SMD TSX 2.0×1.6×0.65mm
9Z Series
■ Features
- 2.0 x 1.6 x 0.65 MAX. mm of surface mounted quartz crystal units
with thermistor.
- Excellent reliability characteristics such as heat and mechanical shock.
- Pb-free and satisfy RoHs requirements.
- Reflow soldering is available.
■ Applications
Mobile Communications
■ Specifications
Frequency range
Overtone Order
Frequency tolerance at 25℃
Operating temperature range and frequency stability
Equivalent series resistance
Shunt capacitance
Load capacitance
Drive level
Insulation resistance (at DC 100V)
Thermistor Resistance
Thermistor B-constant
Aging at 25℃
Storage temperature range
Measure instrument
19.2/38.4/76.8 MHz
26 MHz
Fundamental
Fundamental
±10 ppm
±10 ppm
See Table 1
See Table 1
See Table 2
See Table 2
1.2 ~ 3.1 pF or specify
3 pF Max or specify
7 pF
7, 9 pF
10 ~ 100 μW
100, 150 μW MAX.
500 MΩ Min.
500 MΩ Min.
100 kΩ ± 1%
100 kΩ ± 1%
4250 kΩ ± 1%
4250 kΩ ± 1%
±0.7 ppm / year Max.
-40 ~ +105 ℃
-40 ~ +105 ℃
S&A 250B system with PI circuit
■ Table 1: Operating temperature range and frequency stability
ppm
Temp
- 30~+ 85 ℃
±5
±10
±12
±15
■ Table 2: Equivalent series resistance
Frequency
Overtone
ESR
(MHz)
Order
(Ω MAX)
19.2
Fundamental
70
26
Fundamental
60
38.4
Fundamental
50
76.8
Fundamental
30
±20
* The mark “●” denotes our achieved level
* Inflection Point (T0): 25℃,
℃ (26 MHz), 29℃ 30℃ (38.4MHz), 32℃ (19.2 MHz)
■ Dimensions (unit: mm)
■ Land pattern (unit: mm)
#4
#3
#3
#4
#1
#2
#2
#1
Pin
#1
#2
#3
#4
Function
Xtal Terminal (Input)
Thermistor Terminal + GND
Xtal Terminal (Output)
Thermistor Terminal
很抱歉,暂时无法提供与“9Z26000004-Q”相匹配的价格&库存,您可以联系我们找货
