TXC CORPORATION
4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan.
TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207
www.txccorp.com
SPECIFICATION FOR APPROVAL
CUSTOMER
PRODUCT TYPE
SMD TUNING FORK 3.2X1.5
NOMINAL FREQ.
32.768KHz
TXC P/N
9H03200033
REVISION
S1
CUSTOMER P/N
PM / SALES
DATE
CUSTOMER SIGNATURE & Date
(1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by TXC after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
Attachment: Product Specification Sheet
1
2
3
4
5
Halogen Free
RoHS Compliant
FMT-DOC024
Issue Date: 12.15'08 VER.E
TXC CORPORATION
www.txccorp.com
PRODUCT SPECIFICATION SHEET
PRODUCT TYPE
NOMINAL FREQ.
32.768KHz
TXC P/N
9H03200033
REVISION
S1
RD
QA
MFG
8-Aug-12
NOTE:
(1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003
on the restriction of the use of certain hazardous substances (RoHS) in electrical and
electronic equipment" Compliant (Attachment: SGS Test Report).
(2)Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3)Revision "Ax" is production ready. PE, QA and MFG's approval required
Halogen Free
RoHS Compliant
FMT-DOC024
TXC CORPORATION
Rev
Revise page
S1
NA
FMT-DOC024
TXC P/N: 9H03200033
Revise contents
Initial release
REVISION: S1
PAGE: 1
Date
Ref.No.
Reviser
8-Aug-12
Alan Cheng
TXC P/N: 9H03200033
TXC CORPORATION
REVISION: S1
PAGE: 2
■ ELECTRICAL SPECIFICATIONS
Parameters
Sym.
1 Nominal Frequency
2 Frequency Tolerance
Electrical Spec.
Min
Typical
Max
Notes
Unit
F0
32.768
KHz
at 25 ℃ ±3℃
∆f/fo
± 20
ppm
3 Load Capacitance
CL
9.0
pF
4 Driver Level
DL
0.1
1
μW
ESR
70
KΩ
at 25 ℃ ±3℃
6 Turnover Temperature
Tp
30
7 Parabolic Curvature Constant
K
-0.04
8 Operating Temperature
-40
85
9 Storage Temperature
-55
125
10 Insulation Resistance
IR
500
MΩ
at DC 100V±15V
11 Shunt Capacitance
C0
1.0
pF
12 Motional Capacitance
C1
3.4
fF
13 Aging
∆f/f
5 Equivalent Series Resistance
■ DIMENSIONS
at 25 ℃ ±5℃
2
ppm/℃ -
ppm
±3
1st Year
■ RECOMMENDED SOLDER PAD
(UNIT:mm)
(UNIT:mm)
0.65
1.50 ± 0.10
1.50 ± 0.10
3.20 ± 0.10
1.70 ± 0.10
1.8
0.75 ± 0.10
1.0
■ SUGGESTED REFLOW PROFILE
1.5
1.0
■ TEMPERATURE V.S FREQENCY CURVE
Total time : 200 sec. Max.
-40
Solder melting point :220℃
25
85
TEMP
(oC)
10 sec
260
220
180
-130
150
△f/fo(ppm)
Time (sec)
120 sec
FMT-DOC024
60 sec
REVISION: S1
TXC P/N: 9H03200033
TXC CORPORATION
PAGE: 3
■ MARKING
TXC Use
Frequency/CL Code
Frequency /CL Code
KHz
PF
32.768
12.5
A
32.768
7.0
B
32.768
9.0
C
Date Code
CODE
XXXXX
TXC Use Code
Date Code
MONTH
JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC
YEAR
2001
2005
2009
2013
2017
A
B
C
D
E
F
G
H
J
K
L
M
2002
2006
2010
2014
2018
N
P
Q
R
S
T
U
V
W
X
Y
Z
2003
2007
2011
2015
2019
a
b
c
d
e
f
g
h
j
k
l
m
2004
2008
2012
2016
2020
n
p
q
r
s
t
u
v
w
x
y
z
This date code will be cycled every four years
■ PACKING
Ao= 1.8±0.10 mm
Bo= 3.5±0.10 mm
L
L1
Ko= 1.0±0.10 mm
W1
W
CARRIER TAPE
DIMENSIONS
REEL DIMENSIONS
REMARK :
K1 P0 P1 P2 D0 D1
4
4
2
E
F 10P0 W
1.55 1.1 1.75 5.5
W
W1
16±1.4
13±0.3
L
40
T pcs / Reel
12 0.25 3K
L1
180+0/-3 60.2±0.5
1. 230 mm (9.05) minimum leader which consist of carrier and/or tape followed by a minimum of
160 mm (6
(6.3)
3) of empty carrier tape sealed with cover tape
tape.
