Cautions and Warnings
Please be noted that this spec is only for reference if you have projects
designed with the product number listed in. If you are looking for new
project design-in, please find BPSC Series specification/datasheet on Chilisin
website. Or you may find our sales contact for more information on old part
number at your convenience. Appreciated your attention and
understanding.
Note: Please be sure to request approval specifications that provide further details of the products.
Kindly note that the content of these specifications are subject to change or may be discontinued
without prior notice. This product may not be designed/used in medical or high risk applications
without Chilisin approval. Please contact our sales department before ordering.
SMD Shielded Power Inductors - SCDS Series
SCDS Series
Features
Applications
RoHS, Halogen Free and REACH Compliance
Magnetic shielded
Various package size and wide inductance range
AP Routers
STBs
LCD TVs and monitors
Game consoles
LED lightings
DC/DC converters
T : Packaging: Tape and Reel
HP : High Power
LD : Low DCR
CEC Internal No.: S: Base type terminals
Product Identification
SCDS
SCDS3D16
SCDS2D11/2D14/2D18LD/ 2D18HP
Shape and Dimensions
Recommended Pattern
Dimension in mm
TYPE
Dimensions in mm
A
+0
B
+0
C
+0
SCDS2D11
3.2
3.2
SCDS2D14
3.2+0
3.2+0 1.55+0
SCDS2D18LD
SCDS2D18HP
+0
3.2
+0
3.2
+0
3.2
+0
3.2
1.2
+0
2.0
+0
2.0
D
E
F
+0
4.5
3.3
2.1
4.5+0
3.3
2.1
+0
3.3
2.1
4.5
+0
4.5
3.3
2.1
G
A
B
C
D
1.0
SCDS2D11
TYPE
1.3
1.7
1.3
4.3
1.0
SCDS2D14
1.3
1.7
1.3
4.3
1.0
SCDS2D18LD
1.3
1.7
1.3
4.3
1.0
SCDS2D18HP
1.3
1.7
1.3
4.3
SCDS3D11/3D11HP
Recommended Pattern
Dimension in mm
Dimensions in mm
A
B
C
D
E
F
G
A
B
C
D
SCDS3D11
4+0
4+0
1.2+0
5.2+0
4.4
2.8
1.1
SCDS3D11
1.4
2.4
1.5
5.2
SCDS3D11HP
4+0
4+0
1.2+0
5.2+0
4.4
2.8
1.1
SCDS3D11HP
1.4
2.4
1.5
5.2
TYPE
TYPE
SCDS 3D16T-XXX-S1-N
Recommended Pattern
Dimensions in mm
TYPE
SCDS3D16
A
+0
4
Dimension in mm
B
+0
4
C
D
+0
1.8
5.2
E
+0
F
4.4Typ
+0
1.4
G
TYPE
A
B
C
D
1.1Typ
SCDS3D16
1.4
2.4
1.5
5.2
SCDS3D28/3D28LD
Recommended Pattern
Dimension in mm
TYPE
Dimensions in mm
A
+0
B
+0
C
D
E
F
+0
TYPE
A
B
C
D
SCDS3D28
4
4
3
4.4
2.8
1.1
SCDS3D28
1.4
2.4
1.5
5.2
SCDS3D28LD
4+0
4+0
3+0
4.4
2.8
1.1
SCDS3D28LD
1.4
2.4
1.5
5.2
Standard Specifications
Stamp
RDC (mΩ) Max
Inductance
(H)
SCDS
SCDS
SCDS
SCDS
SCDS
SCDS
SCDS
SCDS
SCDS
2D11
2D14
2D18LD
2D18HP
3D11
3D11HP
3D16
3D28
3D28LD
40
45
R47
0.47
R60
0.6
40
1R0
1.0
1R2
1.2
1R5
1.5
1R7
1.7
1R8
1.8
2R2
2.2
2R7
2.7
3R3
3.3
123
125
3R9
3.9
160
138
4R1
4.1
4R7
4.7
5R6
5.6
6R3
6.3
6R8
6.8
8R2
8.2
100
10
120
12
150
15
180
18
220
22
270
27
330
33
460
822
390
39
600
942
470
47
660
560
56
325
680
68
470
59
82
68
63
44
104
52
143
72
182
85
72.1
234
105
88.3
44
75
98
94
41
60
54
86
78
140
106
78
169
170
169
123
188
135
160
260
213
106
195
281
400
294
950
377
204
180
245
220
345
394
600
180
320
650
170
119
210
240
413
276
585
372
653
468
888
540
1010
210
145
295
213
95
100
115
125
430
335
675
481
726
145
175
215
225
599
305
820
82
101
100
540
121
120
151
150
880
181
180
1130
221
220
1270
2750
610
755
Note: When ordering, please specify tolerance code. Tolerance: M=±20% , T=±30% , N = +40-20%
Operating temperature range-30℃~100℃(Including self - temperature rise)
Rated Current:DC current that will cause L drop approximately 35% over its nominal value or DC current cause the temperature rising
Irms for a 40℃ temperature rise from 25℃ ambient with current
Measure Equipment:
approximately △t=40℃, whichever is lower
Test Freq L:SCDS 2D11/ 2D14/ 2D18LP/2D18HP/3D11/3D11HP/3D28/3D28LD (100kHz/ 1V), SCDS 3D16 (100kHz/ 0.1V)
L:Agilent/ E4980 or HP4284A
RDC:Chroma 16502
Rated Current: HP4284+42841A or WK3260B+WK3265B
Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these
specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in
medical or high risk applications without Chilisin approval. Please contact our sales department before ordering.
