SPV1HM101F11O00RAXXX 数据手册
CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS
PV series
Endurance: +125°C 2,000 hours
High voltage
Recommended Applications: System Board,Display Card,Small Charger,and intelligent TV
RoHS Compliant and lead-free
SPECIFICATIONS
Items
Category Temperature Range
-55~+125°C
Rated Working Voltage Range
35~100 V dc
Nominal Capacitance Range
4.7~1000µF
Capacitance Tolerance
±20%(M)
DC Leakage Current
I≤0.2CV or 500μA, whichever is greater.
Where, I:Max.leakage current (µA),C:Nominal capacitance (µF),V: Rated voltage (V)
(at 20°C,120Hz)
Dissipation Factor (tanδ)
50
35
Rated Voltage(V dc )
tanδ (max.)
63
80
0.12
ESR(100kHz,20°C)
Value in characteristics table
Temperature Characteristic
(Impedance Ratio at 100kHz)
Z(+125°C)/Z(+20°C)≤1.25
Z(-55°C)/Z(+20°C)≤1.25
(at 20°C after 2 minutes)
100
0.15
(at 20°C,120Hz)
After applying rated voltage for 2,000 hours at 125°C,the capacitors shall meet the following requirements.
Endurance
Appearance
No significant damage
Capacitance Change
≤±20% of the initial value
D.F. (tanδ)
≤150% of the initial specified value
ESR
Leakage Current
≤The initial specified value
After subjecting to 90%~95% RH for 2,000 hours at 60°C without voltage applied, the capacitors shall meet the specified
values for the Endurance characteristics listed above.
Humidity Test
After subjecting to 1,000 cycles each consisting of charge with the surge voltage specified at normal temperature for 30
seconds through a protective resistor and discharge for 5 minutes 30 seconds, the capacitors shall meet the following
requirements.
Surge Test
Appearance
Capacitance Change
D.F. (tanδ)
ESR
Leakage Current
DIMENSIONS[mm]
Ød
ØD'
F±0.5
L'
4min.
15min.
ØD
5
5.5
6.3
8
10
Ød
0.5
0.5
0.5
0.6
0.6
F
ØD'
L'
2.0
2.5
2.5
3.5
5.0
Ø D-0.1~+0.5
L+1.0max.
L-0.5~+1
PART NUMBERING SYSTEM
S
P
V
1 C
M
4
7
1
F
1
1
O
R
A
X X X
Special code
Marking code
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
32
Conductive Polymer
Radial Type
Characteristics
PV series
STANDARD RATINGS
VDC
(SV)
Cap
(µF)
Size
ΦDxL(mm)
ESR
(mΩ,20°C,100kHz)
(max.)
Rated ripple current
(mArms/125°C,100kHz)
Leakage Current
(µA)(max.)
Part Number
4.7
10
15
22
33
39
47
56
68
82
5×8
5×8
5×8
5×9
5×9
5×9
6.3×7
6.3×7
6.3×7
6.3×7
6.3×8
6.3×10
8×11
6.3×10
6.3×10
8×11
10×12
10×12
10×12
10×13
10×14
10×16
10×18
10×18
5×8
6.3×7
5×8
5×8
6.3×7
6.3×7
6.3×8
6.3×8
6.3×10
8×11
8×9
10×12
10×12
10×13
10×15
10×18
10×18
6.3×8
6.3×8
6.3×5
6.3×8
6.3×8
8×11
8×11
10×12
10×12
10×13
10×15
10×17
10×18
6.3×8
6.3×8
6.3×10
8×11
10×12
10×12
10×14
6.3×8
6.3×8
6.3×10
8×11
8×11
10×12
10×14
10×16
90
90
90
150
75
75
75
75
75
75
75
60
60
60
60
60
45
45
45
30
30
30
30
30
90
52
105
105
60
60
52
52
45
45
60
45
45
30
30
30
30
90
90
90
45
45
45
45
45
45
30
30
30
30
90
90
90
52
52
52
52
180
