CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS
PT series
Endurance: +125°C 2,000 hours
Long Life,High Temperature Resistance
Recommended Applications: Lamps Power,LED Power,Service Equipment
RoHS Compliant and lead-free
SPECIFICATIONS
Items
Category Temperature Range
-55~+125°C
Rated Working Voltage Range
6.3~25 V dc
Nominal Capacitance Range
22~5600µF
Capacitance Tolerance
±20%(M)
DC Leakage Current
I≤0.2CV or 500μA, whichever is greater.
Where, I:Max.leakage current (µA),C:Nominal capacitance (µF),V: Rated voltage (V)
(at 20°C,120Hz)
Dissipation Factor (tanδ)
6.8
6.3
Rated Voltage(V dc )
7.5
10
0.08
tanδ (max.)
ESR(100kHz,20°C)
Value in characteristics table
Temperature Characteristic
(Impedance Ratio at 100kHz)
Z(+125°C)/Z(+20°C)≤1.25
Z(-55°C)/Z(+20°C)≤1.25
(at 20°C after 2 minutes)
16
25
(at 20°C,120Hz)
0.12
After applying rated voltage for 2,000 hours at 125°C,the capacitors shall meet the following requirements.
Endurance
Appearance
No significant damage
Capacitance Change
≤±20% of the initial value
D.F. (tanδ)
≤200% of the initial specified value
ESR
Leakage Current
≤The initial specified value
After subjecting to 90~95% RH for 2,000 hours at 60°C without voltage applied, the capacitors shall meet the requirement
as surge test.
Humidity Test
After subjecting to 1,000 cycles each consisting of charge with the surge voltage specified at normal temperature for
30 seconds through a protective resistor and discharge for 5 minutes 30 seconds, the capacitors shall meet the following
requirements.
Surge Test
Appearance
Capacitance Change
D.F. (tanδ)
≤150% of the initial specified value
ESR
Leakage Current
*Note: If any doubt arises,measure the leakage current after the following voltage treatment.
Voltage treatment: DC rated voltage is applied to the capacitors for 120 minutes at 105°C.
DIMENSIONS[mm]
Ød
ØD'
F±0.5
L'
4min.
15min.
ØD
5
5.5
6.3
8
10
Ød
0.5
0.5
0.5
0.6
0.6
F
ØD'
L'
2.0
2.5
2.5
3.5
5.0
Ø D-0.1~+0.5
L+1.0max.
L-0.5~+1
PART NUMBERING SYSTEM
S
P
T
1 C
M
2
7
1
E
O
R
A
X X X
Special code
Marking code
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
38
Conductive Polymer
Radial Type
Characteristics
PT series
STANDARD RATINGS
VDC
(SV)
Cap
(µF)
Size
ΦDxL(mm)
ESR
(mΩ,20°C,100kHz)
(max.)
Rated ripple current
(mArms/125°C,100kHz)
Leakage Current
(µA)(max.)
Part Number
220
270
5×7
5×7
5×8
6.3×5
6.3×8
5×9
5×10
5.5×9
6.3×7
6.3×8
6.3×7
6.3×8
5.5×9
6.3×9
5.5×9
8×9
6.3×9
8×9
6.3×10
8×9
8×11
8×11
8×11
10×12
10×10
8×14
10×12
10×14
10×17
10×18
5×7
5×7
5×8
6.3×5
5×9
6.3×7
6.3×8
6.3×9
6.3×9