Stamp
Rated Current (A)
Inductance
(H)
SCDS
SCDS
SCDS
SCDS
SCDS
SCDS
SCDS
SCDS
SCDS
2D11
2D14
2D18LD
2D18HP
3D11
3D11HP
3D16
3D28
3D28LD
1.60
2.80
R47
0.47
2.00
R60
0.6
1R0
1.0
1R2
1.2
1R5
1.5
1R7
1.7
1R8
1.8
2R2
2.2
2R7
2.7
3R3
3.3
0.60
1.20
3R9
3.9
0.60
1.10
4R1
4.1
4R7
4.7
5R6
5.6
6R3
6.3
6R8
6.8
8R2
8.2
100
10
120
12
150
15
180
18
220
22
270
27
330
33
0.24
0.15
390
39
0.22
0.14
470
47
0.20
560
56
0.20
680
68
0.185
2.90
2.00
0.90
1.80
1.90
1.85
1.55
1.60
1.20
1.25
1.10
2.00
1.00
0.90
1.65
1.85
1.65
0.78
1.50
0.85
1.60
1.35
0.53
0.75
1.45
0.63
1.20
1.00
0.50
1.00
0.40
0.95
0.80
1.05
0.44
0.85
0.52
1.00
0.80
0.35
0.70
0.34
0.85
0.32
0.43
0.85
0.62
0.25
0.35
0.70
0.16
0.30
0.50
0.73
1.24
0.55
0.28
0.80
0.25
0.64
0.23
0.58
0.21
0.52
0.19
0.45
0.55
1.05
0.45
0.90
0.40
0.76
0.50
0.45
0.40
0.35
0.17
0.33
0.29
0.32
0.58
0.28
0.25
0.48
0.23
820
82
101
100
0.172
121
120
0.136
151
150
0.124
181
180
0.119
221
220
0.116
0.13
Tolerance Of Inductors
SCDS 2D11
1.5 ~ 22uH ± 30%
SCDS3D11
2.7 ~ 39 uH ± 30%
SCDS 2D14
0.47 ~ 12H ± 30%
SCDS3D11HP
0.6 ~ 22 uH ± 30%
SCDS 2D18LD
2.2 ~ 47H ± 30%
SCDS3D16
1.0 ~ 100 uH ± 30%
SCDS 2D18HP
1.5 ~ 22H ± 30%
SCDS3D28
1.0 ~ 47 uH ± 30%
SCDS3D28LD
10 ~ 220 uH ± 30%
Tolerance: M = ±20% , T = ±30% , N =
+40
-20%
0.160
Packaging Specifications
Tape Dimensions
Tape Material
Reel Dimensions
Dimensions in mm
TYPE
Tape Dimensions
Reel Dimensions
Quantity
A0
B0
K0
D
E
W
P
P0
P2
A
B
C
D
PCS / REEL
SCDS 2D11
3.35
3.35
1.4
1.55
1.75
12
8
4
2
178
60
13
13.2
1000
SCDS 2D14
3.35
3.35
1.7
1.55
1.75
12
8
4
2
178
60
13
13.2
1000
SCDS 2D18
3.5
3.5
2.1
1.55
1.75
12
8
4
2
178
60
13
13.2
1000
SCDS 3D11
4.2
4.2
1.5
1.55
1.75
12
8
4
2
178
60
13
13.2
1000
SCDS 3D16
4.1
4.1
2.0
1.5
1.75
12
8
4
2
178
60
13
13.2
1000
SCDS 3D28
4.2
4.2
3.2
1.55
1.75
12
8
4
2
178
60
13
13.2
500
SCDS Series
Features
Applications
Magnetic shielded
AP Routers
STBs
Game consoles
LED lightings
DC/DC converters
SCDS 3D16T-XXXX-S-N
Recommended Pattern
Dimensions in mm
TYPE
SCDS3D16
Dimension in mm
A
B
C
D
E
TYPE
A
B
C
D
4+0
4+0
1.8+0
5.2 +0
1.0
SCDS3D16
4.6
1.6
1.4
4.6
SCDS 4D18 ~ 6D38
Recommended Pattern
Dimension in
TYPE
mm
Dimension in
A
B
C
+0
E
TYPE
A
B
C
+0
1.9
1.5
5.3
1.9
1.5
5.3
D