180
75
75
75
52
52
52
500
500
500
500
600
600
600
600
600
600
700
700
700
700
700
800
800
900
900
900
900
1000
1000
1100
400
500
500
400
500
600
600
600
600
600
600
700
800
800
800
900
900
400
400
400
500
500
600
600
600
700
700
700
800
800
400
400
400
500
500
500
600
400
400
400
400
400
400
400
400
500
500
500
500
500
500
500
500
500
574
700
700
700
840
1050
1540
1540
1890
2310
3290
3920
4760
5000
5000
500
500
500
500
500
500
500
560
680
1000
1000
1500
2200
2700
3300
4400
4700
500
500
500
500
500
857
1033
1260
1890
2268
2772
3402
4158
500
500
500
528
752
1088
1600
500
500
500
500
500
500
660
940
SPV1VM4R7D08O00RAXXX
SPV1VM100D08O00RAXXX
SPV1VM150D08O00RAXXX
SPV1VM220D09O00RAXXX
SPV1VM330D09O00RAXXX
SPV1VM390D09O00RAXXX
SPV1VM470E07O00RAXXX
SPV1VM560E07O00RAXXX
SPV1VM680E07O00RAXXX
SPV1VM820E07O00RAXXX
SPV1VM101E08O00RAXXX
SPV1VM101E10O00RAXXX
SPV1VM101F11O00RAXXX
SPV1VM121E10O00RAXXX
SPV1VM151E10O00RAXXX
SPV1VM221F11O00RAXXX
SPV1VM221G12O00RAXXX
SPV1VM271G12O00RAXXX
SPV1VM331G12O00RAXXX
SPV1VM471G13O00RAXXX
SPV1VM561G14O00RAXXX
SPV1VM681G16O00RAXXX
SPV1VM821G18O00RAXXX
SPV1VM102G18O00RAXXX
SPV1HM4R7D08O00RAXXX
SPV1HM100E07O00RAXXX
SPV1HM100D08O00RAXXX
SPV1HM150D08O00RAXXX
SPV1HM220E07O00RAXXX
SPV1HM330E07O00RAXXX
SPV1HM470E08O00RAXXX
SPV1HM560E08O00RAXXX
SPV1HM680E10O00RAXXX
SPV1HM101F09O00RAXXX
SPV1HM151G12O00RAXXX
SPV1HM221G12O00RAXXX
SPV1HM271G13O00RAXXX
SPV1HM331G15O00RAXXX
SPV1HM441G18O00RAXXX
SPV1HM471G18O00RAXXX
SPV1JM4R7E08O00RAXXX
SPV1JM6R8E08O00RAXXX
SPV1JM100E05O00RAXXX
SPV1JM330E08O00RAXXX
SPV1JM390E08O00RAXXX
SPV1JM680F11O00RAXXX
SPV1JM820F11O00RAXXX
SPV1JM101G12O00RAXXX
SPV1JM151G12O00RAXXX
SPV1JM181G13O00RAXXX
SPV1JM221G15O00RAXXX
SPV1JM271G17O00RAXXX
SPV1JM331G18O00RAXXX
SPV1BM4R7E08O00RAXXX
SPV1BM6R8E08O00RAXXX
SPV1BM220E10O00RAXXX
SPV1BM330F11O00RAXXX
SPV1BM470G12O00RAXXX
SPV1BM680G12O00RAXXX
SPV1BM101G14O00RAXXX
SPV1KM4R7E08O00RAXXX
SPV1KM6R8E08O00RAXXX
SPV1KM100E10O00RAXXX
SPV1KM100F11O00RAXXX
SPV1KM150F11O00RAXXX
SPV1KM220G12O00RAXXX
SPV1KM330G14O00RAXXX
SPV1KM470G16O00RAXXX
100
35
(40.3)
120
150
220
270
330
470
560
680
820
1000
4.7
10
50
(57.5)
15
22
33
47
56
68
100
63
(72.5)
80
(92.0)
100
(115.0)
150
220
270
330
440
470
4.7
6.8
10
33
39
68
82
100
150
180
220
270
330
4.7
6.8
22
33
47
68
100
4.7
6.8
10
15
22
33
47
※ Specifications subject to change without notice.
33
SPV1HM101F11O00RAXXX 价格&库存
很抱歉,暂时无法提供与“SPV1HM101F11O00RAXXX”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.14240
- 20+1.04040
- 100+0.93840
- 500+0.83640
- 1000+0.78880
- 2000+0.75480
- 国内价格
- 5+1.30644
- 50+1.04556
- 100+1.02988
- 200+0.93384
- 500+0.72040
- 国内价格
- 5+1.43975
- 50+1.15226
- 150+1.02914
- 500+0.79391
- 2500+0.72544
- 5000+0.68440
- 国内价格
- 5+1.43150
- 50+1.14110
- 150+1.01890
- 500+0.78610
- 2500+0.71820
- 5000+0.67760
