MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
HL series
Long life, downsized, high ripple current; For power supply applications
Endurance: +105°C 8,000~12,000 hours
HL 105 C
1808
RoHS Compliant
SPECIFICATIONS
Items
Characteristics
Category Temperature Range
-40~+105°C(160~400V dc )
Rated Voltage Range
160~500 V dc
Capacitance Tolerance
±20%(M)
Leakage Current
-25~+105°C(450~500V dc )
(at 20°C,120Hz)
CV≤1000
CV>1000
After 1 minute
After 5 minutes
l≤0.1CV+40μA
l≤0.04CV+100μA
l≤0.03CV+15μA
Where,I:Max.leakage current (μA),
C:Nominal capacitance (μF),
V: Rated voltage (V)
(at 20°C)
l≤0.02CV+25μA
Rated Voltage(V dc )
160
200
400
450
500
tanδ (max.)
0.18
0.18 0.18 0.24 0.24
0.24
0.24
160
200
250
350
400
450
500
Z(-25°C)/Z(+20°C)
3
3
3
6
6
6
6
Z(-40°C)/Z(+20°C)
8
8
8
10
10
250
350
Dissipation Factor (tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
(at 20°C,120Hz)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20°C after DC voltage plus the rated
ripple current is applied for a specified period of time at 105°C.
Endurance
Capacitance Change
≤±20% of the initial value
D.F. (tanδ)
≤200% of the initial specified value
Leakage Current
≤The initial specified value
Rated Voltage
Life time
160 to 450Vdc
500V dc
L≤20: 10,000 hours
Φ10: 8,000 hours
L >20: 12,000 hours
Φ≥12.5: 10,000 hours
The following specifications shall be satisfied when the capacitors are restored to 20°C after exposing them for 1,000 hours
at 105°C without voltage applied.
Shelf Life
Capacitance Change
D.F. (tanδ)
Leakage Current
DIMENSIONS[mm]
Sleeve(Brown)
Ød
ØD'
F±0.5
L'
4min.
15min.
ØD
10
12.5
16
18
Ød
F
ØD'
L'
0.6
0.6
0.8
0.8
5.0
7.5
7.5
5.0
Ø D+0.5max.
L+2max.
( Ø 10~ Ø 18)
PART NUMBERING SYSTEM
E
HL 2D
M 330 G20 O- -
T
Sleeve Code: “C” for PVC, “T” for PET
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
RATED RIPPLE CURRENT MULTIPLIERS
Frequency correction factor for ripple current
Freq.(Hz)
Cap.(μF)
120
很抱歉,暂时无法提供与“EHL2VM101M25OT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.17760
- 10+5.06520
- 30+4.51440
- 250+3.47760