SCDS4D18
4.7 ± 0.3 4.7 ± 0.3
2.0
6.9
1.5
SCDS4D18
SCDS4D28
4.7 ± 0.3 4.7 ± 0.3
3.0+0
6.9+0
1.5
SCDS4D28
+0
+0
mm
SCDS4D40
4.7 ± 0.3 4.7 ± 0.3
6.9
1.5
SCDS4D40
1.9
1.5
5.3
SCDS5D18
5.7 ± 0.3 5.7 ± 0.3
2.0+0
8.2+0
2.0
SCDS5D18
2.15
2.0
6.3
5.7 ± 0.3 5.7 ± 0.3
+0
+0
2.0
SCDS5D28
2.15
2.0
6.3
+0
9.5
2.0
SCDS6D28
2.65
2.0
7.3
9.5+0
2.0
SCDS6D38
2.65
2.0
7.3
SCDS5D28
SCDS6D28
SCDS6D38
6.7 ± 0.3 6.7 ± 0.3
7+0
7+0
4
3.0
+0
3.0
4+0
8.2
Stamp
Inductance
(H)
RDC (mΩ) Max
Rated Current (A)
SCDS SCDS SCDS SCDS SCDS SCDS SCDS SCDS SCDS SCDS SCDS SCDS SCDS SCDS SCDS SCDS
3D16
4D18
4D28
4D40
45
5D18
5D28
6D28
38
15
24
6D38
3D16
4D18
4D28
4D40
1.72
5D18
5D28
6D28
2.80
3.50
3.50
2.50
3.00
3.40
2.60
3.00
1R0
1.0
1R2
1.2
1R5
1.5
1R8
1.8
2R0
2.0
2R2
2.2
2R5
2.5
2R6
2.6
2R7
2.7
3R0
3.0
3R3
3.3
85
3R6
3.6
90
3R9
3.9
4R1
4.1
4R2
4.2
31
2.20
4R3
4.3
41
2.5Typ
4R7
4.7
38
31
22
5R0
5.0
38
31
24
5R3
5.3
38
5R4
5.4
5R6
5.6
6R0
6.0
6R2
6.2
6R3
6.3
6R8
6.8
7R3
7.3
7R4
7.4
8R2
8.2
8R6
8.6
8R7
8.7
8R9
8.9
100
10
120
12
150
15
180
18
220
22
270
330
390
23.6
52
2.56
60
70
38
75
15
19.5
1.55
27.5
31.3
1.50
1.35
29.0
72
45
22
48
2.20
2.10
18
35
18
1.20
1.32
2.04
2.50
4.6
1.90
18
43.3
110
49.2
2.40
56
24
24
27
25
1.28
1.60
1.04
1.57
0.88
1.44
3.60
3.4
1.90
2.40
3.00
2.10
3.00
64.8
27
2.60
57
162
72.0
44
76
1.95
0.90
0.84
1.32
2.8
170
1.60
1.90
2.40
3.10
1.90
2.40
2.90
1.90
76
1.60
100.9
27
0.80
1.17
2.50
35
96
45
51
2.25
27
180
170
200
1.40
1.80
2.40
2.50
1.35
1.65
2.15
2.30
0.78
108.9
46
100
50
50
31
0.73
0.76
1.12
2.6
54
2.10
31
245
117.5
2.30
53
0.68
1.04
1.60
58
1.85
34
2.20
116
210
280
128.3
320
131.6
360
149.0
400
166.0
430
480
235.0
27
620
570
33
675
694
39
470
65
65
38
153
76
70
53
196
103
84
57
210
110
95
92
290
122
128
96
261.0
330
175
142
331.3
386
189
165
800
383.7
520
212
210
47
950
587.0
595
250
560
56
1080
624.5
665
680
68
1300
699.0
820
82
914.8
101
100
1020
121
120
151
150
181
180
221
220
331
1700
2000
150
1.25
124
295
210
270
0.55
0.61
1.00
0.56
0.84
1.20
1.30
1.70
2.00
1.10
1.20
1.55
0.50
0.76
1.70
0.97
1.10
1.40
0.48
0.72
1.60
0.85
1.00
1.32
0.40
0.41
0.70
1.50
0.80
0.90
1.20
1.30
109
0.35
0.35
124
0.32
0.32
0.58
0.75
0.85
1.05
1.20
0.56
0.65
0.75
0.97
138
1.10
0.30
0.50
