LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS
LH series
Withstand high temperature, for general purpose
Endurance: 2,000 hours at 105°C
Upgrade
RoHS Compliant
SPECIFICATIONS
Items
Characteristics
Category Temperature Range
-40~+105°C
-25~+105°C
Rated Voltage Range
10~100V.DC
160~500V.DC
Capacitance Tolerance
±20% (M)
(at 20°C, 120Hz)
I≤3 CV
Where, I: Max.leakage current (μA), C: Nominal capacitance (μF), V: Rated voltage (V)
Leakage Current
Rated Voltage (Vdc)
Dissipation Factor (tanδ)
16
25
35
50
63
80
100
160 to 250
0.55 0.50 0.45 0.40 0.35 0.30 0.25 0.20
315 to 450
500
0.15
0.15
0.20
Rated Voltage (Vdc)
10
16
25
35
50
63
80
100
160 to 250
315 to 400
420 to 500
Z(-25°C)/Z(+20°C)
4
4
3
3
2
2
2
2
4
8
8
5
tanδ (max.)
Low Temperature
Characteristics
(Max. Impedance Ratio)
10
(at 20°C after 5 minutes)
Z(-40°C)/Z(+20°C)
15
15
10
8
6
6
5
(at 20°C, 120Hz)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20°C after DC voltage plus the rated ripple current
is applied for 2,000 hours at 105°C.
Endurance
Capacitance Change
≤±20% of the initial value
D.F. (tanδ)
≤200% of the initial specified value
Leakage Current
≤The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20°C after exposing them for 1,000 hours at
105°C without voltage applied.
Shelf Life
Capacitance Change
D.F. (tanδ)
≤150% of the initial specified value
Leakage Current
DIMENSIONS [mm]
Terminal Code: P (Ф40 to Ф45)
Terminal Code : K (Φ22 to Φ35) : Standard
Bottom plate
Sleeve(PET)
L+2Max
Safety vent
4.5±1
ØF
ØD+1 Max
3 0°
3 0°
4-Ø2.0±0.1
Ø22.5±0.1
(PC board Mounting Holes)
(Component Side)
PART NUMBERING SYSTEM
E
LH
2W
M 151 P40
K
T
Sleeve Code: “C” for PVC, “T” for PET
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
RATED RIPPLE CURRENT MULTIPLIERS
Frequency correction factor for ripple current
Rated
voltage(Vdc)
Freq.(Hz)
10~50
63~100
160~250
315~500
120
1k
10k
100k
1.00
1.00
1.00
1.00
1.03
1.07
1.32
1.30
1.05
1.13
1.45
1.41
1.08
1.19
1.50
1.43
The endurance of capacitors is shortened with internal heating produced by
ripple current at the rate of halving the lifetime with every 5°C rise. When long life
performance is required in actual use,the rms ripple current has to be reduced.
187
LH series
WV
(V dc )
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
0.45
3.27
ELH1EM153P45KT
0.45
3.13
ELH1EM153Q35KT
35×30
0.45
3.26
ELH1EM153R30KT
30×40
0.45
3.56
ELH1EM183Q40KT
35×35
0.45
3.84
ELH1EM183R35KT
30×45
0.45
4.04
ELH1EM223Q45KT
35×35
0.45
3.75
ELH1EM223R35KT
27000
35×45
0.45
4.74
ELH1EM273R45KT
ELH1AM223O45KT
33000
35×50
0.45
5.50
ELH1EM333R50KT
2.54
ELH1AM223P35KT
3300
22×25
0.40
1.45
ELH1VM332O25KT
0.55
2.50
ELH1AM223Q30KT
3900
22×30
0.40
1.69
ELH1VM392O30KT
22×50
0.55
3.17
ELH1AM273O50KT
22×35
0.40
2.02
ELH1VM472O35KT
25×40
0.55
3.07
ELH1AM273P40KT
25×25
0.40
1.62
ELH1VM472P25KT
30×30
0.55
2.95
ELH1AM273Q30KT
22×35
0.40
2.13
ELH1VM562O35KT
25×45
0.55
3.39
ELH1AM333P45KT
25×30
0.40
2.00
ELH1VM562P30KT
30×35
0.55
3.33
ELH1AM333Q35KT
22×40
0.40
2.41
ELH1VM682O40KT
35×30
0.55
3.21
ELH1AM333R30KT
25×35
0.40
2.31
ELH1VM682P35KT
30×40
0.55
3.70
ELH1AM393Q40KT
30×25
0.40
2.31
ELH1VM682Q25KT
35×35
0.55
3.68
ELH1AM393R35KT
22×50
0.40
2.85
ELH1VM822O50KT
30×45
0.55
4.22
