MHCD252012A-1R0M-A8SW
    CHILISIN(奇力新)
    SMD,2.5x2mm
    功率电感 1uH ±20% IND_2.5X2MM_SM
MHCD252012A-1R0M-A8SW 数据手册
Cautions and Warnings Please be noted that this spec is only for reference if you have projects designed with the product number listed in. If you are looking for new project design-in, please find BDCD Series specification/datasheet on Chilisin website. Or you may find our sales contact for more information on old part number at your convenience. Appreciated your attention and understanding. Note: Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. Molding Power Inductors – MHCD Series MHCD Series MHCD Series provides high current in compact package size with magnetically shielded construction. This power inductor is an excellent power solution for space-limited devices. Features Applications  RoHS, Halogen Free and REACH Compliance  Monolithic, magnetically shielded  Capable for large current      Smartphones, tablets and wearable devices HDD, SSD and PC peripheral devices DSC, camcoders PND DC/DC converters Product Identification Shape and Dimensions Recommended Pattern Dimensions in mm Dimensions in mm TYPE A B C D TYPE A B C 201610 2.0±0.2 1.6±0.2 1.0Max 0.5±0.3 201610 0.7 2.3 1.8 201612 2.0±0.2 1.6±0.2 1.2Max 0.5±0.3 201612 0.7 2.3 1.8 252010 2.5±0.2 2.0±0.2 1.0Max 0.6±0.3 252010 1.2 2.8 2.3 252012 2.5±0.2 2.0±0.2 1.2Max 0.6±0.3 252012 1.2 2.8 2.3 322510 3.2±0.3 2.5±0.3 1.0Max 0.5±0.3 322510 1.7 3.5 2.8 322512 3.2±0.3 2.5±0.3 1.2Max 0.5±0.3 322512 1.7 3.5 2.8 Molding Power Inductors – MHCD Series Electrical Characteristics Test RDC(mΩ) Isat(A) Irms(A) Max(Typ.) Max(Typ.) Max(Typ.) 2 40(28) 4.2(6.0) 4.0(4.5) 20 2 48(40) 4.0(5.5) 3.5(3.8) 20 2 54(44) 3.2(5.0) 3.0(3.6) 0.56 20 2 59(46) 2.8(4.6) 2.8(3.3) MHCD201610A-R68M-A8S 0.68 20 2 72(55) 2.7(4.2) 2.4(3.0) MHCD201610A-1R0M-A8S 1.0 20 2 96(81) 2.2(3.4) 2.0(2.3) MHCD201610A-1R5M-A8S 1.5 20 2 150(122) 2.1(2.8) 1.6(2.0) MHCD201610A-2R2M-A8S 2.2 20 2 204(170) 2.0(2.4) 1.3(1.6) Inductance Tolerance (uH) (±%) MHCD201610A-R24M-A8S 0.24 20 MHCD201610A-R33M-A8S 0.33 MHCD201610A-R47M-A8S 0.47 MHCD201610A-R56M-A8S Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-40℃~125℃(Including self - temperature rise)  Isat for Inductance drop 30% from its value without current  Irms for a 40℃ temperature rise from 25℃ ambient with current  Absolute maximum voltage 25VDC  Measure Equipment: L:Agilent E4991/HP4286A+16197A (or equivalent), 2MHz 0.2V RDC:CHEN HWA502BC/HP4338B (or equivalent) Isat:Agilent E4980A+HP42841A (or equivalent) Irms:Agilent 6641 SYSTEM DC POWER SUPPLY (or equivalent) Test Instruments:E4991A Impedance / Material Analyzer Inductance v.s DC Current Tem perature Change v.s DC Current 2.5 2R2 140 2.0 120 1R5 1R0 R68 1.5 ΔT℃ L(uH) 100 2R2 1R5 1.0 R33 80 