0.57
0.70
0.86
238
1.00
150
0.28
0.48
0.54
0.62
0.80
305
0.95
277
202
0.26
0.41
0.50
0.58
0.73
0.85
840
978
355
304
234
0.24
0.35
0.43
0.52
0.65
0.75
463
390
324
0.32
0.41
0.46
0.60
1200
0.70
520
535
358
0.29
0.36
0.42
0.54
0.65
0.45
0.18
0.20
1270
2840
1350
0.15
1050
2000
1200
330
3400
391
390
3560
471
470
2500
561
560
3200
681
680
5200
1.8
1.6
1.4
0.27
1540
5500
3.50
0.95
155
105
3.80
2.60
22
105
6D38
0.24
0.22
0.29
0.20
0.28
1700
0.19
0.19
1800
0.18
0.18
0.08
0.15
1800
0.12
0.10
0.22
Measure Equipment:
Test Freq L:SCDS 3D16(100kHz/ 0.1V) , 4D28/ 4D40 (100kHz/ 1V) , SCDS 5D18/ 5D28/ 6D28/ 6D38 (10kHz/ 1V)
SCDS 4D18: 1.0~8.2H (7.96MHz/ 1V), 10~150H (100kHz/ 1V)
RDC:Chroma 16502
SCDS 3D16
1.5 ~ 220H ± 30%
SCDS 5D18
1.0 ~ 100H ± 30%
SCDS 4D18
1.0 ~ 150H ± 30%
SCDS 5D28
1.0 ~ 560H ± 30%
SCDS 4D28
1.2 ~ 680H ± 30%
SCDS 6D28
1.0 ~ 100H ± 30%
SCDS 4D40
2.2 ~ 22H ± 30%
SCDS 6D38
2.2 ~ 560uH ± 30%
Tolerance: M = ±20% , T = ±30% , N = +40-20%
Tape Dimensions
Reel Dimensions
Dimensions in mm
TYPE
Tape Dimensions
Reel Dimensions
Quantity
A0
B0
K0
D
E
W
P
P0
P2
A
B
C
D
PCS / REEL
SCDS 3D16
4.1
4.1
2.0
1.5
1.75
12
8
4
2
178
60
13
13.2
1000
SCDS 4D18
5.3
5.3
2.4
1.5
1.75
12
8
4
2
330
100
13
13.4
2000
SCDS 4D28
5.3
5.3
3.4
1.5
1.75
12
8
4
2
330
100
13
13.4
2000
SCDS 4D40
5.35
5.35
4.1
1.55
1.75
12
8
4
2
330
100
13
13.4
1000
SCDS 5D18
6.2
6.2
2.2
1.5
1.75
16
12
4
2
330
100
13
13.4
2000
SCDS 5D28
6.2
6.2
3.2
1.5
1.75
16
12
4
2
330
100
13
13.4
2000
SCDS 6D28
7.25
7.25
3.35
1.55
1.75
16
12
4
2
330
100
13
16.0
1500
SCDS 6D38
7.1
7.1
4.1
1.55
1.75
16
12
4
2
330
100
13
16.0
1000
Tape Dimensions
Tape Material
Reel Dimensions
Dimensions in mm
TYPE
Tape Dimensions
Reel Dimensions
Quantity
A0
B0
K0
D
E
W
P
P0
P2
A
B
C
D
PCS / REEL
SCDS 3D16
4.1
4.1
2.0
1.5
1.75
12
8
4
2
178
60
13
13.2
1000
SCDS 4D18
5.3
5.3
2.4
1.5
1.75
12
8
4
2
330
100
13
13.4
2000
SCDS 4D28
5.3
5.3
3.4
1.5
1.75
12
8
4
2
330
100
13
13.4
2000
SCDS 4D40
5.35
5.35
4.1
1.55
1.75
12
8
4
2
330
100
13
13.4
1000
SCDS 5D18
6.2
6.2
2.2
1.55
1.75
16
12
4
2
330
100
13
13.4
1500
SCDS 5D28
6.2
6.2
3.1
1.55
1.75
16
12
4
2
330
100
13
17.4
1500
SCDS 6D28
7.25
7.25
3.35
1.55
1.75
16
12
4
2
330
100
13
17.4
1500
SCDS 6D38
7.1
7.1
