MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
CD11GN series
Endurance:+130°C 1,000~2,000 hours;+105°C 8,000~12,000 hours
Withstand high temperature,miniaturized,long life
CD11GN 130 C
1808
Suitable for output circuit and input circuit of LED driving power.
RoHS Compliant
SPECIFICATIONS
Items
Characteristics
Category Temperature Range
-40~+130°C(160~ 450 V dc )
Rated Voltage Range
160~500 V dc
Capacitance Tolerance
±20%(M)
-40~+105°C(500 Vd c )
(at 20°C,120Hz)
160~400 V dc
450~500 V dc
I≤0.02CV+10μA
I≤0.03CV+10μA
Leakage Current
Where, I: Max.leakage current (μA),C:Nominal capacitance (μF),
V: Rated voltage (V)
(at 20°C after 2 minutes)
Rated Voltage(V dc )
160
200
250
350
400
450
500
tanδ (max.)
0.15
0.15
0.15
0.20
0.20
0.20
0.24
160
200
250
350
400
450
500
Z(-25°C)/Z(+20°C)
3
3
3
5
5
6
6
Z(-40°C)/Z(+20°C)
6
6
6
6
6
9
15
Dissipation Factor (tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
(at 20°C,120Hz)
(at 120Hz)
The specifications listed below shall be met when the capacitors are restored to 20°C after DC voltage plus rated ripple
current is applied for a specified period of time at 130°C or 105°C,the peak voltage shall not exceed the rated voltage.
Endurance
Capacitance Change
≤±20% of the initial value
D.F. (tanδ)
≤200% of the initial specified value
Leakage Current
≤The initial specified value
Case Dia.
(mm)
Ø D=6.3
ØD≥8
130°C
Load life (hours)
160~450WV
1,000
2,000
105°C
Load life (hours)
160~450WV
8,000
12,000
500WV
10,000
The following specifications shall be satisfied when the capacitors are restored to 20°C after leaving them under no load
at 105°C for 1,000 hours.
Shelf Life
Capacitance Change
D.F. (tanδ)
Leakage Current
DIMENSIONS[mm]
Sleeve(Dark Green)
Ød
ØD'
F±0.5
L'
4min.
15min.
( Ø 6.3~ Ø 22)
ØD
6.3
Ød
0.5
F
ØD'
L'
2.5
8
0.5
0.6
3.5
10
12.5
16
18
22
0.6
0.6
0.8
0.8
0.8
5.0
5.0
7.5
7.5
10
Ø D+0.5max.
L+2max.
PART NUMBERING SYSTEM
E
GN 2G
M 3R3 F20 O- -
T
Sleeve Code: “C” for PVC, “T” for PET
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
RATED RIPPLE CURRENT MULTIPLIERS
Frequency correction factor for ripple current
Freq.(Hz)
120
1k
10k
100k
Cap.
很抱歉,暂时无法提供与“EGN2GM100G16OT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.89975
- 50+0.71313
- 200+0.61085
- 400+0.53005
- 2400+0.47523
- 5000+0.44771