R24 R56 60 1R0 0.5 R47 40 R68 R56 R47 R33 R24 0.0 20 0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 DC Current(A) 6 6.5 7 7.5 8 8.5 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 5 5.5 6 6.5 7 Molding Power Inductors – MHCD Series Electrical Characteristics Test RDC(mΩ) Isat(A) Irms(A) Max(Typ.) Max(Typ.) Max(Typ.) 2 30(23) 5.0(6.0) 3.8(4.4) 20 2 41(34) 4.0(4.5) 2.9(3.3) 0.68 20 2 53(44) 3.3(3.6) 2.5(2.9) MHCD201610B-1R0M-A8L 1.0 20 2 72(60) 2.8(3.2) 2.2(2.5) MHCD201610B-2R2M-A8L 2.2 20 2 170(142) 1.8(2.1) 1.5(1.7) Inductance Tolerance (uH) (±%) MHCD201610B-R24M-A8L 0.24 20 MHCD201610B-R47M-A8L 0.47 MHCD201610B-R68M-A8L Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-40℃~125℃(Including self - temperature rise)  Isat for Inductance drop 30% from its value without current  Irms for a 40℃ temperature rise from 25℃ ambient with current  Absolute maximum voltage 25VDC  Measure Equipment: L:Agilent E4991/HP4286A+16197A (or equivalent), 2MHz 0.2V equivalent) Isat:Agilent E4980A+HP42841A (or equivalent) Irms:Agilent 6641 SYSTEM DC POWER SUPPLY (or equivalent) RDC:CHEN HWA502BC/HP4338B (or Test Instruments:E4991A Impedance / Material Analyzer Inductance v.s DC Current Tem perature Change v.s DC Current 2.5 80 2.0 R47 1.5 1R0 2R2 2R2 ΔT℃ L(uH) 60 1.0 R68 R24 40 1R0 0.5 R68 R47 20 R24 0.0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 6.5 7 7.5 8 8.5 9 DC Current(A) 0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 6 6.5 7 7.5 8 Molding Power Inductors – MHCD Series Electrical Characteristics Part Number Inductance (uH) Tolerance (±%) Test Frequency (MHz) RDC(mΩ) Max(Typ.) Isat(A) Max(Typ.) Irms(A) Max(Typ.) MHCD201612A-R24M-A8S 0.24 20 2 35(25) 5.5(6.5) 4.2(4.8) MHCD201612A-R47M-A8S 0.47 20 2 52(40) 3.8(5.1) 3.2(3.8) MHCD201612A-R68M-A8S 0.68 20 2 70(53) 3.3(4.8) 2.6(3.2) MHCD201612A-1R0M-A8S 1.0 20 2 82(67) 3.1(3.9) 2.3(2.7) MHCD201612A-1R5M-A8S 1.5 20 2 120(95) 2.6(3.2) 2.2(2.6) MHCD201612A-2R2M-A8S 2.2 20 2 195(165) 2.0(2.6) 1.3(1.7) Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-40℃~125℃(Including self - temperature rise)  Isat for Inductance drop 30% from its value without current  Irms for a 40℃ temperature rise from 25℃ ambient with current  Absolute maximum voltage 25VDC  Measure Equipment: L:Agilent E4991/HP4286A+16197A (or equivalent), 2MHz 0.2V equivalent) Isat:Agilent E4980A+HP42841A (or equivalent) Irms:Agilent 6641 SYSTEM DC POWER SUPPLY (or equivalent) RDC:CHEN HWA502BC/HP4338B (or Test Instruments:E4991A Impedance / Material Analyzer Inductance v.s DC Current Tem perature Change v.s DC Current 2.5 140 2.0 1R5 120 ΔT℃ 1.5 2R2 1R5 1.0 1R0 2R2 100 L(uH) R47 R24 R68 80 60 1R0 0.5 40 R68 R47 20 R24 0 0.0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 DC Current(A) 5.5 6 6.5 7 7.5 