4.1
1.55
1.75
16
12
4
2
330
100
13
17.4
1000
SCDS Series
Features
Applications
Magnetic shielded
AP Routers
STBs
Game consoles
LED lightings
DC/DC converters
SCDS 73/ 74
Recommended Pattern
Dimension in mm
Dimension in mm
TYPE
A
B
C
D
TYPE
A
B
C
SCDS73
7.3±0.2
7.3±0.2
3.4+0
1.8
SCDS73
8.4
4.4
2.2
SCDS74
7.3±0.2
7.3±0.2
4.5+0
1.8
SCDS74
8.4
4.4
2.2
SCDS 103R/ 104R/ 105R
Recommended Pattern
Dimensions in mm
TYPE
Dimension in mm
A
B
+0
SCDS103R 10.3
+0
SCDS104R 10.3
+0
SCDS105R 10.3
C
+0
10.5
+0
10.5
+0
10.5
+0
3.1
+0
4
+0
5.1
D
E
F
1.2 7.7 3.0
1.2 7.7 3.0
1.2 7.7 3.0
TYPE
A
B
C
+0
SCDS103R
1.6
7.3
3.2
+0
SCDS104R
1.6
7.3
3.2
+0
SCDS105R
1.6
7.3
3.2
G
13.5
13.5
13.5
SCDS 124/125/127
Recommended Pattern
Dimensions in mm
TYPE
A
B
12.5
+0
SCDS125
12.5
+0
SCDS127
12.5+0
SCDS124
Dimensions in mm
C
+0
12.5
+0
E
TYPE
A
B
C
5
7.6
SCDS124
13
7
5.4
12.5
+0
6
5
7.6
SCDS125
13
7
5.4
12.5+0
8+0
5
7.6
SCDS127
13
7
5.4
+0
4.5
D
RDC (mΩ) Max
Stamp
Inductance
(H)
R80
1R0
0.8
1.0
1R2
1R5
1.2
1.5
30
5.8
7.0
8.0
1R8
2R2
1.8
2.2
30
25
25
9.5
10.5
11
11.5
2R4
2R5
2.4
2.5
2R7
3R3
2.7
3.3
3R5
3R8
3.5
3.8
3R9
4R7
3.9
4.7
5R2
5R6
5.2
5.6
6R1
6R4
6.1
6.4
6R8
7R0
6.8
7.0
7R6
8R2
7.6
8.2
100
120
10
12
72
98
49
58
150
180
15
18
130
140
81
91
220
270
22
27
190
210
110
150
330
390
33
39
240
320
170
230
470
560
47
56
360
470
260
350
680
820
68
82
520
690
101
121
100
120
151
181
SCDS
73
SCDS
74
SCDS
103R
SCDS
104R
SCDS
105R
SCDS
124
SCDS
125
SCDS
127
4.3
7.5
11.5
10.5
40
30
35
13
10.4
15
15
13.5
13.5
13
35
30
18
12.3
15
18
18
15.8
22
27
17.6
18
60
45
35
27
27
18
23
20.0
33
35
26
33
28
38
25
27
21.6
24.3
91
50
70
41
46
50
57
30
34
27.0
39.2
73
90
61
69
66
80
36
51
43.2
45.9
202
93
128
84
106
97
132
57
68
64.8
72.9
299
128
213
130
149
150
190
75
110
100
110
380
430
213
280
201
227
220
260
120
140
140
160
790
890
610
660
304
253
303
308
380
160
170
220
250
150
180
1270
1450
880
980
506
370
419
530
620
230
290
280
350
201
221
200
220
1650
1170
756
756
500
700
400
390
271
331
270
330
2310
2620
1640
1860
1090
672
812
876
990
460
510
560
640
391
471
390
470
2940
4180
2850
3010
1600
953
1289
690
770
700
980
561
681
560
680
4670
5730
3620
4630
1430
1599
860
1200
1070
1460
821
102
820
1000
6540
9440
