BST23A152V
ESD Protection Diode Array
»Features
300 Watts peak pulse power (tp = 8/20μs)
Unidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
IEC 61000-4-2 ±30kV contact ±30kV air
IEC 61000-4-4 (EFT) 40A(5/50ns)
IEC 61000-4-5 (Lightning) 8A(8/20μs)
»Mechanical Data
»Applications
Dataline
SOT-23 package
Automatic Teller Machines
Molding compound flammability rating: UL 94V-0
Net works
Packaging: Tape and Reel
Power line
RoHS/WEEE Compliant
»Schematic & PIN Configuration
1
1
3
3
2
2
SOT-23 (Top View)
Revision 2018
www.born-tw.com
1/4
BST23A152V
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs )
PPP
300
Watts
Peak Pulse Current ( tp =8/20μs ) (note1)
Ipp
8
A
VESD
30
30
kV
Lead Soldering Temperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 125
Storage Temperature
Tstg
-55 to + 125
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Conditions
Typical
Max
Units
15
V
17.6
20.0
V
0.1
0.5
μA
8
A
38
45
V
50
55
pF
VRWM
VBR
IT=1mA
Reverse Leakage Current
IR
VRWM=15V,T=25℃
Peak Pulse Current
IPP
tp =8/20μs
Clamping Voltage
VC
IPP=8A,tp=8/20μs
Junction Capacitance
Cj
Reverse Breakdown Voltage
Min
16.7
VR = 0V, f = 1MHz
(Pin1、Pin2 to Pin 3)
»Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
V RWM
IR
V BR
IT
I
IF
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ V RWM
VC VBR VRWM
Breakdown Voltage @ IT
IR V F
IT
V
Test Current
IPP
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
BST23A152V
»TypicalCharacteristics
Figure 2: Power Derating Curve
10
110
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
300w 8/20 sµaveform
1
0.1
0.01
0.1
1
10
100
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
Figure3: Pulse Waveform
Percent
Ipp
80
e-1
50
40
td=Ipp/
2
5
Revision 2018
10
15
150
35
30
25
Test
Waveform
Paramters
tr=8µs
td=20µs
15
10
5
40
Clamping Voltage–V C (V)
90
30
100
45
Waveform
Paramters
tr=8µs
td=20µs
100
60
75
Figure 4: Clamping Voltage vs.Ipp
110
70
50
Ambient Temperature - TA (℃)
Time (µs)
30
4
6
8
10
12
Peak Pulse Current–IPP (A)
www.born-tw.com
3/4
BST23A152V
»Outline Drawing – SOT-23
DIMENSIONS
D
SYMBOL
3
E1 E
θ
1
b
0.25
L
2
e
A1
INCHES
MIN
MAX
MIN
MAX
A
0.900
1.150
0.035
0.045
A1
0.000
0.100
A2
0.900
1.050
0.035
0.041
D
2.800
3.000
0.110
0.118
0.000
0.004
b
0.300
0.500
0.012
0.020
E
2.250
2.550
0.089
0.100
E1
1.200
1.400
0.047
0.055
e
A
A2
MILLIMETER
0.950 BSC
0.037 BSC
L
0.300
0.500
0.012
0.020
θ
8○
»Marking
BM2
»Ordering information
Order code
BST23A152V
Revision 2018
Package
SOT-23
Base qty
3k
www.born-tw.com
Delivery mode
Tape and reel
4/4
很抱歉,暂时无法提供与“BST23A152V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.40370
- 200+0.26070
- 1500+0.22660
- 3000+0.20020
- 国内价格
- 5+0.44540
- 50+0.35208
- 150+0.30543
- 500+0.27044
- 3000+0.24246
- 6000+0.22842
