MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
CD11GHS series
Upgrade
Upgrade for CD11GH Series, longer life, better performance, cost-effective
CD11GH
CD11GHS
CD11GHS 105 C
1808
Endurance: +105°C 6,000 hours
Suitable for electronic ballast and electronic energy saving lamp.
RoHS Compliant
SPECIFICATIONS
Items
Characteristics
Category Temperature Range
-40~+105°C
Rated Voltage Range
140~500 V dc
Capacitance Tolerance
±20%(M)
(at 20°C,120Hz)
140~400 V dc
450~500 V dc
I≤0.02CV+10μA
I≤0.03CV+10μA
Leakage Current
Where, I: Max.leakage current (μA),C:Nominal capacitance (μF),
V: Rated voltage (V)
(at 20°C after 2 minutes)
Rated Voltage(V dc )
140
160
200
250
315
350
400
450
500
tanδ (max.)
0.15
0.15
0.15
0.15
0.20
0.20
0.20
0.20
0.24
140
160
200
250
315
350
400
450
500
Z(-25°C)/Z(+20°C)
3
3
3
3
5
5
5
6
6
Z(-40°C)/Z(+20°C)
6
6
6
6
6
6
6
9
15
Dissipation Factor (tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
(at 20°C,120Hz)
(at 120Hz)
The specifications listed below shall be met when the capacitors are restored to 20°C after DC voltage plus rated ripple
current is applied for 6,000 hours at 105°C,the peak voltage shall not exceed the rated voltage.
Endurance
Capacitance Change
≤±20% of the initial value
D.F. (tanδ)
≤200% of the initial specified value
Leakage Current
≤The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20°C after leaving them under no load at
105°C for 1,000 hours.
Shelf Life
Capacitance Change
D.F. (tanδ)
Leakage Current
DIMENSIONS[mm]
Ød
ØD'
F±0.5
L'
4min.
15min.
( Ø 6.3~ Ø 22)
ØD
6.3
Ød
0.5
F
ØD'
L'
2.5
8
0.5
0.6
3.5
10
12.5
13
16
18
22
0.6
0.6
0.6
0.8
0.8
0.8
5.0
5.0
5.0
7.5
7.5
10
Ø D+0.5max.
L+2max.
Radial Type
Sleeve(Brown)
PART NUMBERING SYSTEM
E
GS 2G
M 3R3 F12 O- -
T
Sleeve Code: “C” for PVC, “T” for PET
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
RATED RIPPLE CURRENT MULTIPLIERS
Frequency correction factor for ripple current
Freq.(Hz)
Rated voltage(Vdc)
140~500
120
1k
10k
100k
0.50
0.80
0.90
1.00
118
CD11GHS series
STANDARD RATINGS (Rated ripple current: mArms/105°C 100kHz)
WV
(Vdc)
140(2A)
Cap
(µF)
Size
ΦD×L(mm)
10
Rated ripple
current
PartNumber
6.3×12
100
EGS2AM100E12OT
15
6.3×12
125
EGS2AM150E12OT
22
8×12
250
EGS2AM220F12OT
33
10×12
365
EGS2AM330G12OT
47
8×20
430
EGS2AM470F20OT
68
10×20
520
EGS2AM680G20OT
100
12.5×16
650
EGS2AM101W16OT
150
12.5×25
750
EGS2AM151W25OT
220
