9S25000074-Q
9S25000074-Q
    YL(惠伦晶体)
    SMD2016_4P
    无源晶振 25MHz 15pF -40℃~+85℃ 110Ω SMD2016_4P ±18ppm
9S25000074-Q 数据手册
SMD X'TAL 2.0×1.6×0.5 mm 9S Series ■ Features - 2.0 x 1.6 x 0.5 MAX. mm of surface mounted quartz crystal units. - Excellent reliability characteristics such as heat and mechanical shock. - Pb-free and satisfy RoHs requirements. - Reflow soldering is available. ■ Applications Digital Electronics, Consumer Products, Mobile Communications, Bluetooth, Wireless LAN and Automotive ■ Specifications Frequency range Overtone Order Frequency tolerance at 25℃ Operating temperature range and frequency stability Equivalent series resistance Shunt capacitance Load capacitance Drive level (Max.) Insulation resistance Aging at 25℃ Storage temperature range Measure instrument 16~96 MHz Fundamental ±10, ±15, ±20, ±30, ±50 ppm See Table 1 See Table 2 3 pF Max or specify 8, 16, 20 pF or specify 10, 100, 200 μW or specify 500 MΩ Min. at DC 100V ±3 ppm / year Max. -40 ~ +85 ℃ or -40 ~ +125 ℃ S&A 250B system with PI circuit ■ Table 1: Operating temperature range and frequency stability ppm Temp 0~+ 50 ℃ - 10~+ 60 ℃ - 20~+ 70 ℃ - 30~+ 85 ℃ - 40~+ 85 ℃ - 40~+ 125 ℃ ±5 ±10 ±15 ±20 ±50 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ■ Table 2: Equivalent series resistance Frequency Overtone ESR (MHz) Order (Ω MAX) Fundamental 100 16~20 Fundamental 80 20~26 Fundamental 60 26~32 Fundamental 50 32~60 Fundamental 30 60~100 The mark “●” denotes our achieved level ■ Dimensions (unit: mm) ■ Land pattern (unit: mm) #4 #3 #3 #1 #2 #2 #4 #1 Pin #1 #2 #3 #4 Function Xtal Terminal (Input) GND Xtal Terminal (Output) GND
9S25000074-Q
1. 物料型号:9S系列,尺寸为2.0 x 1.6 x 0.5毫米的表面贴装石英晶体单元。 2. 器件简介:具有出色的可靠性特性,如耐热和抗机械冲击,无铅并满足RoHS要求,可进行回流焊接。 3. 引脚分配:#1为晶体终端(输入),#2和#4为地线,#3为晶体终端(输出)。 4. 参数特性:频率范围16~96MHz,基频模式,频率容差±10至±50ppm,工作温度范围和频率稳定性见表1,等效串联电阻见表2,并联电容最大3pF或指定,负载电容8、16、20pF或指定,驱动级别最大10、100、200mW或指定,绝缘电阻最小500MΩ,25°C时老化±3ppm/年,存储温度范围-40至+85°C或-40至+125°C。 5. 功能详解:文档提供了频率稳定性和等效串联电阻的详细表格数据。 6. 应用信息:适用于数字电子、消费产品、移动通信、蓝牙、无线局域网和汽车。 7. 封装信息:提供了土地图案和尺寸单位毫米。
9S25000074-Q 价格&库存
很抱歉,暂时无法提供与“9S25000074-Q”相匹配的价格&库存,您可以联系我们找货
