BDCD002520102R2MS1
BDCD002520102R2MS1
    CHILISIN(奇力新)
    功率电感 1.4A ±20% 2520 2.2µH 2.50 x 2.00mm 130mΩ 1.00mm
BDCD002520102R2MS1 数据手册
Molding Power Inductors – BDCD Series BDCD Series BDCD Series provides high current in compact package size with magnetically shielded construction. This power inductor is an excellent power solution for space-limited devices. Features Applications ⚫ RoHS, Halogen Free and REACH Compliance ⚫ Monolithic, magnetically shielded ⚫ Capable for large current ⚫ ⚫ ⚫ ⚫ ⚫ Smartphones, tablets and wearable devices HDD, SSD and PC peripheral devices DSC, camcoders PND DC/DC converters Product Identification Shape and Dimensions Recommended Pattern Dimensions in mm Dimensions in mm TYPE A B C D TYPE A B C BDCD00201610 2.0±0.2 1.6±0.2 1.0Max 0.5±0.3 BDCD00201610 0.7 2.3 1.8 BDCD00201612 2.0±0.2 1.6±0.2 1.2Max 0.5±0.3 BDCD00201612 0.7 2.3 1.8 BDCD00252010 2.5±0.2 2.0±0.2 1.0Max 0.6±0.3 BDCD00252010 1.2 2.8 2.3 BDCD00252012 2.5±0.2 2.0±0.2 1.2Max 0.6±0.3 BDCD00252012 1.2 2.8 2.3 BDCD00322510 3.2±0.3 2.5±0.3 1.0Max 0.5±0.3 BDCD00322510 1.7 3.5 2.8 BDCD00322512 3.2±0.3 2.5±0.3 1.2Max 0.5±0.3 BDCD00322512 1.7 3.5 2.8 Molding Power Inductors – BDCD Series Electrical Characteristics Test RDC(mΩ) Isat(A) Irms(A) Max(Typ.) Max(Typ.) Max(Typ.) 2 40(28) 4.2(6.0) 4.0(4.5) 20 2 48(40) 4.0(5.5) 3.5(3.8) 0.47 20 2 54(44) 3.2(5.0) 3.0(3.6) BDCD00201610R56MS1 0.56 20 2 59(46) 2.8(4.6) 2.8(3.3) BDCD00201610R68MS1 0.68 20 2 72(55) 2.7(4.2) 2.4(3.0) BDCD002016101R0MS1 1.0 20 2 96(81) 2.2(3.4) 2.0(2.3) BDCD002016101R5MS1 1.5 20 2 150(122) 2.1(2.8) 1.6(2.0) BDCD002016102R2MS1 2.2 20 2 204(170) 2.0(2.4) 1.3(1.6) Inductance Tolerance (uH) (±%) BDCD00201610R24MS1 0.24 20 BDCD00201610R33MS1 0.33 BDCD00201610R47MS1 Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance: M=±20% ⚫ Operating temperature range-40℃~125℃(Including self - temperature rise) ⚫ Isat for Inductance drop 30% from its value without current ⚫ Irms for a 40℃ temperature rise from 25℃ ambient with current ⚫ Rated current:Isat or Irms, whichever is smaller ⚫ Absolute maximum voltage 20VDC ⚫ Measure Equipment: L:Agilent E4991/HP4286A+16197A (or equivalent), 2MHz 0.2V RDC:CHEN HWA502BC/HP4338B (or equivalent) Isat:Agilent E4980A+HP42841A (or equivalent) Irms:Agilent 6641 SYSTEM DC POWER SUPPLY (or equivalent) Test Instruments:E4991A Impedance / Material Analyzer Tem perature Change v.s DC Current Inductance v.s DC Current 2.5 2R2 140 2.0 120 1R5 1R0 R68 1.5 ΔT℃ L(uH) 100 2R2 1R5 1.0 R33 80 R24 R56 60 1R0 0.5 R47 40 R68 R56 R47 R33 R24 0.0 20 0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 6.5 7 7.5 8 8.5 0 0.5 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 1 1.5 2 2.5 3 3.5 4 4.5 DC Current(A) 5 5.5 6 6.5 7 Molding Power Inductors – BDCD Series Electrical Characteristics Test RDC(mΩ) Isat(A) Irms(A) Max(Typ.) Max(Typ.) Max(Typ.) 2 30(23) 