16×20
850
EGS2AM221L20OT
6.3×7
34
EGS2CM010E07OT
6.3×9
36
EGS2CM010E09OT
6.3×7
38
EGS2CM1R5E07OT
6.3×9
45
EGS2CM1R5E09OT
6.3×7
49
EGS2CM1R8E07OT
6.3×9
50
EGS2CM1R8E09OT
6.3×7
53
EGS2CM2R2E07OT
6.3×9
56
EGS2CM2R2E09OT
6.3×7
58
EGS2CM2R8E07OT
6.3×9
62
EGS2CM2R8E09OT
6.3×7
62
EGS2CM3R3E07OT
6.3×9
67
EGS2CM3R3E09OT
6.3×7
68
EGS2CM4R7E07OT
6.3×9
72
EGS2CM4R7E09OT
6.3×9
75
EGS2CM5R6E09OT
6.3×12
79
EGS2CM5R6E12OT
6.3×9
84
EGS2CM6R8E09OT
6.3×12
89
EGS2CM6R8E12OT
6.3×12
120
EGS2CM8R2E12OT
8×9
135
EGS2CM8R2F09OT
8×9
165
EGS2CM100F09OT
8×12
206
EGS2CM100F12OT
8×9
215
EGS2CM150F09OT
8×12
230
EGS2CM150F12OT
8×12
306
EGS2CM220F12OT
8×16
340
EGS2CM220F16OT
10×12
400
EGS2CM330G12OT
10×16
425
EGS2CM330G16OT
10×16
460
EGS2CM470G16OT
10×20
500
EGS2CM470G20OT
10×20
560
EGS2CM680G20OT
12.5×16
570
EGS2CM680W16OT
12.5×20
665
EGS2CM820W20OT
12.5×20
720
EGS2CM101W20OT
12.5×25
740
EGS2CM101W25OT
12.5×25
780
EGS2CM151W25OT
16×20
780
EGS2CM151L20OT
220
16×25
980
EGS2CM221L25OT
330
18×30
1145
EGS2CM331M30OT
6.3×7
35
EGS2DM010E07OT
6.3×9
38
EGS2DM010E09OT
6.3×7
49
EGS2DM1R5E07OT
6.3×9
50
EGS2DM1R5E09OT
6.3×7
50
EGS2DM1R8E07OT
6.3×9
54
EGS2DM1R8E09OT
6.3×7
55
EGS2DM2R2E07OT
6.3×9
60
EGS2DM2R2E09OT
6.3×7
61
EGS2DM2R8E07OT
6.3×9
68
EGS2DM2R8E09OT
6.3×7
68
EGS2DM3R3E07OT
6.3×9
74
EGS2DM3R3E09OT
6.3×9
82
EGS2DM4R7E09OT
6.3×12
90
EGS2DM4R7E12OT
6.3×12
95
EGS2DM5R6E12OT
8×9
95
EGS2DM5R6F09OT
1
1.5
1.8
2.2
2.8
3.3
4.7
5.6
6.8
160(2C)
8.2
10
15
22
33
47
68
82
100
150
1
1.5
1.8
2.2
200(2D)
2.8
3.3
4.7
5.6
WV
(Vdc)
Cap
(µF)
6.8
8.2
10
15
22
200(2D)
33
47
68
82
100
150
1
1.5
1.8
2.2
2.8
3.3
4.7
5.6
6.8
250(2E)
8.2
10
15
22
33
47
68
82
100
150
Size
ΦD×L(mm)
Rated ripple
current
PartNumber
8×9
105
EGS2DM6R8F09OT
8×12
120
EGS2DM6R8F12OT
8×9
150
EGS2DM8R2F09OT
8×12
160
EGS2DM8R2F12OT
8×9
170
EGS2DM100F09OT
8×12
185
EGS2DM100F12OT
8×12
225
EGS2DM150F12OT
8×16
250
EGS2DM150F16OT
8×16
360
EGS2DM220F16OT
10×16
400
EGS2DM220G16OT
10×16
425
EGS2DM330G16OT
10×20
450
EGS2DM330G20OT
10×20
550
EGS2DM470G20OT
12.5×16
550
EGS2DM470W16OT
12.5×20
635
EGS2DM680W20OT
12.5×25
700
EGS2DM680W25OT
12.5×20
705
EGS2DM820W20OT
12.5×25
735
EGS2DM101W25OT
16×20
735
EGS2DM101L20OT
16×25
855
EGS2DM151L25OT
16×30
920
EGS2DM151L30OT
6.3×7
36
EGS2EM010E07OT
6.3×9
40
EGS2EM010E09OT
6.3×7
51
EGS2EM1R5E07OT
6.3×9
54
EGS2EM1R5E09OT
6.3×7
55
EGS2EM1R8E07OT
6.3×9
59
EGS2EM1R8E09OT
6.3×7
64
EGS2EM2R2E07OT
