7V25080026
7V25080026
    TXC(台晶)
    SMD3225_4P
    无源晶振 60Ω -10℃~+70℃
7V25080026 数据手册
: Serial No. TXC CORPORATION Issue Date 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com SPECIFICATION CN: CUSTOMER : Brother Industries, Ltd. PRODUCT TYPE : SMD GLASS SEALING XTAL 3.2 × 2.5 NOMINAL FREQ. : 25.000000MHz TXC P/N : 7V25080026 REVISION : S2 CUSTOMER P/N : Customer Signature & Date (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. PE/RD QA MFG Shih-Yung Pao RoHS Compliant FMT-R&D039 Issue Date: 10.16'08 VER.B TXC P/N: TXC CORPORATION Rev Revise page S1 N/A S2 7 FMT-DOC015 7V25080026 REVISION: S2 PAGE: 1 Date Ref.No. Reviser Initial released 9-Apr-12 N/A Xiaoyan Jiang Adding material information of packaging for Brother 1-Apr-13 N/A Xiaoyan Jiang Revise contents Issue Date: 03.01'13 VER.A TXC CORPORATION TXC P/N: 7V25080026 REVISION: S2 PAGE: 2 Spec Sheet Contents No. Content Page 1 ELECTRICAL SPECIFICATIONS P.3 2 FACTORY LOCATION P.3 3 DIMENSIONS P.4 4 MARKING P.4 5 SUGGESTED REFLOW PROFILE& MANUAL SOLDER CONDITION P.4 6 STRUCTURE ILLUSTRATION P.5 7 EMBOSS CARRIER TAPE & REEL P.6 8 PACKING P.7 9 RELIABILITY SPECIFICATIONS FMT-DOC015 P.8~9 Issue Date: 03.01'13 VER.A TXC P/N: TXC CORPORATION 7V25080026 REVISION: S2 PAGE: 3 ■ ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±5℃ Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25±3℃ Relative humidity 40%~70% : Measure equipment Electrical characteristics measured by S&A250B or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.018±0.001 g/pcs Parameters SYM. Electrical Spec. MIN TYP MAX Notes UNITS FL 25.000000 MHz - - Fundamental - - CL 8 pF - 4 Frequency Tolerance - ±30 ppm at 25 ± 3 ℃ 5 Frequency Stability - ±30 ppm Over Operating Temp. Range (Reference 25℃) 6 Operating Temperature - 7 Aging - 1 Nominal Frequency 2 Oscillation Mode 3 Load Capacitance -10 ~ 70 ±3 - ℃ ppm 1st Year 8 Drive Level DL - 100 - uW - 9 Equivalent Resistance Rr Rr - - 60 Ω - 10 Shunt Capacitance C0 C0 - - 3 pF - 11 Insulation Resistance - 500 - - MΩ 12 Storage Temperature Range - -40 ~ 85 ℃ at DC 100V - ■ FACTORY LOCATION TXC (NINGBO) CORPORATION NO.189 Huang Shan West Road, Beilun District, Ningbo Zhejiang China FMT-DOC015 Issue Date: 03.01'13 VER.A TXC P/N: TXC CORPORATION ■ DIMENSIONS (Unit:mm) 3.2±0.1 7V25080026 S2 PAGE: 4 Connection 0.25 NC 3 3 4 2.5±0.1 4 REVISION: 1 0.8 ± 0.1 3 Suggested Layout 0.8 1.4 1.4 1.2 0.5 1.2 4 NC 0.7±0.1 2 0.8±0.05 0.9±0.05 1.2±0.1 1 2 1 2 *Coplanarity of solderable areas Camber 0.10 mm Max ■ MARKING   T□□□ TXC Logo Frequency Code Ex.: 25.000000 MHz = 250 □□□ Lot Code Date Code Line Code Date Code: MONTH YEAR JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC 2005 2009 2013 2017 A B C D E F G H J K L M 2006 2010 2014 2018 N P Q R S T U V W X Y Z 2007 2011 2015 2019 a b c d e f g h j k l m 2008 2012 2016 2020 n p q r s t u v w x y z *This date code will be cycled every four years ( ) ■ SUGGESTED REFLOW PROFILE Solder melting point :220±10 ℃, 60 sec. Min. Peak Temperature: 260 ± 5 ℃, 10 sec. Max. 10 sec 260 220 180 150 ■ SUGGESTED MANUAL SOLDER CONDITION Temperature: 350 ± 10 ℃ Time: 3 sec. Time (sec) 120 sec 60 sec Re-solder times: twice FMT-DOC015 Issue Date: 03.01'13 VER.A TXC P/N: TXC CORPORATION 7V25080026 REVISION: S2 PAGE: 5 ■ STRUCTURE ILLUSTRATION 5 4 6 1 7 2 3 NO COMPONENTS MATERIALS FINISH/SPECIFICATIONS 1 Cap Ceramic (AI2O3) - 2 Package Ceramic (AI2O3) - 3 PAD