7S10000082-Q
7S10000082-Q
    YL(惠伦晶体)
    SMD7050_4P
    无源晶振 10MHz 16pF ±30ppm 60Ω -20℃~+70℃ SMD7050_4P
7S10000082-Q 数据手册
SMD X'TAL 7.0×5.0×1.2mm 7S Series ■ Features - 7.0 x 5.0 x 1.2 MAX. mm of surface mounted quartz crystal units. - Excellent reliability characteristics such as heat and mechanical shock. - Pb-free and satisfy RoHs requirements. - Reflow soldering is available. ■ Applications Digital Electronics, Consumer Products, Mobile Communications, and Automotive ■ Specifications Frequency range Overtone Order Frequency tolerance at 25℃ Operating temperature range and frequency stability Equivalent series resistance Shunt capacitance Load capacitance Drive level (Max.) Insulation resistance Aging at 25℃ Storage temperature range Measure instrument 6~100 MHz Fundamental, 3rd overtone ±10, ±15, ±20, ±30, ±50 ppm See Table 1 See Table 2 5 pF Max or specify Series, 8, 16, 20 pF or specify 10, 100, 200 μW or specify 500MΩ Min. at DC 100V ±3 ppm / year Max -40 ~ +85 ℃ or -40 ~ +125 ℃ S&A 250B system with PI circuit ■ Table 1: Operating temperature range and frequency stability ppm Temp 0~+ 50 ℃ - 10~+ 60 ℃ - 20~+ 70 ℃ - 30~+ 85 ℃ - 40~+ 85 ℃ - 40~+ 125 ℃ ±5 ±10 ±15 ±20 ±50 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ■ Table 2: Equivalent series resistance Frequency Overtone ESR (MHz) Order (Ω MAX) Fundamental 100 6~10 Fundamental 60 10~12 Fundamental 50 12~15 Fundamental 40 15~54 3rd overtone 90 40~100 rd 3 overtone 80 100~150 The mark “●” denotes our achieved level ■ Dimensions (unit: mm) ■ Land pattern (unit: mm) 7.0 0.2 4.6 1.4 #3 #3 #4 #1 #2 #2 #1 4.3 1.4 1.2 Max. 1.3 1.2 1.54 5.0 0.2 1.2 #4 Pin #1 #2 #3 #4 Function Xtal Terminal (Input) GND Xtal Terminal (Output) GND
7S10000082-Q
物料型号:7S系列 器件简介:7.0 x 5.0 x 1.2mm尺寸的表面贴装石英晶体单元,具有出色的热冲击和机械冲击可靠性,无铅且符合RoHS要求,可进行回流焊接。 引脚分配:#1为Xtal Terminal (Input),#2为GND,#3为Xtal Terminal (Output),#4为GND。 参数特性:频率范围6~100 MHz,基频和三次泛音,频率容差±10至±50 ppm,工作温度范围和频率稳定性见表1,等效串联电阻见表2,并联电容最大5pF或指定,负载电容系列8, 16, 20 pF或指定,最大驱动电平10, 100, 200 W或指定,绝缘电阻最小500MΩ,25°C时老化±3 ppm/年,存储温度范围-40~+85°C或-40~+125°C。 功能详解:文档提供了详细的频率稳定性和等效串联电阻的数据表。 应用信息:适用于数字电子、消费产品、移动通信和汽车。 封装信息:提供了尺寸图和焊盘图案。
7S10000082-Q 价格&库存
很抱歉,暂时无法提供与“7S10000082-Q”相匹配的价格&库存,您可以联系我们找货
