MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
HF series
Long life, high ripple current; For power supply applications
Endurance: +105°C 5,000~10,000 hours
1808
RoHS Compliant
SPECIFICATIONS
Items
Characteristics
Category Temperature Range
-40~+105°C(160~400V dc )
Rated Voltage Range
160~450 V dc
Capacitance Tolerance
±20%(M)
Leakage Current
-25~+105°C(450V dc )
(at 20°C,120Hz)
CV≤1000
CV>1000
After 1 minute
After 5 minutes
l≤0.1CV+40μA
l≤0.04CV+100μA
l≤0.03CV+15μA
l≤0.02CV+25μA
Rated Voltage(V dc )
160
200
400
450
tanδ (max.)
0.15
0.15 0.15 0.20 0.20
0.20
160
200
250
Z(-25°C)/Z(+20°C)
3
3
3
Z(-40°C)/Z(+20°C)
8
8
8
250
350
Where,I:Max.leakage current (μA),
C:Nominal capacitance (μF),
V: Rated voltage (V)
(at 20°C)
Dissipation Factor (tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
350
400
450
6
6
6
10
10
(at 20°C,120Hz)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20°C after DC voltage plus the rated
ripple current is applied for a specified period of time at 105°C.
Case Dia.(mm) Load life (hours)
Capacitance Change
≤±20% of the initial value
5,000
ØD≤8
D.F. (tanδ)
≤200% of the initial specified value
8,000
ØD = 10
Leakage Current
≤The initial specified value
10,000
ØD≥12 . 5
Endurance
The following specifications shall be satisfied when the capacitors are restored to 20°C after exposing them for 1,000
hours at 105°C without voltage applied.
Shelf Life
Capacitance Change
D.F. (tanδ)
Leakage Current
DIMENSIONS[mm]
ØD
Sleeve(Brown)
Ød
ØD'
F±0.5
L'
4min.
15min.
Ød
F
ØD'
L'
8
0.5
0.6
3.5
10
12.5
16
18
0.6
0.6
0.8
0.8
5.0
5.0
7.5
7.5
Ø D+0.5max.
L+2max.
( Ø 8~ Ø 18)
PART NUMBERING SYSTEM
E
HF 2G
M 3R3 G12 O- -
T
Sleeve Code: “C” for PVC, “T” for PET
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
RATED RIPPLE CURRENT MULTIPLIERS
Frequency correction factor for ripple current
Freq.(Hz)
Cap.(μF)
120
很抱歉,暂时无法提供与“EHF2GM4R7E14OT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.55553
- 20+0.50472
- 100+0.45391
- 500+0.40310
- 1000+0.37939
- 2000+0.36245
- 国内价格
- 10+0.46030
- 100+0.36386
- 500+0.31569
