SS12-SS110
Schottky Barrier Diode
»Features
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
250℃/10 seconds at terminals
»General Description
SMA(DO-214AC)
Case: JEDEC DO -214AC molded plastic
Terminals: Axial leads. Solderable per MIL - STD - 750
Method 2026
Polarity: Color band denotes cathode
Mounting Position: Any
» Maximum Ratings and Electrical Characteristics
Ratings at 25 ℃ ambient temperature unless otherwise specifoed.
Single phase half wave 60HZ. resistive or inductive load. For capacitive load current derate by 20%
SYMBOL
SS12
SS13
SS14
SS15
SS16
SS18
SS110
UNITS
Maximum Recurrent Peak Reverse Voltage
VRRM
40
50
60
80
100
V
Maximum RMS Voltage
VRMS
14
21
28
35
42
56
70
V
Maximum DC Blocking Voltage
VDC
40
50
60
80
100
V
Maximum Average Forward Rectified Current
9.5mm Lead Length. TA = 75℃
I(AV)
1.0
A
IFSM
40.0
A
Peak Forward Surge Current
8.3ms Single half-sine-wave superimposed
on rated Tj = 125℃
Maximum Forward Voltage at 1.0A DC
Maximum Reverse Current
TA = 25℃
at Rated DC Blocking Voltage TA = 100℃
VF
IR
Typical Junction Capacitance ( Note 1 )
Cj
Typical Thermal Resistance ( Note 2 )
RQJA
Operating Junction Temperature Range
Tj
Storage Temperature Range
0.45
0.55
0.70
0.85
0.5
6.0
5.0
110
90
TSTG
mA
pF
℃/W
88.0
65 to 125
V
65 to 150
65 to 150
NOTE: Measured at 1.0MHz and applied reverse voltage of 4.0V DC
Revision 2018
www.born-tw.com
1/3
SS12-SS110
»Typical Performance Characteristics((TJ = 25 °C, unless otherwise noted))
FIG.1-TYPICAL INSTANTANEOUS
FORWARD CHARACTERISTICS
FIG.2-TYPICAL JUNCTION CHARACTERISTICS
1000
10
JUNCTION CAPACITANCE, p F
pulse width=300μS
TJ=25℃
SS12-SS14
1.0
AMPERES
INSTANTANEOUS FORWARD CURRENT,
50
SS15-SS16
SS18-SS110
0.1
300
Tj = 25 ℃
f = 1.0 MHZ
SS12-SS14
100
30.0
0.01
SS15-SS110
10.0
0.0
0.2
0.6
0.4
0.8
1.0
1.2
1.4
1.0
4.0
INTANTANEOUS FORWARD VOLEAGE,
10
100
REVERSE VOLTAGE, VOLTS
VOLTS
FIG.3-FORWARD CURRENT DERATING CURVE
FIG.4-MAXIMUM NON-REPETITIVE PEAK
FORWARD SURGE CURRENT
SS15-SS110
1.0
0.5
SS12-SS14
CURRENT, AMPERES
40
PEAK FORWARD SURGE
Single Phase Half Wave 60Hz
Resistive or Inductive Load
CURRENT,AMPERES
AVERAGE FORWARD RECTIFIED
1.5
30
8.3mS SINGLE HALF
SINE-WAVE
(JEDEC Method)
10
50
75
100
125
150
10
175
NUMBER OF CYCLES AT 60Hz
AMBIENT TEMPERATURE, ℃
Revision 2018
2.0
www.born-tw.com
2/3
SS12-SS110
»Package Information
SMA
B
D
A
C
F
H
L
G
Z
X
Y
SMA
Dimension
Inches
MIN
NOM
Millimeters
MAX
MIN
NOM
MAX
A
0.1
0.11
2.54
2.8
B
0.194
0.223
4.93
5.66
C
0.051
0.067
1.3
1.7
D
0.157
0.177
3.99
4.5
F
0.006
0.012
0.152
0.305
G
H
L
X
Y
Z
0.078
0.03
0.008
0.095
0.06
1.98
0.76
0.203
2.42
1.52
0.085
0.07
0.079
2.16
1.78
2
»Ordering information
Part Number
SS12
SS13
SS14
SS15
SS16
SS18
SS110
Marking
SS12
SS13
SS14
SS15
SS16
SS18
SS110
Base qty
5K
5K
5K
5K
5K
5K
5K
Revision 2018
www.born-tw.com
3/3
很抱歉,暂时无法提供与“SS16”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.18060
- 200+0.14240
- 600+0.12230
- 5000+0.10290
- 10000+0.09240
- 20000+0.08680
- 国内价格
- 20+0.18771
- 200+0.14980
- 600+0.12874
- 5000+0.10822
- 10000+0.09720
- 20000+0.09126
- 国内价格
- 1+0.42350
- 500+0.14190
- 2500+0.09427
- 5000+0.07722
