MST002
MST002
    CONQUER(功得)
    FUSE_8.35X4.3MM_TM
    微型保险丝 250V 2A 插件
MST002 数据手册
CONQUER Micro Fuse Type MST Time Lag Radial Lead Micro Fuse Series Interrupting Rating 35 amperes or 10 x rated current ; whichever is greater at 250V AC SEMKO VDE TUV CSA Acceptance UL Recognized PSE CCC KTL CQC (IR:130A/250V AC) 63mA~10A 50mA~6.3A 50mA~10A 50mA~6.3A 50mA~10A 1A~10A 50mA~6.3A 50mA~6.3A 500mA~10A Recognized Component for Canada and U.S. PSE TUV CQC KTL 50mA~10A 1A~10A 50mA~10A 500mA~10A 500mA~6.3A 130 amperes at 250V AC(optional) 50 amperes at 300V AC(optional) Recognized Component for Canada and U.S. 50mA~10A PSE 1A~10A TUV 50mA~10A 100 amperes at 400V AC(optional) 100 amperes at 250V DC(optional) Recognized Component for Canada and U.S. 50mA~10A PSE 1A~10A Rated 1.5 In 2.1 In 2.75 In 4 In 10 In MIN MAX MIN MAX MIN MAX MIN MAX 50mA~5A 60 min 60 min 6.3A~10A 2 min 2 min 400 10 ms sec 400 10 ms sec 150 3 ms sec 150 3 ms sec Ampere Voltage Nominal Voltage Nominal Rating Rating Resistance Drop Melting I2t MST .050 MST .063 MST .080 MST .100 MST .125 MST .160 MST .200 MST .250 MST .315 MST .400 MST .500 MST .630 MST .800 MST 001 MST 1.25 MST 1.60 MST 002 MST 2.50 MST 3.15 MST 004 MST 005 MST 6.30 MST 008 MST 010 [ In ] (V) Cold Ohms (mv) MAX A2 Sec 50mA 63mA 80mA 100mA 125mA 160mA 200mA 250mA 315mA 400mA 500mA 630mA 800mA 1A 1.25A 1.6A 2A 2.5A 3.15A 4A 5A 6.3A 8A 10A 250V*1 8.9000 5.4053 3.6870 2.4063 1.6194 1.2458 0.8240 0.6300 0.3800 0.2700 0.1950 0.1322 0.0907 0.0750 0.0550 0.0425 0.0316 0.0241 0.0188 0.0136 0.0100 0.0074 0.0057 0.0034 550 480 400 350 300 280 260 240 220 200 190 180 160 140 130 120 100 100 100 100 100 100 100 100 0.0225 0.0446 0.0760 0.1080 0.1223 0.1700 0.3060 0.6019 0.8216 1.4832 2.7000 3.1792 5.7600 8.7300 14.766 23.040 36.000 56.250 93.768 158.40 202.50 310.77 368.64 288.00 *1 : 300V/400V optional Electrical Characteristic Current Catalog Number 20 ms 15 ms 150 ms 150 ms Environmental Specification Physical Specification Material Base and Cap: Black thermoplastic, UL 94-V0 Round Pins: Copper, Tin-plated Packaging 1. In bulk: 1,000 pcs per box. 2. On Tap: Ammo pack, 1,000 pcs box Mechanical Dimensions 26 Conquer Electronics Co., Ltd. Operating Temperature -55°C to +125°C Vibration MIL-STD-202G, Method 201(10-55 Hz x 3axis/no load) Salt Spray MIL-STD-202G, Method 101, Test Condition B (48Hrs) Insulation Resistance MIL-STD-202G, Method 302, Test Condition A (After Opening) 10,000 ohms minimum (-65°C to +125°C) Resistance to Solder Heat MIL-STD-202G, Method 210, Test Condition B (10sec,at 260°C) Thermal Shock: MIL-STD-202G, Method 107, Test Condition B Conquer Electronics Co., Ltd. No.26, Wucyuan 5th Rd., Wugu Dist.,(New Taipei Industrial Park) New Taipei City 24888, Taiwan TEL: 886-2-8990-2189 (Rep.) Offical Website: http://www.conquer.com.tw FAX: 886-2-8990-2577
MST002 价格&库存
很抱歉,暂时无法提供与“MST002”相匹配的价格&库存,您可以联系我们找货
