5x7
SMDSMD
Crystal
2.5x2.0
OSCILLATOR
深圳市星通时频电子有限公司
SHENZHEN SCTF ELECTRONICS CO.,LTD
FEATURE
Tight frequence tolerance.
CMOS compatible logic levels.
Pin-compatible with standard 2.5×2.0mm packages.
Designed for standard reflow and washing techniques.
Low power standby mode.
Pb-free and RoHS/Green compliant.
APPLICATIONS
Ideally suited designed for use in Ethernet, network adapter cards,hard disk
devices,blue tooth,PCMCIA Cards, Palmtop Computer, Portable Applications.
Pb
Free
●Electrical Specifications 电气参数
Holder Type
Frequency Range
1.000 Mhz to 64 MHz
±20ppm to ±50ppm
Supply Voltage
3.3V ±10%※(See Notes)
工作温度范围
Operating Temperature Range
-20℃ - +70℃ / -40℃ - +85℃
储存温度范围
Storage Temperature Range
-40℃ - +85℃/-55℃ - +125℃
占空比
Symmetry(Duty Cycle)
45/55 Standard
输出
Output Load
15pF Hcmos or 10 TTL
消耗电流
Current Consumption(15pf only)
1.000Mhz - 49.999Mhz=20mA max
(3.3V)
50.000Mhz - 64.000Mhz=30mA max
1.000Mhz - 49.999Mhz=15mA max
( 1.8V 2.5V 2.8V )
50.000Mhz - 64.000Mhz=25mA max
Rise/Fall Time
5 nS max
4
3
1
2
0.80
0.90
1
2
4
3
0.70
※Notes:The supply voltage 1.8V,2.5V,2.85V also can be made by customer.
0.90
0.60
1.30
Frequency Stability
2.5±0.1
2.0±0.1
总频差
输入电压
上升/下降时间
UNIT(单位):mm(毫米)
2.5x2.0mm SMD OSCILLATOR
0.9MAX
23
型号
频率范围
●Mechanical Dimensions 外型尺寸
1.0
1.70
●Test Circuit(测试电路)
suggested solder pad layout
Frequency
Counter
+Vs
A
Oscillator
4
3
+Vs
Power
Supply
1
V
2
0.1μF
Oscilloscope
15pF *
PIN
FUNCTION
1
Tri-state※(See Notes)
2
Ground
3
Output
4
Vdd
※Notes:
Tri-state: PIN 1 connected to Vdd or floating, the product is working properly;connected to GND,stops working.
The above specifications are standard for SCTF product
If you have special requirement please Contact SCTF sales with your enquiries
Tel:0086-0755-86097430,0086-0755-86097250
The above specifications are standard for HLX product
Fax:0086-0755-86097259
If you have special requirement please Contact HLX sales with your en
E-mail:sales@ sctf-crystal.com
http://www.sctf-crystal.com
Tel:0086-25-85238320,0086-25-85320830(Direct)
Fax:0086-25-85315213,85301856
很抱歉,暂时无法提供与“S2D8.000000D20F30T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.90960
- 10+3.20760
- 30+2.86200
- 100+2.51640
- 500+2.14920
- 1000+2.04120