6.3×11
8×11
5×7
5×8
5×9
6.3×7
5.5×9
6.3×8
6.3×9
6.3×10
8×9
5×7
5×7
5×9
5×9
6.3×7
5.5×9
5.5×9
6.3×8
6.3×9
6.3×10
8×9
8×11
5×7
5×7
5×7
5×7
5×7
5×7
5×7
5×8
5×9
6.3×8
6.3×8
6.3×8
8×9
6.3×8
30
30
30
37
22
30
30
30
30
22
30
30
30
30
30
30
30
22
15
18
15
15
15
15
15
15
15
15
15
15
28
28
28
35
28
28
28
28
28
17
14
28
28
28
28
28
28
17
17
17
28
28
28
28
35
28
28
28
17
17
17
17
52
52
52
52
52
30
30
30
30
22
30
30
22
30
1000
1100
1200
900
1200
1200
1200
1200
1100
1300
1200
1400
1200
1500
1400
1300
1500
1400
1500
1400
1500
1500
1600
1600
1600
1700
1700
1700
1800
1800
900
1000
1100
900
1200
1100
1300
1400
1400
1500
1500
900
1000
1000
1100
1000
1200
1200
1300
1300
900
900
1000
1000
900
1000
1000
1100
1200
1300
1300
1440
600
600
600
700
700
700
700
800
800
900
900
900
1000
1000
500
500
500
500
500
500
592
592
592
592
706
706
706
857
857
857
1033
1033
1260
1260
1260
1512
1890
1890
2268
2772
2772
4158
5000
5000
500
500
500
500
639
639
762
925
1115
1360
1360
500
500
500
658
658
784
952
1148
1148
500
500
500
585
705
705
750
840
1020
1230
1230
1800
500
500
500
500
500
500
500
500
500
500
540
660
660
780
SPT0JM221D07O00RAXXX
SPT0JM271D07O00RAXXX
SPT0JM331D08O00RAXXX
SPT0JM331E05O00RAXXX
SPT0JM331E08O00RAXXX
SPT0JM391D09O00RAXXX
SPT0JM471D10O00RAXXX
SPT0JM471B09O00RAXXX
SPT0JM471E07O00RAXXX
SPT0JM471E08O00RAXXX
SPT0JM561E07O00RAXXX
SPT0JM561E08O00RAXXX
SPT0JM561B09O00RAXXX
SPT0JM681E09O00RAXXX
SPT0JM681B09O00RAXXX
SPT0JM681F09O00RAXXX
SPT0JM821E09O00RAXXX
SPT0JM821F09O00RAXXX
SPT0JM102E10O00RAXXX
SPT0JM102F09O00RAXXX
SPT0JM102F11O00RAXXX
SPT0JM122F11O00RAXXX
SPT0JM152F11O00RAXXX
SPT0JM152G12O00RAXXX
SPT0JM182G10O00RAXXX
SPT0JM222F14O00RAXXX
SPT0JM222G12O00RAXXX
SPT0JM332G14O00RAXXX
SPT0JM472G17O00RAXXX
SPT0JM562G18O00RAXXX
SPT0CM221D07O00RAXXX
SPT0CM271D07O00RAXXX
SPT0CM331D08O00RAXXX
SPT0CM331E05O00RAXXX
SPT0CM471D09O00RAXXX
SPT0CM471E07O00RAXXX
SPT0CM561E08O00RAXXX
SPT0CM681E09O00RAXXX
SPT0CM821E09O00RAXXX
SPT0CM102E11O00RAXXX
SPT0CM102F11O00RAXXX
SPT0QM221D07O00RAXXX
SPT0QM271D08O00RAXXX
SPT0QM331D09O00RAXXX
SPT0QM471E07O00RAXXX
SPT0QM471B09O00RAXXX
SPT0QM561E08O00RAXXX
SPT0QM681E09O00RAXXX
SPT0QM821E10O00RAXXX
SPT0QM821F09O00RAXXX
SPT0AM221D07O00RAXXX
SPT0AM271D07O00RAXXX
SPT0AM331D09O00RAXXX
SPT0AM391D09O00RAXXX
SPT0AM471E07O00RAXXX
SPT0AM471B09O00RAXXX
SPT0AM501B09O00RAXXX
SPT0AM561E08O00RAXXX
SPT0AM681E09O00RAXXX
SPT0AM821E10O00RAXXX
SPT0AM821F09O00RAXXX
SPT0AM122F11O00RAXXX
SPT1AM470D07O00RAXXX
SPT1AM560D07O00RAXXX
SPT1AM680D07O00RAXXX
SPT1AM820D07O00RAXXX
SPT1AM101D07O00RAXXX
SPT1AM121D07O00RAXXX
SPT1AM151D07O00RAXXX