5200
6000
1768
1989
1340
1530
1640
1820
20.0
2100
Operating temperature range-40℃~105℃(Including self - temperature rise)
Isat for Inductance drop 35% from its value without current
Measure Equipment:
L:Agilent/ E4980 or HP4284A (under 1MHz), HP4285A (over 1MHz)
RDC:Chroma 16502
Rated Current:HP4284+42841A or WK3260B+WK3265B
25
Isat (A)
Stamp
Inductance
(H)
R80
1R0
0.8
1.0
1R2
1R5
1.2
1.5
4.00
5.00
10.
10.5
9.80
9.50
1R8
2R2
1.8
2.2
4.00
4.00
3.50
8.5
7.5
9.25
8.00
2R4
2R5
2.4
2.5
2R7
3R3
2.7
3.3
3R5
3R8
3.5
3.8
3R9
4R7
3.9
4.7
5R2
5R6
5.2
5.6
6R1
6R4
6.1
6.4
6R8
7R0
6.8
7.0
7R6
8R2
7.6
8.2
100
120
10
12
1.68
1.52
1.84
1.71
150
180
15
18
1.33
1.20
1.47
1.31
220
270
22
27
1.07
0.96
1.23
1.12
330
390
33
39
0.91
0.77
0.96
0.91
470
560
47
56
0.76
0.68
0.88
0.75
680
820
68
82
0.61
0.57
101
121
100
120
151
181
SCDS
73
SCDS
74
SCDS
103R
SCDS
104R
SCDS
105R
SCDS
124
SCDS
125
SCDS
127
13.5
11
8.00
7.5
3.70
3.50
3.50
6.0
7.8
6.50
8.00
7.50
7.50
6.0
3.00
4.65
5.7
6.40
6.50
5.70
7.60
6.80
5.5
5.0
6.60
5.8
2.00
2.50
3.84
5.0
4.8
5.40
4.90
6.20
4.5
4.85
3.18
4.4
4.45
4.00
4.50
4.00
4.00
3.50
5.40
4.90
2.60
3.6
3.5
3.60
3.20
3.20
3.10
3.30
3.00
4.50
3.90
2.9
2.5
2.95
2.70
2.90
2.80
2.80
2.30
3.60
3.40
1.74
2.3
2.1
2.50
2.30
2.70
2.10
2.10
2.00
3.00
2.75
1.43
2.1
1.6
2.00
1.90
1.90
1.80
1.80
1.70
2.50
2.35
0.69
0.61
1.5
1.35
1.65
1.50
1.50
1.30
1.50
1.40
2.10
1.95
0.50
0.49
0.60
0.52
1.35
1.35
1.28
1.20
1.10
1.30
1.10
1.70
1.60
150
180
0.43
0.39
0.46
0.42
1.15
1.12
1.04
0.95
0.85
1.00
0.90
1.42
1.30
201
221
200
220
0.35
0.36
0.92
0.92
0.94
0.80
0.80
1.16
271
331
270
330
0.32
0.28
0.34
0.32
0.70
0.84
0.75
0.60
0.50
0.75
0.68
1.06
0.95
391
471
390
470
0.26
0.24
0.29
0.26
0.50
0.70
0.60
0.65
0.58
0.88
0.79
561
681
560
680
0.22
0.19
0.23
0.22
0.54
0.52
0.54
0.48
0.73
0.67
821
102
820
1000
0.18
0.16
0.20
0.18
0.50
0.48
0.43
0.40
0.60
0.55
5.90
0.40
1.5 ~ 1000uH ± 20%
SCDS 73
SCDS 124
3.3 ~ 330uH ±20%
SCDS 74
1.5 ~ 1000uH ± 20%
SCDS 125
3.3 ~ 1000uH ± 20%
SCDS 103R
4.7~47uH ± 30%
1.2 ~ 7.6uH +40-20%
SCDS 104R
1.0 ~ 470uH ± 30%
SCDS 105R
0.8 ~ 1000uH ± 30%
SCDS 127
SCDS 127
5.00
10 ~ 1000uH ± 20%
Curves of SCDS Series
Test Instruments:HP4294 Impedance / Material Analyzer
SCDS73