2. 160 mm (6.3) minimum trailer of empty carrier tape sealed with cover tape.
FMT-DOC024
TXC CORPORATION
TXC P/N:
9H03200033
REVISION:
S1
PAGE:
4
■ PACKING
Reel Quantity :
1. Reel X 5 (5 Reels x1 )
2. Reel X 10 (10 Reels x1 )
3. Reel X 20 (10 Reels x2 )
4. Reel X 40 (10 Reels x4 )
Label B
Box Size:
1. L200 X W200 X H140mm
2. L200 X W200 X H250mm
3. L400 X W200 X H250mm
4. L400 X W400 X H280mm
Tape
Tape
Label A
Label B
QA Pass
(Label A) Size:100 X 100mm
(Label B) Size:80 X 40mm
[STORAGE]
1.The storage time to be 1 year maximum.
2.Don't be caught in the rain.
3.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine.
4.If customers have special requirements, we can paste labels according to it.
FMT-DOC024
TXC CORPORATION
TXC P/N: 9H03200033
REVISION: S1
PAGE: 5
■ STRUCTURE ILLUSTRATION
1
4
6
2
5
NO
1 Lid
3
COMPONENTS
MATERIALS
FINISH/SPECIFICATIONS
Kovar(Fe+Co+Ni) Alloy
2 Base(Package)
Ceramic(AI2O3)
Alumina Ceramics
3 PAD
Au
Tungsten metalize
+ Ni plating
+ Au plating
4 Crystal chip
SiO2
5 Conductive adhesive
Ag
Silicon resin
6 Electrode
Au+Cr
■ UNIT WEIGHT:
0.01197g/pcs
FMT-DOC024
TXC P/N: 9H03200033
TXC CORPORATION
REVISION: S1
PAGE: 6
■ RELIABILITY SPECIFICATIONS
1.Mechanical Endurance
No.
Test Item
1 Drop Test
Test Methods
REF. DOC
MIL-STD-202
150 cm height, fall freely onto concrete floor 3 times.
1 Mechanical Shock
1 Vibration
Device are shocked to half sine wave ( 1000 G ) three mutually
perpendicular axes each 3 times. 0.5m sec. duration time
Frequency range
10 ~ 2000 Hz
Amplitude
1.52 mm,20G
Sweep time
20 minute
Perpendicular axes each test time
4 hours
MIL-STD-202
MIL-STD-883
(Total test time 12 hours)
1 Solderability
Temperature
245 ℃ ± 5℃
Immersing depth
0.5 mm minimum
Immersion time
5 ± 1 seconds
Flux
Rosin resin methyl
y alcohol
MIL-STD-883
solvent ( 1 : 4 )
2.Environmental Endurance
No.
Test Item
2 Resistance To Soldering Heat
Test Methods
Pre-heat temperature
125 ℃
Pre-heat time
60 ~ 120 sec.
Test temperature
260 ± 5 ℃
Test time
10 ± 1 sec.
REF. DOC
MIL-STD-202
2 High Temp. Storage
+ 125 ℃ ± 3 ℃ for 1000 ± 12 hours
MIL-STD-883
2 Low Temp. Storage
- 40 ℃ ± 3 ℃ for 1000 ± 12 hours
MIL-STD-883
Total 100 cycles of the following temperature cycle
1 cycle
2 Thermal Shock
125 ± 3 ℃
MIL-STD-883
25 ℃
-55 ± 3 ℃
10 min.
10 min.
10 min. max.
3 Pressure Cooker Storage
121 ± 3℃, RH100%, 2 bar, for 240 hours
EIA-JESD22
3 High Temp&Humidity
85℃ ± 3℃, RH 85% , 1000Hrs
EIA-JESD22
FMT-DOC024
TXC CORPORATION
TXC P/N: 9H03200033
REVISION: S1
PAGE: 7
■ SUGGESTED MANUAL SOLDER CONDITION
Temperature: 350 ± 10 ℃
Time: 3 sec.
Re-solder times: twice
■ FACTORY LOCATION
TXC (NINGBO) CORPORATION
NO.189 Huang Shan West Road, Beilun District,
Ningbo Zhejiang China
FMT-DOC024
很抱歉,暂时无法提供与“9H03200033”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.24800
- 50+1.79440
- 150+1.60000
- 500+1.32440
- 国内价格
- 5+2.29349
- 50+1.83082
- 150+1.63253
- 500+1.35141
- 国内价格
- 5+2.08113
- 50+1.66130
- 600+1.64469
- 1200+1.61180
- 3000+1.56345
