P6SMB220CA
P6SMB220CA
    SUNMATE(森美特)
    SMB(DO-214AA)
    TVS VC=220V VRWM=185V Ppk=600W Ipp=1.8A SMB
P6SMB220CA 数据手册
P6SMB6.8A(CA) - P6SMB440A(CA) SURFACE MOUNT TRANSIENT VOLAGE SUPPESSOR DIODE VOLTAGE RANGE: 6.8 - 440 V POWER: 600Wa t t s Features ! Glass Passivated Die Construction ! ! ! Uni- and Bi-Directional Versions Available Excellent Clamping Capability Fast Response Time Plastic Material: UL Flammability ! Classification Rating 94V-0 B SMB(DO-214AA) Mechanical Data A ! Case: SMB/DO-214AA, Molded Plastic ! Terminals: Solder Plated, Solderable per MIL-STD-750, Method 2026 ! Polarity: Cathode Band or Cathode Notch ! Marking: Type Number ! Weight: 0.093 grams (approx.) C D J H Maximum Ratings Min A 3.30 Max 3.94 B 4.06 4.70 C 1.91 2.21 D 0.15 0.31 E 5.00 5.59 G 0.10 0.20 H 0.76 1.52 J 2.00 2.62 All Dimensions in mm @ TA = 25°C unless otherwise specified Characteristic Peak Pulse Power Dissipation (Non repetitive current pulse derated above TA = 25°C) (Note 1) Peak Forward Surge Current, 8.3ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) (Notes 1, 2, & 3) Instantaneous Forward Voltage @ IPP = 35A VBR
P6SMB220CA 价格&库存
很抱歉,暂时无法提供与“P6SMB220CA”相匹配的价格&库存,您可以联系我们找货
P6SMB220CA
  • 1+0.19575
  • 10+0.18850
  • 100+0.17110
  • 500+0.16240
库存:251