6.3×9
71
EGS2EM2R2E09OT
6.3×7
71
EGS2EM2R8E07OT
6.3×9
75
EGS2EM2R8E09OT
6.3×9
78
EGS2EM3R3E09OT
6.3×12
83
EGS2EM3R3E12OT
6.3×12
91
EGS2EM4R7E12OT
8×9
97
EGS2EM4R7F09OT
8×12
102
EGS2EM4R7F12OT
8×9
95
EGS2EM5R6F09OT
8×12
105
EGS2EM5R6F12OT
8×9
105
EGS2EM6R8F09OT
8×12
109
EGS2EM6R8F12OT
8×9
120
EGS2EM8R2F09OT
8×12
132
EGS2EM8R2F12OT
8×12
170
EGS2EM100F12OT
8×16
210
EGS2EM100F16OT
8×16
295
EGS2EM150F16OT
10×12
295
EGS2EM150G12OT
8×16
360
EGS2EM220F16OT
10×16
400
EGS2EM220G16OT
10×20
480
EGS2EM330G20OT
12.5×16
480
EGS2EM330W16OT
12.5×16
560
EGS2EM470W16OT
12.5×20
627
EGS2EM470W20OT
12.5×25
675
EGS2EM680W25OT
16×20
675
EGS2EM680L20OT
16×20
730
EGS2EM820L20OT
16×25
760
EGS2EM820L25OT
16×20
780
EGS2EM101L20OT
16×25
820
EGS2EM101L25OT
16×30
930
EGS2EM151L30OT
18×25
930
EGS2EM151M25OT
119
CD11GHS series
STANDARD RATINGS(Rated ripple current: mArms/105°C 100kHz)
315(2F)
Cap
(µF)
PartNumber
6.3×9
71
EGS2FM2R2E09OT
3.3
6.3×9
78
EGS2FM3R3E09OT
4.7
6.3×12
95
EGS2FM4R7E12OT
5.6
8×9
100
EGS2FM5R6F09OT
6.8
8×9
110
EGS2FM6R8F09OT
8.2
8×12
130
EGS2FM8R2F12OT
10
10×12
215
EGS2FM100G12OT
15
10×16
325
EGS2FM150G16OT
22
10×20
420
EGS2FM220G20OT
33
12.5×20
540
EGS2FM330W20OT
47
12.5×20
630
EGS2FM470W20OT
6.3×7
52
EGS2VM010E07OT
6.3×9
58
EGS2VM010E09OT
6.3×7
62
EGS2VM1R5E07OT
6.3×9
68
EGS2VM1R5E09OT
6.3×9
74
EGS2VM1R8E09OT
6.3×12
80
6.3×9
1.5
1.8
2.2
2.8
3.3
4.7
5.6
6.8
8.2
10
15
22
33
47
68
82
100
1
1.5
1.8
2.2
400(2G)
Rated ripple
current
2.2
1
350(2V)
Size
ΦD×L(mm)
2.8
3.3
4.7
5.6
6.8
WV
(Vdc)
Cap
(µF)
Size
ΦD×L(mm)
Rated ripple
current
PartNumber
10×12
200
EGS2GM8R2G12OT
10×16
220
EGS2GM8R2G16OT
10×12
230
EGS2GM100G12OT
10×16
252
EGS2GM100G16OT
12
10×16
262
EGS2GM120G16OT
15
10×20
300
EGS2GM150G20OT
12.5×16
370
EGS2GM220W16OT
12.5×20
400
EGS2GM220W20OT
12.5×25
520
EGS2GM330W25OT
13×20
465
EGS2GM330K20OT
16×20
520
EGS2GM330L20OT
47
16×20
580
EGS2GM470L20OT
56
16×25
650
EGS2GM560L25OT
16×30
760
EGS2GM680L30OT
18×25
760
EGS2GM680M25OT
82
18×25
810
EGS2GM820M25OT
EGS2VM1R8E12OT
100
18×30
920
EGS2GM101M30OT
85
EGS2VM2R2E09OT
150
18×40
1280
EGS2GM151M40OT
6.3×12
90
EGS2VM2R2E12OT
6.3×9
60
EGS2WM010E09OT
8×9
101
EGS2VM2R8F09OT
6.3×12
65
EGS2WM010E12OT
8×12
106
EGS2VM2R8F12OT
8×9
70
EGS2WM1R5F09OT
8×9
106
EGS2VM3R3F09OT
8×12
75
EGS2WM1R5F12OT
8×12
110
EGS2VM3R3F12OT
8×9
81
EGS2WM1R8F09OT
8×9
112
EGS2VM4R7F09OT
8×12
90
EGS2WM1R8F12OT
8×12
120
EGS2VM4R7F12OT