SPT1AM181D08O00RAXXX
SPT1AM221D09O00RAXXX
SPT1AM221E08O00RAXXX
SPT1AM271E08O00RAXXX
SPT1AM331E08O00RAXXX
SPT1AM331F09O00RAXXX
SPT1AM391E08O00RAXXX
330
390
470
560
680
820
6.3
(7.2)
1000
1200
1500
1800
2200
3300
4700
5600
220
270
330
6.8
(7.8)
470
560
680
820
1000
220
270
330
7
(8.1)
470
560
680
820
220
270
330
390
470
7.5
(8.6)
500
560
680
820
10
(11.5)
1200
47
56
68
82
100
120
150
180
220
270
330
390
39
PT series
VDC
(SV)
Cap
(µF)
470
560
10
(11.5)
680
820
1000
1200
1500
1800
2200
3300
330
470
12
(13.8)
560
680
820
1000
1200
1500
47
56
68
82
100
120
150
180
220
270
16
(18.4)
330
470
560
680
820
1000
25
(28.8)
1500
1800
2200
82
120
150
220
270
470
560
680
820
1000
22
33
39
47
56
Size
ΦDxL(mm)
5.5×9
6.3×8
8×9
8×11
6.3×10
8×9
8×11
8×11
8×11
10×12
8×12
10×12
10×12
10×13
10×15
10×18
5.5×9
5.5×9
6.3×9
6.3×10
6.3×11
8×11
8×12
8×14
8×16
5×7
5×7
5×7
5×8
5×7
6.3×5
6.3×8
5×8
5×8
5×8
6.3×7
5×10
6.3×8
6.3×10
5.5×9
6.3×8
8×9
5.5×9
6.3×9
6.3×10
6.3×11
8×11
8×9
8×11
8×13
10×12
8×11
10×12
8×13
10×12
10×12
8×14
10×18
10×14
10×18
6.3×8
6.3×8
6.3×10
8×11
8×11
10×12
8×11
10×12
10×15
10×18
10×18
5×9
5×9
5×8
5×9
5×9
ESR
(mΩ,20°C,100kHz)
(max.)
30
30
22
18
19
22
18
18
18
15
15
15
15
15
15
15
28
28
28
21
21
17
17
17
17
30
30
30
30
30
37
30
30
30
30
24
30
30
22
30
30
30
30
30
30
22
22
19
22
22
18
22
18
16
18
18
18
18
18
18
42
42
28
28
28
28
28
28
28
28
28
90
90
90
90
90
Leakage Current
(µA)(max.)
Part Number
1000
1000
1000
1600
1000
1000
1100
1200
1200
1500
1300
1600
1600
1700
1800
1800
900
900
1000
1000
1100
1100
1200
1300
1400
600
600
600
600
600
600
800
700
700
700
700
700
800
800
800
800
800
800
800
900
900
1300
1200
900
900
1000
1000
1000
1000
1100
1200
1200
1600
1600
1700
1290
700
700
700
800
800
700
900
900
1000
1100
500
500
500
500
600
940
940
940
940
1120
1120
1360
1640
2000
2000
2400
2400
3000
3600
4400
5000
792
1128
1128
1344
1632
1968
2400
2880
3600
500
500
500
500
500
500
500
500
500
576
576
704
704
704
864
864
864
1056
1056
1056
1504
1504
1504
1792
1792
1792
2176
2176
2624
2624
3200
3200
4800
5000
5000
500
500
600
880
1080
1880
1880
2240
2720
3280
4000
500
500
500
500
500
SPT1AM471B09O00RAXXX
SPT1AM471E08O00RAXXX
SPT1AM471F09O00RAXXX
SPT1AM471F11O00RAXXX
SPT1AM561E10O00RAXXX
SPT1AM561F09O00RAXXX
SPT1AM681F11O00RAXXX
SPT1AM821F11O00RAXXX
SPT1AM102F11O00RAXXX
SPT1AM102G12O00RAXXX
SPT1AM122F12O00RAXXX
SPT1AM122G12O00RAXXX
SPT1AM152G12O00RAXXX
SPT1AM182G13O00RAXXX
SPT1AM222G15O00RAXXX
SPT1AM332G18O00RAXXX
SPT1TM331B09O00RAXXX
SPT1TM471B09O00RAXXX
SPT1TM471E09O00RAXXX
SPT1TM561E10O00RAXXX
SPT1TM681E11O00RAXXX
