SMAJ Series
Transient Voltage Suppressor
HF LF RoHS
SMAJxxxXX
»Features
Excellent clamping capability
Low leakage current
Low capacitance
High surge capability
Glass passivated chip
Epoxy resin package
Built-in strain relief
Will not fatigue
RoHS Compliant
Fast response time:
typically less than 1.0ps from 0 Volts to VBR min
»Mechanical
SMA (DO-214AC)
»Applications
Characteristics
Package: SMA plastic package.
Lead Finish: Matte Tin
Case Material: Epoxy Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 1 per J-STD-020
Telecom
Computer
Industrial electronic
Consumer electronic
»Electrical Parameters
Parameter
Definition
+I
CJ
Junction Capacitance - typical capacitance measured
with 0V or VR bias
IPP
Peak Pulse Current - maximum rated peak impulse
current
VC
Clamping Voltage - Peak voltage measured across the
suppressor at a specified Ippm (peak impulse current)
VBR
Breakdown Voltage - Maximum voltage that flows
though the TVS at a specified test current (IT)
IR
Leakage Current - maximum peak off-state current
measured at VR
VR
Peak Off-state Voltage - maximum voltage that can be
applied while maintaining off state
VF
Ipp
Uni
Bi
IT
IR
VR
VBR
VC
+V
»Summary of Packing Options
Package
SMA
Revision: 2018
Packing Description
Packing Quantity
Industry Standard
Tape/Reel,13" reel
5000
EIA-481-1
Tape/Reel,7" reel
2000
EIA-481-1
www.born-tw.com
1/7
SMAJ Series
»Absolute Maximum Ratings (TA=25℃ unless otherwise noted)
Parameter
Symbol
Value
Units
Remarks
PPPM
400
W
(Note1)(Note2)
Steady State Power Dissipation
PD
3.3
W
(Note3)
Peak Forward Surge Current
IFSM
40
A
(Note4)
Maximum Instantaneous Forward Voltage at 20A
VFM
3.5/6.5
V
(Note5)
Typical Thermal Resistance Junction to Lead
RθJL
30
℃/W
Typical Thermal Resistance Junction to Ambient
RθJA
120
℃/W
TJ
-55 to 150
TSTG
-55 to 150
Peak Pulse Power Dissipation
Operating Temperature Range
Storage Temperature Range
Notes1: Non-repetitive current pulse , 10/1000us Waveform.
Notes2: Mounted on copper pad area of 5×5mm to each terminal.
Notes3: Infinite HeatSink at TA=50°C
Notes4: Measured on 8.3ms single half sine wave or equivalent square wave, duty cycle=4 perminute maximum.
Notes5: For UnidirectionalOnly, VFM
很抱歉,暂时无法提供与“SMAJ5.0A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.41678
- 100+0.34161
- 300+0.30402
- 1000+0.27584
- 5000+0.21492
- 10000+0.20358
- 国内价格
- 1+0.31900
- 500+0.21230
- 2500+0.18480
- 5000+0.16940
- 国内价格
- 10+0.41300
- 100+0.33830
- 300+0.30100
- 1000+0.27310
- 5000+0.21280
- 10000+0.20160