8 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 5.5 6 6.5 7 7.5 8 Molding Power Inductors – MHCD Series Electrical Characteristics Inductance Tolerance (uH) (±%) MHCD252010A-R24M-A8S 0.24 20 MHCD252010A-R47M-A8S 0.47 MHCD252010A-R68M-A8S Test RDC(mΩ) Isat(A) Irms(A) Max(Typ.) Max(Typ.) Max(Typ.) 2 40(24) 7.5(9.5) 4.5(5.0) 20 2 46(36) 5.2(6.5) 3.1(3.6) 0.68 20 2 65(49) 3.8(5.0) 2.9(3.3) MHCD252010A-1R0M-A8S 1.0 20 2 78(60) 3.4(4.3) 2.5(3.0) MHCD252010A-1R5M-A8S 1.5 20 2 105(82) 3.2(4.0) 2.2(2.9) MHCD252010A-2R2M-A8S 2.2 20 2 156(130) 2.6(3.2) 1.4(1.8) Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-40℃~125℃(Including self - temperature rise)  Isat for Inductance drop 30% from its value without current  Irms for a 40℃ temperature rise from 25℃ ambient with current  Absolute maximum voltage 25VDC  Measure Equipment: L:Agilent E4991/HP4286A+16197A (or equivalent), 2MHz 0.2V RDC:CHEN HWA502BC/HP4338B (or equivalent) Isat:Agilent E4980A+HP42841A (or equivalent) Irms:Agilent 6641 SYSTEM DC POWER SUPPLY (or equivalent) Test Instruments:E4991A Impedance / Material Analyzer Inductance v.s DC Current Tem perature Change v.s DC Current 2.5 140 2R2 120 R24 1R5 1R0 2.0 ΔT℃ L(uH) 1.5 1R5 1.0 1R0 0.5 R68 100 2R2 R47 80 60 40 R68 R47 20 R24 0 0.0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 6.5 7 7.5 8 8.5 9 9.5 DC Current(A) 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 5.5 6 6.5 7 7.5 8 Molding Power Inductors – MHCD Series Electrical Characteristics Inductance Tolerance (uH) (±%) MHCD252010B-R33M-A8L 0.33 20 MHCD252010B-R47M-A8L 0.47 MHCD252010B-R68M-A8L 0.68 MHCD252010B-1R0M-A8L Test RDC(mΩ) Isat(A) Irms(A) Max(Typ.) Max(Typ.) Max(Typ.) 2 31(25) 5.0(6.0) 3.8(4.4) 20 2 35(29) 4.2(4.7) 3.4(3.9) 20 2 48(40) 3.7(4.0) 3.0(3.5) 1.0 20 2 65(54) 3.2(3.6) 2.6(3.0) MHCD252010B-1R5M-A8L 1.5 20 2 94(78) 2.9(3.3) 2.1(2.4) MHCD252010B-2R2M-A8L 2.2 20 2 120(100) 2.3(2.7) 1.8(2.1) Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-40℃~125℃(Including self - temperature rise)  Isat for Inductance drop 30% from its value without current  Irms for a 40℃ temperature rise from 25℃ ambient with current  Absolute maximum voltage 25VDC  Measure Equipment: L:Agilent E4991/HP4286A+16197A (or equivalent), 2MHz 0.2V equivalent) Isat:Agilent E4980A+HP42841A (or equivalent) Irms:Agilent 6641 SYSTEM DC POWER SUPPLY (or equivalent) RDC:CHEN HWA502BC/HP4338B (or Test Instruments:E4991A Impedance / Material Analyzer Tem perature Change v.s DC Current Inductance v.s DC Current 2.5 70 R33 60 1R5 2.0 1R0 2R2 R47 2R2 1.5 ΔT℃ L(uH) 50 1R5 1.0 40 30 1R0 20 R47 0.5 R33 10 0 0.0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 DC Current(A) 5 5.5 6 6.5 7 7.5 0 0.5 1 1.5 2 2.5 3 3.5 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 4 4.5 