1SS355
1SS355
    BORN(伯恩半导体)
    SOD-323
    开关二极管 VR=80V Io=100mA VF=1.2V IR=0.1μA
1SS355 数据手册
1SS355 Fast Switching Diode »Features  Fast Switching Device  Power Dissipation of 250mW  High Stability and High Reliability  Low reverse leakage »General Description  SOD-323 Small Outline Plastic Package  Polarity: Color band denotes cathode end  Mounting Position: Any SOD-323 »Absolute Maximum Ratings @T =25℃ unless otherwise noted A Parameters Reverse Voltage Symbol Value Unit VR 80 V VRM 90 V Power Dissipation Pd 250 mW Operating junction temperature Tj 150 ℃ Storage temperature range Ts -55-+150 ℃ Average Rectified Current IO 100 mA IFM 225 mA Peak Reverse Voltage Non-repetitive Peak Forward Current Valid provided that electrodes are kept at ambient temperature. Revision 2018 www.born-tw.com 1/4 1SS355 »Electrical Characteristics @T =25℃ unless otherwise noted A Symbols Parameter Limits Test Condition Unit Min Max --- 0.1 uA --- 1.20 V --- 4 nS --- 3 pF Reverse Leakage Current VR=80V IR Reverse Leakage Current Forward Voltage VF IF=100mA Forward Voltage TRR Reverse Recovery Time IF= 10mA, VR=6V Reverse Recovery Time RL=100Ω Capacitance C VR=0.5V, f=1MHZ Capacitance Revision 2018 www.born-tw.com 2/4 1SS355 »Typical Performance Characteristics((TJ = 25 °C, unless otherwise noted)) Forward 100 Characteristics Reverse 1000 Characteristics (mA) Ta=100℃ REVERSE CURRENT IR 1 Ta =2 5℃ FORWARD CURRENT Ta =1 00 ℃ IF (nA) 10 0.1 0.01 0.0 Ta=25℃ 10 1 0.2 0.4 0.6 FORWARD VOLTAGE 0.8 VF 1.0 1.2 0 20 (V) 40 REVERSE VOLTAGE Capacitance Characteristics 1.2 100 60 VR 80 (V) Power Derating Curve 300 Ta=25℃ f=1MHz (mW) PD POWER DISSIPATION CAPACITANCE BETWEEN TERMINALS CT (pF) 250 1.0 200 150 100 50 0.8 0 0 5 10 REVERSE VOLTAGE Revision 2018 15 VR 20 0 (V) 25 50 75 AMBIENT TEMPERATURE www.born-tw.com 100 Ta a 125 150 ℃) 3/4 1SS355 »Package Information SOD-323 »Ordering information Order code 1SS355 Revision 2018 Package SOD-323 Marking A www.born-tw.com Base qty Delivery mode 3K Tape and reel 4/4
1SS355 价格&库存
很抱歉,暂时无法提供与“1SS355”相匹配的价格&库存,您可以联系我们找货
1SS355
  • 1+0.32780
  • 200+0.10956
  • 1500+0.06853
  • 3000+0.05434
库存:2244
1SS355
  • 50+0.11600
  • 500+0.09083
  • 3000+0.07452
  • 6000+0.06610
  • 24000+0.05886
  • 51000+0.05498
库存:8352