5.0(6.0) 3.8(4.4) 20 2 35(27) 4.5(5.0) 3.4(3.8) 0.47 20 2 41(34) 4.0(4.5) 2.9(3.3) BDCD00201610R68ML1 0.68 20 2 53(44) 3.3(3.6) 2.5(2.9) BDCD002016101R0ML1 1.0 20 2 72(60) 2.8(3.2) 2.2(2.5) BDCD002016101R5ML1 1.5 20 2 110(92) 2.2(2.8) 1.8(2.1) BDCD002016102R2ML1 2.2 20 2 170(142) 1.8(2.1) 1.5(1.7) Inductance Tolerance (uH) (±%) BDCD00201610R24ML1 0.24 20 BDCD00201610R33ML1 0.33 BDCD00201610R47ML1 Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance: M=±20% ⚫ Operating temperature range-40℃~125℃(Including self - temperature rise) ⚫ Isat for Inductance drop 30% from its value without current ⚫ Irms for a 40℃ temperature rise from 25℃ ambient with current ⚫ Rated current:Isat or Irms, whichever is smaller ⚫ Absolute maximum voltage 20VDC ⚫ Measure Equipment: L:Agilent E4991/HP4286A+16197A (or equivalent), 2MHz 0.2V RDC:CHEN HWA502BC/HP4338B (or equivalent) Isat:Agilent E4980A+HP42841A (or equivalent) Irms:Agilent 6641 SYSTEM DC POWER SUPPLY (or equivalent) Test Instruments:E4991A Impedance / Material Analyzer Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. Molding Power Inductors – BDCD Series Electrical Characteristics Part Number Inductance (uH) Tolerance (±%) Test Frequency (MHz) RDC(mΩ) Max(Typ.) Isat(A) Max(Typ.) Irms(A) Max(Typ.) BDCD00201612R24MS1 0.24 20 2 35(25) 5.5(6.5) 4.2(4.8) BDCD00201612R47MS1 0.47 20 2 52(40) 3.8(5.1) 3.2(3.8) BDCD00201612R68MS1 0.68 20 2 70(53) 3.3(4.8) 2.6(3.2) BDCD002016121R0MS1 1.0 20 2 82(67) 3.1(3.9) 2.3(2.7) BDCD002016121R5MS1 1.5 20 2 120(95) 2.6(3.2) 2.2(2.6) BDCD002016122R2MS1 2.2 20 2 195(165) 2.0(2.6) 1.3(1.7) Note: When ordering, please specify tolerance code. Tolerance: M=±20% ⚫ Operating temperature range-40℃~125℃(Including self - temperature rise) ⚫ Isat for Inductance drop 30% from its value without current ⚫ Irms for a 40℃ temperature rise from 25℃ ambient with current ⚫ Rated current:Isat or Irms, whichever is smaller ⚫ Absolute maximum voltage 20VDC ⚫ Measure Equipment: L:Agilent E4991/HP4286A+16197A (or equivalent), 2MHz 0.2V RDC:CHEN HWA502BC/HP4338B (or equivalent) Isat:Agilent E4980A+HP42841A (or equivalent) Irms:Agilent 6641 SYSTEM DC POWER SUPPLY (or equivalent) Test Instruments:E4991A Impedance / Material Analyzer Tem perature Change v.s DC Current Inductance v.s DC Current 2.5 140 1R5 120 2.0 ΔT℃ 1.5 2R2 1R5 1.0 1R0 2R2 100 L(uH) R47 R24 R68 80 60 1R0 0.5 40 R68 R47 20 R24 0 0.0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 6.5 7 7.5 8 0 0.5 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 1 1.5 2 2.5 3 3.5 4 4.5 5 DC Current(A) 5.5 6 6.5 7 7.5 8 Molding Power Inductors – BDCD Series Molding Power Choke – BDCD Series Electrical Characteristics Inductance Tolerance (uH) (±%) BDCD00252010R24MS1 0.24 20 BDCD00252010R47MS1 0.47 BDCD00252010R68MS1 Test RDC(mΩ) Isat(A) Irms(A) Max(Typ.) Max(Typ.) Max(Typ.) 2 40(24) 7.5(9.5) 4.5(5.0) 20 2 46(36) 