EHS2GM4R7E14OT
EHS2GM4R7E14OT
    AISHI(艾华集团)
    插件,D6.3xL14mm
    直插铝电解电容 插件,D6.3xL14mm 4.7µF ±20% Ф6.30 x 14.00mm 400V 3000Hrs@105℃
EHS2GM4R7E14OT 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS HS series High ripple current; For power supply applications Endurance: +105°C 3,000~5,000 hours 1808 RoHS Compliant SPECIFICATIONS Items Characteristics Category Temperature Range -40~+105°C(160~400V dc ) Rated Voltage Range 160~450 V dc Capacitance Tolerance ±20%(M) Leakage Current -25~+105°C(450V dc ) (at 20°C,120Hz) CV≤1000 CV>1000 After 1 minute After 5 minutes l≤0.1CV+40μA l≤0.04CV+100μA l≤0.03CV+15μA l≤0.02CV+25μA (at 20°C) Rated Voltage(V dc ) 160 200 400 450 tanδ (max.) 0.15 0.15 0.15 0.20 0.20 0.20 Rated Voltage(V dc ) 160 200 250 350 400 450 Z(-25°C)/Z(+20°C) 3 3 3 6 6 6 Z(-40°C)/Z(+20°C) 8 8 8 10 10 - 250 350 Where,I:Max.leakage current (μA), C:Nominal capacitance (μF), V: Rated voltage (V) Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) (at 20°C,120Hz) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20°C after DC voltage plus the rated ripple current is applied for a specified period of time at 105°C. Endurance Capacitance Change ≤±20% of the initial value Case Dia.(mm) Load life (hours) D.F. (tanδ) ≤200% of the initial specified value ØD≤8 3,000 Leakage Current ≤The initial specified value ØD≥10 Capacitance Change ≤±20% of the initial value D.F. (tanδ) ≤200% of the initial specified value Leakage Current ≤200% of the initial specified value 5,000 The following specifications shall be satisfied when the capacitors are restored to 20°C after exposing them for 1,000 hours at 105°C without voltage applied. Shelf Life DIMENSIONS[mm] Sleeve(Brown) Ød ØD' F±0.5 L' 4min. 15min. ( Ø 6.3~ Ø 18) ØD 6.3 Ød F ØD' L' 0.5 2.5 8 0.5 0.6 3.5 10 12.5 16 18 0.6 0.6 0.8 0.8 5.0 5.0 7.5 7.5 Ø D+0.5max. L+2max. PART NUMBERING SYSTEM E HS 2G M 3R3 G12 O- - T Sleeve Code: “C” for PVC, “T” for PET Terminal code Size code Capacitance code Capacitance tolerance code Voltage code Series code Category code RATED RIPPLE CURRENT MULTIPLIERS Frequency correction factor for ripple current Freq.(Hz) Cap.(μF) 120
EHS2GM4R7E14OT 价格&库存
很抱歉,暂时无法提供与“EHS2GM4R7E14OT”相匹配的价格&库存,您可以联系我们找货
