SMD TCXO 2.0×1.6×0.85mm
2016 TCXO Series
■ Features
- 2.0 x 1.6 x 0.85 MAX. mm of surface mounted quartz crystal units
with thermistor.
- Excellent reliability characteristics such as heat and mechanical shock.
- Pb-free and satisfy RoHs requirements.
- Reflow soldering is available.
■ Applications
- Cellular phone(GSM & CDMA & WCDMA)
- GPS Module
- WIBRO,DMB,PDA
- Repeater
■ Specifications
Output Frequency
Supply Voltage
Output Level (10kΩ//10pF)
Current Consumption
Operating Temperature Range
Storage Temperature Range
Frequency Stability
vs. Temperature (Refer to 25’C)
vs. Supply Voltage (±5%)
vs. Load (10kΩ//10pF)
vs. Aging (per 1 year)
Frequency Tolerance (Initial at 25’C)
Frequency Tolerance (After Reflow)
AFC characteristics
Harmonics
Frequency Slope
at -20 ~ 65’C
at -30 ~ 85’C
■ Dimensions (unit: mm)
For Cellular
8.0 MHz ~ 52.0 MHz
DC +1.7V ~ +3.3V
0.8 Vp-p min.
For GPS
8.0 MHz ~ 52.0 MHz
DC +1.7V ~ +3.3V
0.8 Vp-p min.
1.5 mA Max. (Below 32 MHz)
2.0 mA Max. (Above 32 MHz)
-30’C ~ +85’C
-40’C ~ +85’C
-30’C ~ +85’C
-40’C ~ +85’C
±1.0, ±2.0 ppm Max.
±0.1 ppm Max.
±0.1 ppm Max.
±1.0 ppm Max.
±1.0 ppm Max.
±1.0 ppm Max.
Specify
-8 dBc Max.
±0.5 ppm Max.
±0.1 ppm Max.
±0.1 ppm Max.
±1.0 ppm Max.
±1.0 ppm Max.
±1.0 ppm Max.
Specify
-8 dBc Max.
±0.1 ppm/’C Max.
±0.2 ppm/’C Max.
±0.05 ppm/’C Max.
±0.1 ppm/’C Max.
■ Land pattern (unit: mm)
很抱歉,暂时无法提供与“9T26000128-Q”相匹配的价格&库存,您可以联系我们找货