5.2(6.5) 3.1(3.6) 0.68 20 2 65(49) 3.8(5.0) 2.9(3.3) BDCD002520101R0MS1 1.0 20 2 78(60) 3.4(4.3) 2.5(3.0) BDCD002520101R5MS1 1.5 20 2 105(82) 3.2(4.0) 2.2(2.9) BDCD002520102R2MS1 2.2 20 2 156(130) 2.6(3.2) 1.4(1.8) Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance: M=±20% ⚫ Operating temperature range-40℃~125℃(Including self - temperature rise) ⚫ Isat for Inductance drop 30% from its value without current ⚫ Irms for a 40℃ temperature rise from 25℃ ambient with current ⚫ Rated current:Isat or Irms, whichever is smaller ⚫ Absolute maximum voltage 20VDC ⚫ Measure Equipment: L:Agilent E4991/HP4286A+16197A (or equivalent), 2MHz 0.2V RDC:CHEN HWA502BC/HP4338B (or equivalent) Isat:Agilent E4980A+HP42841A (or equivalent) Irms:Agilent 6641 SYSTEM DC POWER SUPPLY (or equivalent) Test Instruments:E4991A Impedance / Material Analyzer Tem perature Change v.s DC Current Inductance v.s DC Current 2.5 140 2R2 120 R24 1R5 1R0 2.0 ΔT℃ L(uH) 1.5 1R5 1.0 1R0 0.5 R68 100 2R2 R47 80 60 40 R68 R47 20 R24 0 0.0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 6.5 7 7.5 8 8.5 9 9.5 0 0.5 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 1 1.5 2 2.5 3 3.5 4 4.5 5 DC Current(A) 5.5 6 6.5 7 7.5 8 Molding Power Inductors – BDCD Series Electrical Characteristics Inductance Tolerance (uH) (±%) BDCD00252010R33ML1 0.33 20 BDCD00252010R47ML1 0.47 BDCD00252010R68ML1 Test RDC(mΩ) Isat(A) Irms(A) Max(Typ.) Max(Typ.) Max(Typ.) 2 31(25) 5.0(6.0) 3.8(4.4) 20 2 35(29) 4.2(4.7) 3.4(3.9) 0.68 20 2 48(40) 3.7(4.0) 3.0(3.5) BDCD002520101R0ML1 1.0 20 2 65(54) 3.2(3.6) 2.6(3.0) BDCD002520101R5ML1 1.5 20 2 94(78) 2.9(3.3) 2.1(2.4) BDCD002520102R2ML1 2.2 20 2 120(100) 2.3(2.7) 1.8(2.1) Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance: M=±20% ⚫ Operating temperature range-40℃~125℃(Including self - temperature rise) ⚫ Isat for Inductance drop 30% from its value without current ⚫ Irms for a 40℃ temperature rise from 25℃ ambient with current ⚫ Rated current:Isat or Irms, whichever is smaller ⚫ Absolute maximum voltage 20VDC ⚫ Measure Equipment: L:Agilent E4991/HP4286A+16197A (or equivalent), 2MHz 0.2V RDC:CHEN HWA502BC/HP4338B (or equivalent) Isat:Agilent E4980A+HP42841A (or equivalent) Irms:Agilent 6641 SYSTEM DC POWER SUPPLY (or equivalent) Test Instruments:E4991A Impedance / Material Analyzer Tem perature Change v.s DC Current Inductance v.s DC Current 2.5 70 R33 60 1R5 2.0 1R0 2R2 R47 2R2 1.5 ΔT℃ L(uH) 50 1R5 1.0 40 30 1R0 20 R47 0.5 R33 10 0 0.0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 6.5 7 7.5 0 0.5 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 1 1.5 2 2.5 3 3.5 DC Current(A) 4 4.5 5 5.5 6 Molding Power Inductors – BDCD Series Electrical Characteristics Inductance Tolerance (uH) (±%) BDCD00252012R33MS1 0.33 20 BDCD00252012R47MS1 0.47 BDCD00252012R68MS1 Test RDC(mΩ) Isat(A) Irms(A) Max(Typ.) Max(Typ.) Max(Typ.) 2 35(27) 