Au Tungsten metalize + Ni plating + Au plating 4 Crystal blank SiO2 - 5 Conductive adhesive Resin+Ag - 6 Electrode Ag - 7 Sealing Glass Glass(PbO) - FMT-DOC015 Issue Date: 03.01'13 VER.A TXC CORPORATION 7V25080026 TXC P/N: S2 REVISION: PAGE: 6 ■ EMBOSS CARRIER TAPE & REEL F E B H G DIMENSIONS A B Feeding D C A C D 1.65±0.10 3.40±0.10 2.70±0.10 4.00±0.10 E F G H 8.00±0.20 4.00±0.10 1.55±0.10 1.75±0.10 (UNIT:mm) REMARK : Products put in 3000pcs Trailer 160mm(Min) Empty Sealed Leader 160mm(Min) 230mm(Min) User direction of feed DIMENSIONS FMT-DOC015 L L1 178±1.00 13±0.50 W W1 11.5±0.20 8±0.10 (UNIT:mm) Issue Date: 03.01'13 VER.A TXC CORPORATION TXC P/N: 7V25080026 REVISION: S2 PAGE: 7 ■ PACKING Reel Quantity : 1. Reel X 6 (6 Reels) 2. Reel X 12 (12 Reels) 3. Reel X 25 (12 Reels + 13 Reels) 4. Reel X 50 ( 12 Reelsx2 + 13 Reelsx2 ) Label B Bubble bag(PE) Box Size: 1. L200 X W200 X H140mm 2. L200 X W200 X H250mm 3. L400 X W200 X H250mm 4. L400 X W400 X H280mm Tape Tape Label A Label B QA Pass (Label A) Size:100 X 100mm (Lable B) Size:80 X 40mm [STORAGE] 1.The storage time to be 1 year maximum. 2.Don't be caught in the rain. 3.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine. 4.If customers have special requirements, we can paste labels according to it. FMT-DOC015 Issue Date: 03.01'13 VER.A TXC CORPORATION TXC P/N: 7V25080026 REVISION: S2 PAGE: 8 ■ RELIABILITY SPECIFICATIONS 1.Mechanical Endurance Test Item No. 1 Drop Test 1 Mechanical Shock Test Methods 150 cm height,3 times on concrete floor . Device are shocked to half sine wave ( 1000 G ) three mutually perpendicular axes each 3 times. 0.5 ms duration time Vibration 1 Frequency range 10 ~ 2000 Hz Amplitude 1.52 mm/20G Sweep time 20 minutes Perpendicular axes each test time 4 Hrs Test Criteria A.C A.C A.C (Total test time 12 Hrs) Solderability 1 Temperature 245 ℃ ± 5℃ Immersing depth 0.5 mm minimum Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcohol E solvent ( 1 : 4 ) 2.Environmental Endurance Test Item No. 2 Resistance To Soldering Heat Test Methods Pre-heat temperature 125 ℃ Pre-heat time 60 ~ 120 sec. Test temperature 260 ± 5 ℃ Test time 10 ± 1 sec. Test Criteria B.C.D 2 High Temp. Storage + 125 ℃ ± 3 ℃ for 500 ± 12 Hrs B.C.D 2 Low Temp. Storage - 40 ℃ ± 3 ℃ for 500 ± 12 Hrs B.C.D Total 100 cycles of the following temperature cycle 2 Temperature cycle 3 High Temp&Humidity 85℃ ± 3℃ , RH 85% , 500 Hrs FMT-DOC015 B.C.D B.C.D Issue Date: 03.01'13 VER.A TXC CORPORATION TXC P/N: 7V25080026 REVISION: S2 PAGE: 9 RELIABILITY SPECIFICATIONS Specifications A Frequency change: Within ±5ppm or in customer's specification. B Frequency change: Within ±10ppm or in customer's specification. C Equivalent series resistance(E.S.R) change: Within ±15% or 10Ω(larger value). D After conditioning , quartz crystal units shall be subjected to standard atmospheric conditions for 2 hour, and measured. E Minimum 95% of immersed terminal shall be covered with new uniform solder. Measurement condition Electrical characteristics measured by S&A250B or equivalent. FMT-DOC015 Issue Date: 03.01'13 VER.A
7V25080026 价格&库存
很抱歉,暂时无法提供与“7V25080026”相匹配的价格&库存,您可以联系我们找货
7V25080026
    • 1+0.76866
    • 30+0.74081
    • 100+0.71296
    • 500+0.65726
    • 1000+0.62941
    • 2000+0.61270
    7V25080026
      • 5+0.83787
      • 50+0.73538
      • 150+0.69142
      • 500+0.63666
      • 3000+0.61226
      • 6000+0.59757
      库存:7908
