HIGH CURRENT MOLDING POWER CHOKE
MCS0420 Series (SHIELDED)
■ Mechanical Dimensions (Unit: mm)
MCS0420
XXX
XXX
Recommended Patterns
■ Electrical Specification
Part Number
Marking
Inductance
(uH)
Inductance
Tolerance
Test Freq.
(KHz)
MCS0420-R47MN2
MCS0420-1R0MN2
MCS0420-1R5MN2
MCS0420-2R2MN2
MCS0420-3R3MN2
MCS0420-4R7MN2
MCS0420-6R8MN2
R47
1R0
1R5
2R2
3R3
4R7
6R8
0.47
1.0
1.5
2.2
3.3
4.7
6.8
M
M
M
M
M
M
M
100
100
100
100
100
100
100
DCR
(mΩ)
Typical
12.5
24.0
38.0
52.0
74.0
92.0
162.0
DCR
(mΩ)
Max.
14.0
27.0
46.0
58.0
87.0
105.0
178.0
Rated Current
(A)
Typical
7.0
4.5
4.0
3.0
2..5
2.2
2.0
I sat
(A)
Typical
9.5
7.0
6.0
5.0
4.0
3.0
2.1
f. The part temperature (ambient +temp rise) should not exceed 125°C under
worst case operating conditions. Circuit design, component placement, PWB
trace size and thickness, airflow and other cooling provisions all affect the part
temperature Part temperature should be verified in the end application.
g. Test Instrument: Chroma16502、Chroma11300.
a. Tolerance: M=±20%,N=±30%
b. All test data is referenced to 25°C ambient.
c. Operating Temperature Range -55°C to +125°C .
d. Rated current (A) that will cause an approximate ΔT of 40°C .
e. Isat (A) that will cause Lo to drop approximately 30%.
■ Characteristic Curve
‧MCS0420
Inductance vs. DC Current
Temperature Rise vs. DC Current
Temperature
Rise vs. DC Current
7
150
2R2
6
4R7
Inductance (uH)(uH)
Inductance
6R8
1R0
1R5
3R3
120
R47
ΔT (°C)
90
60
5
6R8
4
3
4R7
3R3
2
2R2
1R5
30
1
1R0
R47
2
3
4
5
DC Current (A)
DC Current (A)
6
7
8
9
10
2
3
4
5
6
7
8
9
10
11
Current (A)
DC DC
Current
(A)
Prosperity Dielectrics Co., Ltd.
2013目錄.indd 59
59
2013/2/1 下午 03:02:47
很抱歉,暂时无法提供与“MCS0420-100MN1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.52273
- 50+0.51489
- 400+0.49944
- 800+0.47697
- 2000+0.44835