6.8(8.5) 4.0(4.6) 20 2 39(29) 6.2(7.8) 3.7(4.4) 0.68 20 2 46(40) 5.5(6.5) 3.3(3.7) BDCD002520121R0MS1 1.0 20 2 59(45) 4.0(5.0) 3.0(3.5) BDCD002520121R5MS1 1.5 20 2 70(62) 3.4(4.0) 2.5(2.7) BDCD002520122R2MS1 2.2 20 2 115(102) 3.3(3.8) 2.0(2.3) Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance: M=±20% ⚫ Operating temperature range-40℃~125℃(Including self - temperature rise) ⚫ Isat for Inductance drop 30% from its value without current ⚫ Irms for a 40℃ temperature rise from 25℃ ambient with current ⚫ Rated current:Isat or Irms, whichever is smaller ⚫ Absolute maximum voltage 20VDC ⚫ Measure Equipment: L:Agilent E4991/HP4286A+16197A (or equivalent), 2MHz 0.2V RDC:CHEN HWA502BC/HP4338B (or equivalent) Isat:Agilent E4980A+HP42841A (or equivalent) Irms:Agilent 6641 SYSTEM DC POWER SUPPLY (or equivalent) Test Instruments:E4991A Impedance / Material Analyzer Tem perature Change v.s DC Current Inductance v.s DC Current 2.5 70 2R2 60 1R0 2.0 1R5 2R2 1.5 ΔT( ℃ ) L(uH) 50 1R5 1.0 R33 R68 R47 40 30 1R0 20 R68 0.5 R47 R33 10 0.0 0 0 1 2 3 4 5 6 7 8 9 0 0.5 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 1 1.5 2 2.5 3 DC Current(A) 3.5 4 4.5 5 Molding Power Inductors – BDCD Series Electrical Characteristics Inductance Tolerance (uH) (±%) BDCD00252012R47ML1 0.47 20 BDCD002520121R0ML1 1.0 BDCD002520122R2ML1 2.2 Part Number Test RDC(mΩ) Isat(A) Irms(A) Max(Typ.) Max(Typ.) Max(Typ.) 2 34(30) 5.2(6.0) 4.1(4.7) 20 2 56(45) 3.6(4.5) 3.2(3.7) 20 2 102(80) 2.5(3.0) 2.2(2.6) Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance: M=±20% ⚫ Operating temperature range-40℃~125℃(Including self - temperature rise) ⚫ Isat for Inductance drop 30% from its value without current ⚫ Irms for a 40℃ temperature rise from 25℃ ambient with current ⚫ Rated current:Isat or Irms, whichever is smaller ⚫ Absolute maximum voltage 20VDC ⚫ Measure Equipment: L:Agilent E4991/HP4286A+16197A (or equivalent), 2MHz 0.2V RDC:CHEN HWA502BC/HP4338B (or equivalent) Isat:Agilent E4980A+HP42841A (or equivalent) Irms:Agilent 6641 SYSTEM DC POWER SUPPLY (or equivalent) Test Instruments:E4991A Impedance / Material Analyzer Tem perature Change v.s DC Current Inductance v.s DC Current 70 3.0 1R0 60 2.5 2R2 R47 50 ΔT( ℃ ) L(uH) 2.0 2R2 1.5 1.0 40 30 20 1R0 0.5 10 R47 0 0.0 0 1 2 3 4 5 6 7 8 0 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 1 2 3 DC Current(A) 4 5 6 Molding Power Inductors – BDCD Series Electrical Characteristics Inductance Tolerance (uH) (±%) BDCD00322510R47MS1 0.47 20 BDCD003225101R0MS1 1.0 BDCD003225101R5MS1 BDCD003225102R2MS1 Part Number Test RDC(mΩ) Isat(A) Irms(A) Max(Typ.) Max(Typ.) Max(Typ.) 2 37(30) 5.8(6.6) 3.6(4.2) 20 2 56(49) 4.0(4.6) 3.0(3.3) 1.5 20 2 75(66) 3.4(4.0) 2.6(3.0) 2.2 20 2 108(95) 2.7(3.2) 2.2(2.5) Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance: M=±20% ⚫ Operating temperature range-40℃~125℃(Including self - temperature