9T38400003-Q
9T38400003-Q
    YL(惠伦晶体)
    SMD2016_4P
    有源晶振 - 1.8V 38.4MHz SMD2016_4P
9T38400003-Q 数据手册
SMD TCXO 2.0×1.6×0.85mm 2016 TCXO Series ■ Features - 2.0 x 1.6 x 0.85 MAX. mm of surface mounted quartz crystal units with thermistor. - Excellent reliability characteristics such as heat and mechanical shock. - Pb-free and satisfy RoHs requirements. - Reflow soldering is available. ■ Applications - Cellular phone(GSM & CDMA & WCDMA) - GPS Module - WIBRO,DMB,PDA - Repeater ■ Specifications Output Frequency Supply Voltage Output Level (10kΩ//10pF) Current Consumption Operating Temperature Range Storage Temperature Range Frequency Stability vs. Temperature (Refer to 25’C) vs. Supply Voltage (±5%) vs. Load (10kΩ//10pF) vs. Aging (per 1 year) Frequency Tolerance (Initial at 25’C) Frequency Tolerance (After Reflow) AFC characteristics Harmonics Frequency Slope at -20 ~ 65’C at -30 ~ 85’C ■ Dimensions (unit: mm) For Cellular 8.0 MHz ~ 52.0 MHz DC +1.7V ~ +3.3V 0.8 Vp-p min. For GPS 8.0 MHz ~ 52.0 MHz DC +1.7V ~ +3.3V 0.8 Vp-p min. 1.5 mA Max. (Below 32 MHz) 2.0 mA Max. (Above 32 MHz) 1.5 mA Max. (Below 32 MHz) 2.0 mA Max. (Above 32 MHz) -30’C ~ +85’C -40’C ~ +85’C -30’C ~ +85’C -40’C ~ +85’C ±1.0, ±2.0 ppm Max. ±0.1 ppm Max. ±0.1 ppm Max. ±1.0 ppm Max. ±1.0 ppm Max. ±1.0 ppm Max. Specify -8 dBc Max. ±0.5 ppm Max. ±0.1 ppm Max. ±0.1 ppm Max. ±1.0 ppm Max. ±1.0 ppm Max. ±1.0 ppm Max. Specify -8 dBc Max. ±0.1 ppm/’C Max. ±0.2 ppm/’C Max. ±0.05 ppm/’C Max. ±0.1 ppm/’C Max. ■ Land pattern (unit: mm)
9T38400003-Q 价格&库存
很抱歉,暂时无法提供与“9T38400003-Q”相匹配的价格&库存,您可以联系我们找货
