EGN2GM470L25OT
EGN2GM470L25OT
    AISHI(艾华集团)
    插件,D16xL25mm
    直插铝电解电容 插件,D16xL25mm 47µF ±20% Ф16.00 x 25.00mm 400V 455mA 2000Hrs@130℃
EGN2GM470L25OT 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS CD11GN series Endurance:+130°C 1,000~2,000 hours;+105°C 8,000~12,000 hours Withstand high temperature,miniaturized,long life CD11GN 130 C 1808 Suitable for output circuit and input circuit of LED driving power. RoHS Compliant SPECIFICATIONS Items Characteristics Category Temperature Range -40~+130°C(160~ 450 V dc ) Rated Voltage Range 160~500 V dc Capacitance Tolerance ±20%(M) -40~+105°C(500 Vd c ) (at 20°C,120Hz) 160~400 V dc 450~500 V dc I≤0.02CV+10μA I≤0.03CV+10μA Leakage Current Where, I: Max.leakage current (μA),C:Nominal capacitance (μF), V: Rated voltage (V) (at 20°C after 2 minutes) Rated Voltage(V dc ) 160 200 250 350 400 450 500 tanδ (max.) 0.15 0.15 0.15 0.20 0.20 0.20 0.24 Rated Voltage(V dc ) 160 200 250 350 400 450 500 Z(-25°C)/Z(+20°C) 3 3 3 5 5 6 6 Z(-40°C)/Z(+20°C) 6 6 6 6 6 9 15 Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) (at 20°C,120Hz) (at 120Hz) The specifications listed below shall be met when the capacitors are restored to 20°C after DC voltage plus rated ripple current is applied for a specified period of time at 130°C or 105°C,the peak voltage shall not exceed the rated voltage. Endurance Capacitance Change ≤±20% of the initial value D.F. (tanδ) ≤200% of the initial specified value Leakage Current ≤The initial specified value Case Dia. (mm) Ø D=6.3 ØD≥8 130°C Load life (hours) 160~450WV 1,000 2,000 105°C Load life (hours) 160~450WV 8,000 12,000 500WV 10,000 The following specifications shall be satisfied when the capacitors are restored to 20°C after leaving them under no load at 105°C for 1,000 hours. Shelf Life Capacitance Change ≤±20% of the initial value D.F. (tanδ) ≤200% of the initial specified value Leakage Current ≤200% of the initial specified value DIMENSIONS[mm] Sleeve(Dark Green) Ød ØD' F±0.5 L' 4min. 15min. ( Ø 6.3~ Ø 22) ØD 6.3 Ød 0.5 F ØD' L' 2.5 8 0.5 0.6 3.5 10 12.5 16 18 22 0.6 0.6 0.8 0.8 0.8 5.0 5.0 7.5 7.5 10 Ø D+0.5max. L+2max. PART NUMBERING SYSTEM E GN 2G M 3R3 F20 O- - T Sleeve Code: “C” for PVC, “T” for PET Terminal code Size code Capacitance code Capacitance tolerance code Voltage code Series code Category code RATED RIPPLE CURRENT MULTIPLIERS Frequency correction factor for ripple current Freq.(Hz) 120 1k 10k 100k Cap.
EGN2GM470L25OT 价格&库存
很抱歉,暂时无法提供与“EGN2GM470L25OT”相匹配的价格&库存,您可以联系我们找货