SPT1TM821F11O00RAXXX
SPT1TM102F12O00RAXXX
SPT1TM122F14O00RAXXX
SPT1TM152F16O00RAXXX
SPT1CM470D07O00RAXXX
SPT1CM560D07O00RAXXX
SPT1CM680D07O00RAXXX
SPT1CM820D08O00RAXXX
SPT1CM101D07O00RAXXX
SPT1CM101E05O00RAXXX
SPT1CM101E08O00RAXXX
SPT1CM121D08O00RAXXX
SPT1CM151D08O00RAXXX
SPT1CM181D08O00RAXXX
SPT1CM181E07O00RAXXX
SPT1CM221D10O00RAXXX
SPT1CM221E08O00RAXXX
SPT1CM221E10O00RAXXX
SPT1CM271B09O00RAXXX
SPT1CM271E08O00RAXXX
SPT1CM271F09O00RAXXX
SPT1CM331B09O00RAXXX
SPT1CM331E09O00RAXXX
SPT1CM331E10O00RAXXX
SPT1CM471E11O00RAXXX
SPT1CM471F11O00RAXXX
SPT1CM471F09O00RAXXX
SPT1CM561F11O00RAXXX
SPT1CM561F13O00RAXXX
SPT1CM561G12O00RAXXX
SPT1CM681F11O00RAXXX
SPT1CM681G12O00RAXXX
SPT1CM821F13O00RAXXX
SPT1CM821G12O00RAXXX
SPT1CM102G12O00RAXXX
SPT1CM102F14O00RAXXX
SPT1CM152G18O00RAXXX
SPT1CM182G14O00RAXXX
SPT1CM222G18O00RAXXX
SPT1DM820E08O00RAXXX
SPT1DM121E08O00RAXXX
SPT1DM151E10O00RAXXX
SPT1DM221F11O00RAXXX
SPT1DM271F11O00RAXXX
SPT1DM471G12O00RAXXX
SPT1DM471F11O00RAXXX
SPT1DM561G12O00RAXXX
SPT1DM681G15O00RAXXX
SPT1DM821G18O00RAXXX
SPT1DM102G18O00RAXXX
SPT1EM220D09O00RAXXX
SPT1EM330D09O00RAXXX
SPT1EM390D08O00RAXXX
SPT1EM470D09O00RAXXX
SPT1EM560D09O00RAXXX
40
Conductive Polymer
Radial Type
STANDARD RATINGS
PT series
STANDARD RATINGS
VDC
(SV)
Cap
(µF)
Size
ΦDxL(mm)
ESR
(mΩ,20°C,100kHz)
(max.)
Leakage Current
(µA)(max.)
68
82
6.3×7
6.3×7
6.3×8
6.3×10
8×11
6.3×8
6.3×10
6.3×10
8×9
8×11
10×12
8×11
8×11
10×12
10×10
10×12
8×16
10×12
10×15
10×12
10×18
10×18
45
45
45
30
30
45
30
30
45
30
30
30
30
30
37
30
30
30
30
30
30
30
600
600
700
800
900
700
800
800
700
900
1000
900
900
1100
800
1200
1000
1200
1200
1200
1200
1300
500
500
500
500
500
600
750
900
1100
1100
1350
1650
1650
1650
2350
2350
2350
2800
3400
3400
4100
5000
100
25
(28.8)
120
150
180
220
270
330
470
560
680
820
1000
Part Number
SPT1EM680E07O00RAXXX
SPT1EM820E07O00RAXXX
SPT1EM101E08O00RAXXX
SPT1EM101E10O00RAXXX
SPT1EM101F11O00RAXXX
SPT1EM121E08O00RAXXX
SPT1EM151E10O00RAXXX
SPT1EM181F10O00RAXXX
SPT1EM181F09O00RAXXX
SPT1EM221F11O00RAXXX
SPT1EM221G12O00RAXXX
SPT1EM271F11O00RAXXX
SPT1EM331F11O00RAXXX
SPT1EM331G12O00RAXXX
SPT1EM331G10O00RAXXX
SPT1EM471G12O00RAXXX
SPT1EM471F16O00RAXXX
SPT1EM561G12O00RAXXX
SPT1EM681G15O00RAXXX
SPT1EM681G12O00RAXXX
SPT1EM821G18O00RAXXX
SPT1EM102G18O00RAXXX
※ Specifications subject to change without notice.
41
很抱歉,暂时无法提供与“SPT1CM331E09O00R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.91250
- 50+0.71060
- 150+0.61290
- 1000+0.53960
- 2000+0.48110
- 国内价格
- 5+0.72031
- 20+0.65522
- 100+0.59013
- 500+0.52504
- 1000+0.49467
- 2000+0.47297