5 5.5 6 Molding Power Inductors – MHCD Series Electrical Characteristics Inductance Tolerance (uH) (±%) MHCD252012A-R33M-A8S 0.33 20 MHCD252012A-R47M-A8S 0.47 MHCD252012A-R68M-A8S 0.68 MHCD252012A-1R0M-A8S Test RDC(mΩ) Isat(A) Irms(A) Max(Typ.) Max(Typ.) Max(Typ.) 2 35(27) 6.8(8.5) 4.0(4.6) 20 2 39(29) 6.2(7.8) 3.7(4.4) 20 2 46(40) 5.5(6.5) 3.3(3.7) 1.0 20 2 59(45) 4.0(5.0) 3.0(3.5) MHCD252012A-1R5M-A8S 1.5 20 2 70(62) 3.4(4.0) 2.5(2.7) MHCD252012A-2R2M-A8S 2.2 20 2 115(102) 3.3(3.8) 2.0(2.3) Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-40℃~125℃(Including self - temperature rise)  Isat for Inductance drop 30% from its value without current  Irms for a 40℃ temperature rise from 25℃ ambient with current  Absolute maximum voltage 25VDC  Measure Equipment: L:Agilent E4991/HP4286A+16197A (or equivalent), 2MHz 0.2V equivalent) Isat:Agilent E4980A+HP42841A (or equivalent) Irms:Agilent 6641 SYSTEM DC POWER SUPPLY (or equivalent) RDC:CHEN HWA502BC/HP4338B (or Test Instruments:E4991A Impedance / Material Analyzer Tem perature Change v.s DC Current Inductance v.s DC Current 2.5 70 2R2 60 1R0 2.0 1R5 1.5 ΔT( ℃ ) L(uH) 50 2R2 1R5 1.0 R33 R68 R47 40 30 1R0 20 R68 0.5 R47 R33 10 0.0 0 0 1 2 3 4 5 DC Current(A) 6 7 8 9 0 0.5 1 1.5 2 2.5 3 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 3.5 4 4.5 5 Molding Power Inductors – MHCD Series Electrical Characteristics Test Inductance Tolerance (uH) (±%) MHCD252012B-R47M-A8L 0.47 20 2 MHCD252012B-1R0M-A8L 1.0 20 MHCD252012B-2R2M-A8L 2.2 20 Part Number RDC(mΩ) Isat(A) Irms(A) Max(Typ.) Max(Typ.) Max(Typ.) 34(30) 5.2(6.0) 4.1(4.7) 2 56(45) 3.6(4.5) 3.2(3.7) 2 102(80) 2.5(3.0) 2.2(2.6) Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-40℃~125℃(Including self - temperature rise)  Isat for Inductance drop 30% from its value without current  Irms for a 40℃ temperature rise from 25℃ ambient with current  Absolute maximum voltage 25VDC  Measure Equipment: L:Agilent E4991/HP4286A+16197A (or equivalent), 2MHz 0.2V RDC:CHEN HWA502BC/HP4338B (or equivalent) Isat:Agilent E4980A+HP42841A (or equivalent) Irms:Agilent 6641 SYSTEM DC POWER SUPPLY (or equivalent) Test Instruments:E4991A Impedance / Material Analyzer Inductance v.s DC Current Tem perature Change v.s DC Current 3.0 70 1R0 60 2.5 2R2 R47 50 ΔT( ℃ ) L(uH) 2.0 2R2 1.5 1.0 40 30 20 1R0 0.5 10 R47 0 0.0 0 1 2 3 4 DC Current(A) 5 6 7 8 0 1 2 3 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 4 5 6 Molding Power Inductors – MHCD Series Electrical Characteristics Inductance Tolerance (uH) (±%) MHCD322510A-R47M-A8S 0.47 20 MHCD322510A-1R0M-A8S 1.0 MHCD322510A-1R5M-A8S MHCD322510A-2R2M-A8S Part Number Test RDC(mΩ) Isat(A) Irms(A) Max(Typ.) Max(Typ.) Max(Typ.) 2 37(30) 5.8(6.6) 3.6(4.2) 20 2 56(49) 4.0(4.6) 3.0(3.3) 1.5 20 2 75(66) 3.4(4.0) 