TMPC0412HP-4R7MG-Z02
    TAI-TECH(台庆)
    功率电感 ±20% 1.7A 0412 4.7µH 4.45 x 4.06mm 1.20mm 145mΩ
TMPC0412HP-4R7MG-Z02 数据手册
TAI-TECH P1 SMD Power Inductor TMPC0412HP-Serise(G)-Z02 ECN HISTORY LIST REV DATE DESCRIPTION APPROVED CHECKED DRAWN 1.0 15/06/15 新 發 行 楊祥忠 詹偉特 何秦芝 1.1 15/09/10 更改卷軸 A(mm)尺寸定義 : 12.0±0.5 改 12.4+2/-0 楊祥忠 詹偉特 何秦芝 1.2 17/03/24 增加:電流 MAX 規格 楊祥忠 詹偉特 何秦芝 備 注 TAI-TECH P2 SMD Power Inductor TMPC0412HP-Serise(G)-Z02 1. Features 1. Carbonyl Powder. 2. Compact design. 3. High current,low DCR,high efficiency. Halogen Pb Halogen-free Pb-free 4. Very low acoustic noise and very low leakage flux noise. 5. High reliability. 6. 100% Lead(Pb)-Free and RoHS compliant. 2. Applications Note PC power system,incl. IMVP-6 DC/DC converter . 3. Dimensions Recommend PC Board Pattern Dr. MOS application C D H L E B A   1R0 G Series A(mm) B(mm) TMPC0412HP 4.45±0.25 4.06±0.25 C(mm) D(mm) E(mm) 1.0±0.2 0.76±0.30 2.0±0.20 4. Part Numbering TMPC 0412 HP A B C A: Series B: Dimension C: Type D: Inductance E: Inductance Tolerance F: Control S/N - 1R0 MG D E - Z02 F BxC H: Carbonyl Powder, P:PAD broaden. 1R0=1.0uH M=±20% 印字:黑色,單向印字 L(mm) G(mm) H(mm) 5.2 2.2 2.3 Note: 1. The above PCB layout reference only. 2. Recommend solder paste thickness at 0.12mm and above TAI-TECH P3 5. Specification Part Number Inductance L0 (uH) @0A Typ Max Typ TMPC0412HP-R10YG-Z02 0.10±30% 11.5 10.0 25.0 I rms (A) Max DCR (mΩ) Typ. @25℃ DCR (mΩ) Max. @25℃ 22.0 4.3 5.5 I sat (A) TMPC0412HP-R15YG-Z02 0.15±30% 10.0 9.00 21.5 19.0 5.5 6.8 TMPC0412HP-R22MG-Z02 0.22±20% 8.50 7.50 20.0 17.0 6.6 8.0 TMPC0412HP-R33MG-Z02 0.33±20% 7.00 6.00 11.0 9.00 13.6 16 TMPC0412HP-R36MG-Z02 0.36±20% 6.50 5.50 8.50 7.00 15.5 18 TMPC0412HP-R47MG-Z02 0.47±20% 6.00 5.00 6.50 5.50 18 20 TMPC0412HP-R60MG-Z02 0.60±20% 5.30 4.50 6.00 5.00 22.5 26 TMPC0412HP-R68MG-Z02 0.68±20% 5.00 4.00 6.00 5.00 32 37 TMPC0412HP-1R0MG-Z02 1.00±20% 4.00 3.50 6.00 5.00 41 47 TMPC0412HP-1R2MG-Z02 1.20±20% 3.50 2.70 5.00 4.20 48 56 TMPC0412HP-1R5MG-Z02 1.50±20% 3.00 2.40 4.00 3.20 55 63.3 TMPC0412HP-2R2MG-Z02 2.20±20% 2.80 2.20 3.50 3.00 69.2 80 TMPC0412HP-3R3MG-Z02 3.30±20% 2.30 2.00 3.00 2.70 84 97 TMPC0412HP-4R7MG-Z02 4.70±20% 2.00 1.70 2.50 2.30 128 145 TMPC0412HP-5R6MG-Z02 5.60±20% 1.70 1.50 2.30 2.00 180 208 TMPC0412HP-6R8MG-Z02 6.80±20% 1.50 1.30 1.70 1.50 300 360 TMPC0412HP-8R2MG-Z02 8.20±20% 1.40 1.10 1.60 1.40 313 376 TMPC0412HP-100MG-Z02 10.0±20% 1.30 1.00 1.40 1.20 410 463 TMPC0412HP-180MG-Z02 18.0±20% 0.90 0.70 1.10 0.90 860 960 TMPC0412HP-220MG-Z02 22.0±20% 0.80 0.60 1.00 0.80 950 1050 Note: 1. Test frequency : Ls : 100KHz /1.0V. 2. All test data referenced to 25℃ ambient. 3. Testing Instrument(or equ) : L: HP4284A,CH11025,CH3302,CH1320,CH1320S LCR METER / Rdc:CH16502,Agilent33420A MICRO OHMMETER. 4. Heat Rated Current (Irms) will cause the coil temperature rise approximately ΔT of 40℃ 5. Saturation Current (Isat) will cause L0 to drop approximately 20%. 6. The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. 7. Special inquiries besides the above common used types can be met on your requirement. TAI-TECH P4 6. Material List NO Items 1 Core Materials 2 Wire Polyester Wire or equivalent. 3 Clip 100% Pb free solder(Ni+Sn---Plating) 4 paint Epoxy resin 5 Ink Carbonyl Powder. Halogen-free ketone 7. Reliability and Test Condition Item Performance Operating temperature -40~+125℃ (Including self - temperature rise) Storage temperature 1.-10~+40℃,50~60%RH (Product without taping) 2.