vf. Each reel has a label identifying its specification; the immediate box consists
of a product label as well.
Inolux Corporation
May 12, 2017
Page 8
www.inolux-corp.com
IN-S128DATRG
Dry Pack
All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times during
transportation or storage. Every reel is packaged in a moisture protected anti-static bag. Each bag is properly
sealed prior to shipment.
Upon request, a humidity indicator will be included in the moisture protected anti-static bag prior to shipment.
The packaging sequence is as follows:
Reflow Soldering
• Recommended tin glue specifications: melting temperature in the range of 178~192 OC
• The recommended reflow soldering profile is as follows (temperatures indicated are as measured on
the surface of the LED resin):
Lead-free Solder Profile
Inolux Corporation
May 12, 2017
Page 9
www.inolux-corp.com
IN-S128DATRG
Precautions
Avoid exposure to moisture at all times during transportation or storage.
Anti-Static precaution must be taken when handling GaN, InGaN, and AlInGaP products.
It is suggested to connect the unit with a current limiting resistor of the proper size. Avoid applying a
reverse voltage.
Avoid operation beyond the limits as specified by the absolute maximum ratings.
Avoid direct contact with the surface through which the LED emits light.
If possible, assemble the unit in a clean room or dust-free environment.
Reworking
Rework should be completed within 5 seconds under 260 OC.
The iron tip must not come in contact with the copper foil.
Twin-head type is preferred.
Cleaning
Following are cleaning procedures after soldering:
• An alcohol-based solvent such as isopropyl alcohol (IPA) is recommended.
• Temperature x Time should be 50oC x 30sec. or
很抱歉,暂时无法提供与“IN-S128DATRG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+2.18768
- 1000+2.08824
- 国内价格
- 1+1.51082
- 200+0.60286
- 500+0.58266
- 1000+0.57273
- 国内价格 香港价格
- 3000+1.041493000+0.13539
- 6000+0.978466000+0.12720
- 9000+0.946109000+0.12299
- 15000+0.9095315000+0.11824
- 21000+0.8877821000+0.11541
- 30000+0.8665430000+0.11265
- 国内价格
- 1+2.74775
- 10+1.83383
- 100+1.36549
- 500+1.05886
- 1000+0.92949
- 3000+0.72706
- 6000+0.67915
- 国内价格 香港价格
- 1+3.179691+0.41335
- 10+2.1884410+0.28449
- 100+1.55122100+0.20166
- 500+1.26072500+0.16389
- 1000+1.164991000+0.15145