8×9
93
EGS2WM2R2F09OT
8×12
130
EGS2VM5R6F12OT
8×12
103
EGS2WM2R2F12OT
8×16
150
EGS2VM5R6F16OT
8×9
105
EGS2WM2R8F09OT
8×12
160
EGS2VM6R8F12OT
8×12
115
EGS2WM2R8F12OT
8×16
170
EGS2VM6R8F16OT
8×12
116
EGS2WM3R3F12OT
8×16
190
EGS2VM8R2F16OT
8×16
128
EGS2WM3R3F16OT
8×20
230
EGS2VM100F20OT
8×12
130
EGS2WM4R7F12OT
10×12
210
EGS2VM100G12OT
8×16
140
EGS2WM4R7F16OT
10×16
280
EGS2VM150G16OT
10×12
150
EGS2WM5R6G12OT
10×20
310
EGS2VM150G20OT
10×16
162
EGS2WM5R6G16OT
10×20
385
EGS2VM220G20OT
10×12
170
EGS2WM6R8G12OT
12.5×16
400
EGS2VM220W16OT
10×16
180
EGS2WM6R8G16OT
12.5×20
515
EGS2VM330W20OT
10×16
210
EGS2WM8R2G16OT
12.5×25
535
EGS2VM330W25OT
10×20
230
EGS2WM8R2G20OT
16×20
650
EGS2VM470L20OT
10×16
235
EGS2WM100G16OT
16×25
760
EGS2VM680L25OT
10×20
250
EGS2WM100G20OT
18×20
760
EGS2VM680M20OT
12.5×16
320
EGS2WM150W16OT
16×30
910
EGS2VM820L30OT
12.5×20
350
EGS2WM150W20OT
18×25
910
EGS2VM820M25OT
12.5×20
425
EGS2WM220W20OT
16×30
960
EGS2VM101L30OT
12.5×25
450
EGS2WM220W25OT
18×25
960
EGS2VM101M25OT
33
16×20
510
EGS2WM330L20OT
6.3×7
63
EGS2GM010E07OT
47
16×25
640
EGS2WM470L25OT
6.3×9
70
EGS2GM010E09OT
68
18×25
760
EGS2WM680M25OT
6.3×9
72
EGS2GM1R5E09OT
82
18×30
860
EGS2WM820M30OT
6.3×12
78
EGS2GM1R5E12OT
100
18×35
920
EGS2WM101M35OT
6.3×9
80
EGS2GM1R8E09OT
150
18×45
1100
EGS2WM151M45OT
6.3×12
85
EGS2GM1R8E12OT
12.5×20
259
EGS2HM100W20OT
6.3×9
85
EGS2GM2R2E09OT
12.5×25
272
EGS2HM100W25OT
6.3×12
90
EGS2GM2R2E12OT
12.5×25
356
EGS2HM150W25OT
8×12
105
EGS2GM2R2F12OT
16×20
356
EGS2HM150L20OT
8×9
105
EGS2GM2R8F09OT
12.5×35
453
EGS2HM220W35OT
8×12
110
EGS2GM2R8F12OT
16×25
453
EGS2HM220L25OT
8×9
110
EGS2GM3R3F09OT
33
18×25
567
EGS2HM330M25OT
8×12
120
EGS2GM3R3F12OT
47
18×30
713
EGS2HM470M30OT
8×9
125
EGS2GM4R7F09OT
56
18×30
770
EGS2HM560M30OT
8×12
140
EGS2GM4R7F12OT
18×35
900
EGS2HM680M35OT
8×12
150
EGS2GM5R6F12OT
22×35
1000
EGS2HM680O35OT
10×12
160
EGS2GM5R6G12OT
82
22×35
1150
EGS2HM820O35OT
8×12
165
EGS2GM6R8F12OT
100
22×35
1400
EGS2HM101O35OT
10×12
180
EGS2GM6R8G12OT
8.2
10
22
400(2G)
33
68
1
1.5
1.8
2.2
2.8
3.3
4.7
5.6
450(2W)
6.8
8.2
10
15
22
10
15
22
500(2H)
68
120
Radial Type
WV
(Vdc)
很抱歉,暂时无法提供与“EGS2EM2R2E09OT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.20801
- 200+0.16244
- 1000+0.13716
- 2000+0.12204
- 10000+0.10887
- 20000+0.10185
- 国内价格
- 20+0.42460
- 100+0.25320
- 400+0.17720
- 1000+0.12660
- 2000+0.12030
- 10000+0.11140