rise) ⚫ Isat for Inductance drop 30% from its value without current ⚫ Irms for a 40℃ temperature rise from 25℃ ambient with current ⚫ Rated current:Isat or Irms, whichever is smaller ⚫ Absolute maximum voltage 20VDC ⚫ Measure Equipment: L:Agilent E4991/HP4286A+16197A (or equivalent), 2MHz 0.2V RDC:CHEN HWA502BC/HP4338B (or equivalent) Isat:Agilent E4980A+HP42841A (or equivalent) Irms:Agilent 6641 SYSTEM DC POWER SUPPLY (or equivalent) Test Instruments:E4991A Impedance / Material Analyzer Inductance v.s DC Current Tem perature Change v.s DC Current 2.5 70 2R2 60 1R5 1R0 R47 50 1.5 2R2 ΔT( ℃ ) L(uH) 2.0 1R5 1.0 40 30 1R0 20 0.5 R47 10 0.0 0 1 2 3 4 5 DC Current(A) 6 7 8 0 0 1 2 3 4 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 5 6 Molding Power Inductors – BDCD Series Electrical Characteristics Part Number Inductance (uH) Tolerance (±%) Test Frequency (MHz) RDC(mΩ) Max(Typ.) Isat(A) Max(Typ.) Irms(A) Max(Typ.) BDCD00322512R47MS1 0.47 20 2 27(21) 8.0(9.0) 5.0(5.8) BDCD00322512R68MS1 0.68 20 2 34(26) 6.3(7.5) 4.0(4.6) BDCD003225121R0MS1 1.0 20 2 42(34) 5.8(6.3) 3.8(4.2) BDCD003225121R5MS1 1.5 20 2 68(58) 4.0(4.5) 2.8(3.2) BDCD003225122R2MS1 2.2 20 2 85(75) 3.6(4.0) 2.4(2.7) Note: When ordering, please specify tolerance code. Tolerance: M=±20% ⚫ Operating temperature range-40℃~125℃(Including self - temperature rise) ⚫ Isat for Inductance drop 30% from its value without current ⚫ Irms for a 40℃ temperature rise from 25℃ ambient with current ⚫ Rated current:Isat or Irms, whichever is smaller ⚫ Absolute maximum voltage 20VDC ⚫ Measure Equipment: L:Agilent E4991/HP4286A+16197A (or equivalent), 2MHz 0.2V RDC:CHEN HWA502BC/HP4338B (or equivalent) Isat:Agilent E4980A+HP42841A (or equivalent) Irms:Agilent 6641 SYSTEM DC POWER SUPPLY (or equivalent) Test Instruments:E4991A Impedance / Material Analyzer Tem perature Change v.s DC Current Inductance v.s DC Current 3.0 70 2R2 R68 1R5 60 2.5 R47 1R0 50 ΔT( ℃ ) L(uH) 2.0 2R2 1.5 40 30 1R5 1.0 1R0 20 R68 0.5 10 R47 0 0.0 0 1 2 3 4 5 6 7 8 9 10 11 0 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 1 2 3 4 5 DC Current(A) 6 7 8 Molding Power Inductors – BDCD Series Packaging Specifications Tape Dimensions Tape Material Reel Dimensions Dimensions in mm Tape Dimensions Reel Dimensions Quantity TYPE A B T W P F K A B C D PCS / REEL BDCD00201610 1.90 2.30 0.22 8 4 3.5 1.15 178 60 12 1.5 3000 BDCD00201612 1.90 2.30 0.22 8 4 3.5 1.15 178 60 12 1.5 3000 BDCD00252010 2.25 2.80 0.22 8 4 3.5 1.15 178 60 12 1.5 3000 BDCD00252012 2.30 2.80 0.22 8 4 3.5 1.35 178 60 12 1.5 3000 BDCD00322510 2.80 3.55 0.23 8 4 3.5 1.20 178 60 12 1.5 3000 BDCD00322512 2.80 3.50 0.23 8 4 3.5 1.34 178 60 12 1.5 3000
BDCD002520102R2MS1 价格&库存
很抱歉,暂时无法提供与“BDCD002520102R2MS1”相匹配的价格&库存,您可以联系我们找货
BDCD002520102R2MS1
  • 1+0.36420
  • 100+0.33992
  • 300+0.31564
  • 500+0.29136
  • 2000+0.27922
  • 5000+0.27194
