MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
CD11GES series
Miniaturized
Endurance: +130°C 3,000 hours +105°C 12,000 hours
Withstand high temperature 130°C, miniaturized and long life
CD11GE
CD11GES 130 C
1808
CD11GES
Suitable for output circuit and input circuit of LED driving power, electronic
ballast and electronic energy saving lamp.
RoHS Compliant
SPECIFICATIONS
Items
Characteristics
Category Temperature Range
-40~+130°C(160~ 450 V dc )
Rated Voltage Range
160~500 V dc
Capacitance Tolerance
±20%(M)
(at 20°C,120Hz)
160~400 V dc
Leakage Current
-40~+105°C(500 V dc )
450~500 V dc
I≤0.02CV+10μA
I≤0.03CV+10μA
Where, I: Max.leakage current (μA),C:Nominal capacitance (μF),
V: Rated voltage (V)
(at 20°C after 2 minutes)
Rated Voltage(V dc )
160
200
250
350
400
450
500
tanδ (max.)
0.15
0.15
0.15
0.20
0.20
0.20
0.24
160
200
250
350
400
450
500
Z(-25°C)/Z(+20°C)
3
3
3
5
5
6
6
Z(-40°C)/Z(+20°C)
6
6
6
6
6
9
15
Dissipation Factor (tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
(at 20°C,120Hz)
(at 120Hz)
The specifications listed below shall be met when the capacitors are restored to 20°C after DC voltage is applied for 3,000 hours
(WV:160~450V) at 130°C or after DC voltage with the rated ripple current is applied for 12,000 hours at 105°C (500V: 10,000 hours),
the peak voltage shall not exceed the rated voltage.
Endurance
Capacitance Change
≤±20% of the initial value
D.F. (tanδ)
≤200% of the initial specified value
Leakage Current
≤The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20°C after leaving them under no load
at 105°C for 1,000 hours.
Shelf Life
Capacitance Change
D.F. (tanδ)
Leakage Current
DIMENSIONS[mm]
Ød
ØD'
F±0.5
L'
4min.
15min.
( Ø 6.3~ Ø 22)
ØD
6.3
Ød
0.5
F
ØD'
L'
2.5
8
0.5
0.6
3.5
10
12.5
16
18
22
0.6
0.6
0.8
0.8
0.8
5.0
5.0
7.5
7.5
10
Ø D+0.5max.
L+2max.
Radial Type
Sleeve(Dark Green)
PART NUMBERING SYSTEM
E
GX 2G
M 3R3 F12 O- -
T
Sleeve Code: “C” for PVC, “T” for PET
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
RATED RIPPLE CURRENT MULTIPLIERS
Frequency correction factor for ripple current
Freq.(Hz)
120
1k
10k
100k
Cap.
很抱歉,暂时无法提供与“EGX2DM100F12OT”相匹配的价格&库存,您可以联系我们找货
