9CQ3200003-Q
9CQ3200003-Q
    YL(惠伦晶体)
    SMD2016_4P
    有源晶振 15pF 3.3V SMD2016_4P 32.768KHz -8~+12ppm
9CQ3200003-Q 数据手册
SMD SEAM SEALING OSCILLATOR 2.0×1.6×0.9mm 9C Series ■ Features - Small SMD seam sealed clock crystal oscillator units. - Designed for automatic mounting and refl ow soldering. -Tri-State function available. - Supply voltage range : 1.8 V ~ 3.3 V. - High stability, low jitter, low power consumption. ■ Applications Digital Electronics, Consumer Products, Mobile Communications, and Automotive ■ Specifications Output Type Supply Voltage Frequency range Oscillation Mode Frequency Stability Operating Temperature Range Storage Temperature Range Voltage Vol ( Max. ) / Voh ( Min. ) Rise ( Tr ) / Fall ( Tf ) Time Supply Current Symmetry Start-up Time Phase Jitter ( 12 KHz ~ 20 MHz ) Aging ( at 25 ℃ ) ■ Dimensions & Land pattern (unit: mm) CMOS 1.8 V 2.5 V , 2.8 V , 3.3 V 1~60 MHz Fundamental ± 25 ppm , ± 50 ppm -10 ~ + 70 ℃ , - 40 ~ + 85 ℃ - 55 ~ + 125 ℃ 0.1 VDD / 0.9 VDD 8 ns Max. 20 mA Max. 40 ~ 55 % , 40 ~ 60 % 5 ms Max. 1 ps Max. ± 3 ppm / year Max.
9CQ3200003-Q 价格&库存
很抱歉,暂时无法提供与“9CQ3200003-Q”相匹配的价格&库存,您可以联系我们找货