-40~+125℃ (on board) Test Condition Electrical Performance Test Inductance Refer to standard electrical characteristics list. DCR HP4284A,CH11025,CH3302,CH1320,CH1320S LCR Meter. CH16502,Agilent33420A Micro-Ohm Meter. Saturation Current (Isat) Approximately △L20%. Saturation DC Current (Isat) will cause L0 to drop △L(%) Heat Rated Current (Irms) Approximately △T40℃ Heat Rated Current (Irms) will cause the coil temperature rise △T(℃). 1.Applied the allowed DC current 2.Temperature measured by digital surface thermometer Reliability Test Preconditioning: Run through IR times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles) Temperature: 125±2℃(Inductor) Life Test reflow for 2 Applied current:rated current Duration:1000±12hrs Measured at room temperature after placing for 24±2 hrs Preconditioning: Run through IR times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Humidity:85±2﹪ R.H, Load Humidity reflow for 2 Temperature:85℃±2℃ Duration:1000hrs Min. with 100% rated current Measured at room temperature after placing for 24±2 hrs Appearance:No damage. Moisture Resistance Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Thermal shock Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles 1. Baked at50℃ for 25hrs, measured at room temperature after placing for 4 hrs. 2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs. 3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs 4. Keep at 25℃ 80-100%RH for 15min and vibrate at the frequency of 10 to 55 Hz to 10 Hz, measure at room temperature after placing for 1~2 hrs. Preconditioning: Run through IR reflow times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Condition for 1 cycle Step1:-40±2℃ 30±5min for Step2:25±2℃ ≦0.5min Step3:125±2℃ 30±5min Number of cycles: 500 Measured at room temperature after placing for 24±2 hrs Oscillation Frequency: 10~2K~10Hz for 20 minutes Vibration Equipment: Vibration checker Total Amplitude:1.52mm±10% Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 2 TAI-TECH P5 Item Shock Performance Type Peak value (g’s) Normal duration (D) (ms) Wave form Velocity change (Vi)ft/sec SMD 50 11 Half-sine 11.3 Lead 50 11 Half-sine 11.3 Appearance:No damage. Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Bending Solderability Test Condition More than 95% of the terminal electrode should be covered with solder。 Shall be mounted on a FR4 substrate of the following dimensions: >=0805 inch(2012mm):40x100x1.2mm =0805 inch(2012mm):1.2mm 0805 inch(2012mm):1kg ,
物料型号: - 系列型号:TMPC0412HP-Serise(G)-Z02
器件简介: - 该电感器采用碳粉芯,具有紧凑设计。 - 高电流、低直流电阻(DCR)、高效率。 - 极低的声学噪声和极低的漏磁通噪声。 - 无卤素、无铅,符合RoHS标准。 - 高可靠性,100%无铅,符合RoHS指令。
引脚分配: - 推荐PCB布线图,包括电感器的尺寸和推荐焊膏厚度。
参数特性: - 包括电感值(Inductance L0)、额定电流(I rms)、饱和电流(I sat)、直流电阻(DCR)等参数。 - 测试频率为100kHz,所有测试数据参考25℃环境。
功能详解: - 适用于PC电源系统,包括IMVP-6 DC/DC转换器。 - 详细列出了不同型号的电感值、额定电流、饱和电流和直流电阻。
应用信息: - 适用于PC电源系统,包括IMVP-6 DC/DC转换器。
封装信息: - 提供了电感器的尺寸参数和封装类型。 - 包装信息包括卷轴尺寸、胶带尺寸、包装数量和撕离力。
可靠性和测试条件: - 包括工作温度、存储温度、电气性能测试、寿命测试、耐湿性测试、耐热冲击测试、振动测试等。
焊接和安装: - 推荐使用温和活化的松香助焊剂,适合于再流焊接系统。 - 提供了焊接温度曲线和焊接铁的推荐条件。
包装信息: - 提供了卷轴尺寸、胶带尺寸、包装数量和撕离力的详细信息。
典型性能曲线: - 提供了不同型号电感器在不同直流电流下的电感值和温度上升曲线。
测试报告: - 由SGS出具的测试报告,包括对电感器的RoHS指令相关物质的测试结果。
注意事项: - 存储条件、运输和处理建议,以保持电感器的可焊性。
TMPC0412HP-4R7MG-Z02 价格&库存
很抱歉,暂时无法提供与“TMPC0412HP-4R7MG-Z02”相匹配的价格&库存,您可以联系我们找货
TMPC 0412HP-4R7MG-Z02
  • 4000+3.837154000+0.49530
  • 8000+3.604248000+0.46524
  • 12000+3.4752112000+0.44858
  • 20000+3.3197820000+0.42852
库存:3531
  • 1+8.409191+1.08546
  • 10+6.6974010+0.86451
  • 25+6.1402125+0.79258
  • 50+5.7509950+0.74234
  • 100+5.38905100+0.69562
  • 250+4.94790250+0.63868
  • 500+4.64038500+0.59898
  • 1000+4.353891000+0.56200
库存:3531