2.6(3.0) 2.2 20 2 108(95) 2.7(3.2) 2.2(2.5) Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-40℃~125℃(Including self - temperature rise)  Isat for Inductance drop 30% from its value without current  Irms for a 40℃ temperature rise from 25℃ ambient with current  Absolute maximum voltage 25VDC  Measure Equipment: L:Agilent E4991/HP4286A+16197A (or equivalent), 2MHz 0.2V RDC:CHEN HWA502BC/HP4338B (or equivalent) Isat:Agilent E4980A+HP42841A (or equivalent) Irms:Agilent 6641 SYSTEM DC POWER SUPPLY (or equivalent) Test Instruments:E4991A Impedance / Material Analyzer Inductance v.s DC Current Tem perature Change v.s DC Current 2.5 70 2R2 60 1R5 1R0 R47 50 1.5 2R2 ΔT( ℃ ) L(uH) 2.0 1R5 1.0 40 30 1R0 20 0.5 R47 10 0.0 0 1 2 3 4 5 DC Current(A) 6 7 8 0 0 1 2 3 4 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 5 6 Molding Power Inductors – MHCD Series Electrical Characteristics Part Number Inductance (uH) Tolerance (±%) Test Frequency (MHz) RDC(mΩ) Max(Typ.) Isat(A) Max(Typ.) Irms(A) Max(Typ.) MHCD322512A-R47M-A8S 0.47 20 2 27(21) 8.0(9.0) 5.0(5.8) MHCD322512A-R68M-A8S 0.68 20 2 34(26) 6.3(7.5) 4.0(4.6) MHCD322512A-1R0M-A8S 1.0 20 2 42(34) 5.8(6.3) 3.8(4.2) MHCD322512A-1R5M-A8S 1.5 20 2 68(58) 4.0(4.5) 2.8(3.2) MHCD322512A-2R2M-A8S 2.2 20 2 85(75) 3.6(4.0) 2.4(2.7) Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-40℃~125℃(Including self - temperature rise)  Isat for Inductance drop 30% from its value without current  Irms for a 40℃ temperature rise from 25℃ ambient with current  Absolute maximum voltage 25VDC  Measure Equipment: L:Agilent E4991/HP4286A+16197A (or equivalent), 2MHz 0.2V equivalent) Isat:Agilent E4980A+HP42841A (or equivalent) Irms:Agilent 6641 SYSTEM DC POWER SUPPLY (or equivalent) RDC:CHEN HWA502BC/HP4338B (or Test Instruments:E4991A Impedance / Material Analyzer Inductance v.s DC Current Tem perature Change v.s DC Current 3.0 70 2R2 R68 1R5 60 2.5 R47 1R0 50 ΔT( ℃ ) L(uH) 2.0 2R2 1.5 40 30 1R5 1.0 1R0 20 R68 0.5 10 R47 0 0.0 0 1 2 3 4 5 6 DC Current(A) 7 8 9 10 11 0 1 2 3 4 5 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 6 7 8 Molding Power Inductors – MHCD Series Packaging Specifications Tape Dimensions Tape Material Reel Dimensions Dimensions in mm Tape Dimensions Reel Dimensions Quantity TYPE A B T W P F K A B C D PCS / REEL 201610 1.80 2.20 0.22 8 4 3.5 1.15 178 60 12 1.5 3000 201612 1.80 2.20 0.22 8 4 3.5 1.15 178 60 12 1.5 3000 252010 2.25 2.80 0.22 8 4 3.5 1.15 178 60 12 1.5 3000 252012 2.25 2.80 0.22 8 4 3.5 1.35 178 60 12 1.5 3000 322510 2.80 3.55 0.23 8 4 3.5 1.20 178 60 12 1.5 3000 322512 2.80 3.50 0.23 8 4 3.5 1.34 178 60 12 1.5 3000
MHCD252012A-1R0M-A8SW 价格&库存
很抱歉,暂时无法提供与“MHCD252012A-1R0M-A8SW”相匹配的价格&库存,您可以联系我们找货
    • 10+0.50069
    • 100+0.39960
    • 300+0.34906
    库存:77