SCDS74
SCDS104R
SCDS124
SCDS125
SCDS127
Tape Dimensions
Tape Material
Reel Dimensions
Dimensions in mm
TYPE
Tape Dimensions
Reel Dimensions
Quantity
A0
B0
K0
D
E
W
P
P0
P2
A
B
C
D
PCS / REEL
SCDS 73
7.6
7.6
3.6
1.55
1.75
16
12
4
2
330
100
13
16.0
1600
SCDS 74
7.6
7.6
5.0
1.55
1.75
16
12
4
2
330
100
13
16.0
1000
SCDS 103R
10.6
10.75
4.2
1.55
1.75
24
16
4
2
300
100
13
24.4
1000
SCDS 104R
10.6
10.75
4.2
1.5
1.75
24
16
4
2
330
100
13
24.4
1000
SCDS 105R
10.6
10.6
5.0
1.5
1.75
24
16
4
2
330
100
13
24.4
500
SCDS 124
13.0
12.8
5.1
1.55
1.75
24
16
4
2
330
100
13
24.4
500
SCDS 125
12.6
12.6
6.7
1.55
1.75
24
16
4
2
330
100
13
24.4
600
SCDS 127
12.6
12.6
8.7
1.55
1.75
24
16
4
2
330
100
13
24.4
500
SCDS Series
Features
Applications
Magnetic shielded
AP Routers
STBs
Game consoles
LED lightings
DC/DC converters
Shapes and Dimensions
Recommended Pattern
Dimension in mm
Dimension in mm
TYPE
A
B
C
D
E
TYPE
A
B
C
D
SCDS8D43
8.3+0
8.3+0
4.5+0
2.5
6.3
SCDS8D43
10.1
6.1
2.0
2.8
SMD Shielded Power Inductors – SCDS Series
Electrical Characteristics
Part Number
Inductance
Test Frequency
Tolerance
RDC
Rated Current
(H)
(kHz)
(mΩ) Max
(A)
SCDS8D43T-3R3□-N
3.3
100
30
19
5.7
SCDS8D43T-4R7□-N
4.7
100
30
22
5.6
SCDS8D43T-6R8□-N
6.8
100
30
25
4.4
SCDS8D43T-100□-N
10
100
30
36
4.0
SCDS8D43T-150□-N
15
100
30
53
2.9
SCDS8D43T-220□-N
22
100
30
75
2.4
SCDS8D43T-470□-N
47
100
30
150
1.8
SCDS8D43T-680□-N
68
100
30
240
1.5
SCDS8D43T-101□-N
100
100
30
353
1.1
Note: When ordering, please specify tolerance code. Tolerance: T=±30%
Rated current for Inductance drop 35% from its value with current
Measure Equipment:
L:HP4284A 100kHz/ 1V
RDC:Chroma 16502
Rated current:HP4284+42841A
Tape Dimensions
Reel Dimensions
Dimensions in mm
TYPE
SCDS 8D43
Tape Dimensions
Reel Dimensions
Quantity
A0
B0
K0
D
E
W
P
P0
P2
A
B
C
D
PCS / REEL
8.4
9.9
4.8
1.55
1.75
24
12
4
2
330
100
13
24.4
1000
Tape Dimensions
Tape Material
Reel Dimensions
Dimensions in mm
TYPE
SCDS 8D43
Tape Dimensions
Reel Dimensions
Quantity
A0
B0
K0
D
E
W
P
P0
P2
A
B
C
D
PCS / REEL
8.4
9.9
4.8
1.55
1.75
24
12
4
2
330
100
13
24.4
1000
很抱歉,暂时无法提供与“SCDS105R-221M-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.75940
- 10+1.39640
- 30+1.24089
