TAI-TECH
P1
5. Specification
Part Number
Inductance
L0 (uH)±20%
@0A
I rms (A)
Typ.
I sat 1(A)
Typ.
I sat2 (A)
Typ.
DCR
(mΩ) Typ.
@25℃
DCR
(mΩ) Max.
@25℃
TMPC1707HP-R45MG-D
0.45
62
85
125
0.8
0.96
TMPC1707HP-1R0MG-D
1.00
52
60
70
1.6
2.0
TMPC1707HP-1R3MG-D
1.30
49
54
67
1.7
2.3
TMPC1707HP-1R5MG-D
1.50
47
52
65
2.0
2.5
TMPC1707HP-2R2MG-D
2.20
43.5
47
62
2.4
2.7
TMPC1707HP-3R3MG-D
3.30
28
45
54
3.5
3.9
TMPC1707HP-4R7MG-D
4.70
25
41
50
4.8
5.5
TMPC1707HP-5R6MG-D
5.60
21
40
45
5.8
7.05
TMPC1707HP-6R8MG-D
6.80
19
32
39
8.4
9.2
TMPC1707HP-8R2MG-D
8.20
18
25
31
9.6
10.8
TMPC1707HP-100MG-D
10.0
16.5
24
29
11.8
13.0
TMPC1707HP-150MG-D
15.0
12.5
23
27
17.8
20.5
TMPC1707HP-220MG-D
22.0
12
18
23
25.1
26.5
TMPC1707HP-330MG-D
33.0
10.7
15
44.0
TMPC1707HP-390MG-D
39.0
9.2
11
18
40.0
48.0
TMPC1707HP-470MG-D
47.0
8.7
9.5
16
48.0
55.0
TMPC1707HP-560MG-D
56.0
7.8
9.0
15
54.0
62.0
TMPC1707HP-680MG-D
68.0
7.0
8.0
13
68.0
80.0
TMPC1707HP-101MG-D
100
5.3
6.5
12
102.0
118.0
Note:
1. Test frequency : L/Q: 100KHz /1.0V.
2. All test data referenced to 25℃ ambient.
3. Testing Instrument : L/Q: HP4284A,CH11025,CH3302,CH1320 ,CH1320S LCR METER / Rdc:CH16502,Agilent33420A MICRO OHMMETER.
4. Heat Rated Current (Irms) will cause the coil temperature rise approximately Δt of 40℃
5.
Saturation Current (Isat1) will cause L0
to drop approximately 20%
6.
Saturation Current (Isat2) will cause L0
to drop approximately 30%
7. The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and
thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application.
7. Special inquiries besides the above common used types can be met on your requirement.
TAI-TECH
P2
6. Typical Performance Curves
0.14
24
30
16
1.8
72
1.2
48
0.6
24
42
56
40
48
2
48
0.7
24
1
24
TMPC1707HP-6R8
4
48
4.8
48
24
2
24
2.4
24
18.4
27.6
36.8
120
16
24
32
40
DC CURRENT(A)
TMPC1707HP-100
TMPC1707HP-150
100
25
12
80
9
60
15
60
6
40
10
40
24
3
TEMP. RISE(oC)
INDUCTANCE (uH)
INDUCTANCE (uH)
34
11.6
17.4
23.2
29
120
50
28
96
21
72
14
48
7
100
DC CURRENT(A)
10.8
16.2
21.6
27
DC CURRENT(A)
TMPC1707HP-330
TMPC1707HP-390
120
60
40
96
48
96
30
72
36
72
24
48
24
10
24
12
24
TEMP. RISE(oC)
INDUCTANCE (uH)
INDUCTANCE (uH)
54
72
TEMP. RISE(oC)
INDUCTANCE (uH)
INDUCTANCE (uH)
TMPC1707HP-5R6
DC CURRENT(A)
16.8
43.2
7.2
3
72
48
TMPC1707HP-220
21.6
DC CURRENT(A)
6
6
12.6
10.8
96
72
8.4
9
DC CURRENT(A)
62
96
96
4.2
49.6
8
12
12
15
35
24.8
120
120
120
27.2
70
TMPC1707HP-3R3
DC CURRENT(A)
1.4
DC CURRENT(A)
TMPC1707HP-8R2
42
72
1.6
DC CURRENT(A)
3
48
20.4
14
72
3.2
13.6
72
6.8
96
4.8
4
96
15
24
96
6.4
30
0.4
2.8
10
5
120
10
0.8
DC CURRENT(A)
TMPC1707HP-4R7
120
DC CURRENT(A)
8
48
TEMP. RISE(oC)
INDUCTANCE (uH)
96
14
32
TMPC1707HP-2R2
3.5
TEMP. RISE(oC)
INDUCTANCE (uH)
INDUCTANCE (uH)
120
2.4
DC CURRENT(A)
TMPC1707HP-1R5
3
96
DC CURRENT(A)
TEMP. RISE(oC)
INDUCTANCE (uH)
78
0.3
TEMP. RISE(oC)
INDUCTANCE (uH)
52
60
8
12
DC CURRENT(A)
16
TEMP. RISE(oC)
INDUCTANCE (uH)
26
0.6
1.6
TEMP. RISE(oC)
48
0.9
120
TEMP. RISE(oC)
0.28
120
TEMP. RISE(oC)
72
1.2
TMPC1707HP-1R3
2
TEMP. RISE(oC)
0.42
150
120
7.2
10.8
DC CURRENT(A)
14.4
18
TEMP. RISE(oC)
96
TEMP. RISE(oC)
INDUCTANCE (uH)
INDUCTANCE (uH)
0.56
TMPC1707HP-1R0
1.5
120
TEMP. RISE(oC)
INDUCTANCE (uH)
TMPC1707HP-R45
0.7
TAI-TECH
48
96
36
72
24
48
12
6.4
9.6
12.8
100
64
48
80
56
48
36
60
42
32
24
40
28
24
16
12
90
72
60
48
30
24
4.8
7.2
DC CURRENT(A)
9.6
12
TEMP. RISE(oC)
INDUCTANCE (uH)
120
120
3.6
5.4
DC CURRENT(A)
TMPC1707HP-101
TMPC1707HP-680
60
DC CURRENT(A)
150
TMPC1707HP-560
7.2
9
70
5.2
7.8
DC CURRENT(A)
10.4
13
TEMP. RISE(oC)
80
TEMP. RISE(oC)
INDUCTANCE (uH)
120
TEMP. RISE(oC)
INDUCTANCE (uH)
TMPC1707HP-470
60
INDUCTANCE (uH)
P3
很抱歉,暂时无法提供与“TMPC1707HP-150MG-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+8.70480
- 10+7.24680
- 30+6.43680
