SMD SEAM SEALING OSCILLATOR 2.0×1.6×0.9mm
9C Series
■ Features
- Small SMD seam sealed clock crystal oscillator units.
- Designed for automatic mounting and refl ow soldering.
-Tri-State function available.
- Supply voltage range : 1.8 V ~ 3.3 V.
- High stability, low jitter, low power consumption.
■ Applications
Digital Electronics, Consumer Products, Mobile Communications,
and Automotive
■ Specifications
Output Type
Supply Voltage
Frequency range
Oscillation Mode
Frequency Stability
Operating Temperature Range
Storage Temperature Range
Voltage Vol ( Max. ) / Voh ( Min. )
Rise ( Tr ) / Fall ( Tf ) Time
Supply Current
Symmetry
Start-up Time
Phase Jitter ( 12 KHz ~ 20 MHz )
Aging ( at 25 ℃ )
■ Dimensions & Land pattern (unit: mm)
CMOS
1.8 V
2.5 V , 2.8 V , 3.3 V
1~60 MHz
Fundamental
± 25 ppm , ± 50 ppm
-10 ~ + 70 ℃ , - 40 ~ + 85 ℃
- 55 ~ + 125 ℃
0.1 VDD / 0.9 VDD
8 ns Max.
20 mA Max.
40 ~ 55 % , 40 ~ 60 %
5 ms Max.
1 ps Max.
± 3 ppm / year Max.
很抱歉,暂时无法提供与“9C27000003-Q”相匹配的价格&库存,您可以联系我们找货