ELH1AM473Q45KT
25×40
0.40
2.73
ELH1VM822P40KT
35×40
0.55
4.16
ELH1AM473R40KT
30×30
0.40
2.75
ELH1VM822Q30KT
56000
35×45
0.55
5.00
ELH1AM563R45KT
25×45
0.40
3.05
ELH1VM103P45KT
6800
22×25
0.50
1.75
ELH1CM682O25KT
30×35
0.40
3.05
ELH1VM103Q35KT
8200
22×30
0.50
2.00
ELH1CM822O30KT
25×50
0.40
3.37
ELH1VM123P50KT
22×30
0.50
2.10
ELH1CM103O30KT
30×40
0.40
3.23
ELH1VM123Q40KT
25×25
0.50
2.05
ELH1CM103P25KT
35×30
0.40
3.19
ELH1VM123R30KT
22×35
0.50
2.31
ELH1CM123O35KT
30×45
0.40
3.72
ELH1VM153Q45KT
25×30
0.50
2.30
ELH1CM123P30KT
35×35
0.40
3.67
ELH1VM153R35KT
30×25
0.50
2.30
ELH1CM123Q25KT
18000
35×40
0.40
4.37
ELH1VM183R40KT
22×40
0.50
2.68
ELH1CM153O40KT
22000
35×45
0.40
4.92
ELH1VM223R45KT
25×35
0.50
2.58
ELH1CM153P35KT
1800
22×25
0.35
1.34
ELH1HM182O25KT
30×30
0.50
2.57
ELH1CM153Q30KT
2200
22×30
0.35
1.60
ELH1HM222O30KT
22×50
0.50
3.20
ELH1CM183O50KT
22×30
0.35
1.70
ELH1HM272O30KT
25×40
0.50
3.16
ELH1CM183P40KT
25×25
0.35
1.70
ELH1HM272P25KT
30×30
0.50
2.98
ELH1CM183Q30KT
22×35
0.35
1.97
ELH1HM332O35KT
25×45
0.50
3.36
ELH1CM223P45KT
25×30
0.35
1.88
ELH1HM332P30KT
30×35
0.50
3.30
ELH1CM223Q35KT
22×40
0.35
2.22
ELH1HM392O40KT
35×30
0.50
3.25
ELH1CM223R30KT
25×30
0.35
2.20
ELH1HM392P30KT
25×50
0.50
3.85
ELH1CM273P50KT
30×25
0.35
1.95
ELH1HM392Q25KT
30×40
0.50
3.80
ELH1CM273Q40KT
22×45
0.35
2.43
ELH1HM472O45KT
35×35
0.50
3.93
ELH1CM273R35KT
25×35
0.35
2.43
ELH1HM472P35KT
30×45
0.50
4.30
ELH1CM333Q45KT
30×30
0.35
2.25
ELH1HM472Q30KT
35×35
0.50
4.27
ELH1CM333R35KT
22×50
0.35
2.75
ELH1HM562O50KT
30×50
0.50
4.81
ELH1CM393Q50KT
25×40
0.35
2.72
ELH1HM562P40KT
35×40
0.50
4.80
ELH1CM393R40KT
30×30
0.35
2.64
ELH1HM562Q30KT
47000
35×45
0.50
5.53
ELH1CM473R45KT
25×45
0.35
3.30
ELH1HM682P45KT
4700
22×25
0.45
1.61
ELH1EM472O25KT
30×35
0.35
3.30
ELH1HM682Q35KT
5600
22×30
0.45
1.80
ELH1EM562O30KT
35×30
0.35
3.25
ELH1HM682R30KT
22×35
0.45
2.09
ELH1EM682O35KT
30×40
0.35
3.60
ELH1HM822Q40KT
25×25
0.45
1.87
ELH1EM682P25KT
35×35
0.35
3.60
ELH1HM822R35KT
22×40
0.45
2.31
ELH1EM822O40KT
30×50
0.35
4.05
ELH1HM103Q50KT
25×30
30×25
0.45
0.45
2.34
2.16
ELH1EM822P30KT
35×40
0.35
4.04
ELH1HM103R40KT
ELH1EM822Q25KT
12000
35×45
0.35
4.56
ELH1HM123R45KT
22×45
0.45
2.65
ELH1EM103O45KT
15000
35×50
0.35
4.77
ELH1HM153R50KT
25×35
0.45
2.61
ELH1EM103P35KT
1200
22×25
0.30
1.20
ELH1JM122O25KT
30×30
0.45
2.61
ELH1EM103Q30KT
1500
22×30
0.30
1.47
ELH1JM152O30KT
22×50
0.45
2.80
ELH1EM123O50KT
22×30
0.30
1.58
ELH1JM182O30KT
25×40
0.45
2.81
ELH1EM123P40KT
25×25
0.30
1.52
ELH1JM182P25KT
30×30
0.45
2.74
ELH1EM123Q30KT
22×35
0.30
1.82
ELH1JM222O35KT
25×30
0.30
1.75
ELH1JM222P30KT
Cap
(µF)
Size
ΦDxL(mm)
tanδ
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
10000
22×25
0.55
1.77
ELH1AM103O25KT
22×30
0.55
2.10
ELH1AM123O30KT
25×25
0.55
1.94
22×35
0.55
25×30
12000
15000
18000
22000
10(1A)
27000
33000
39000
47000
10000
12000
15000
16(1C)
18000
22000
27000
33000
39000
6800
8200
25(1E)
10000
12000
WV
(V dc )
Cap
(µF)
Size
ΦDxL(mm)
tanδ
25×45
15000
30×35
ELH1AM123P25KT
2.23
ELH1AM153O35KT
0.55
2.10
ELH1AM153P30KT
22×40
0.55
2.41
ELH1AM183O40KT
25×30
0.55
2.34
ELH1AM183P30KT
30×25
0.55
2.25
ELH1AM183Q25KT
22×45
0.55
2.58
25×35
0.55
30×30
25(1E)
18000
22000
4700
5600
6800
35(1V)
8200
10000
12000
15000
2700
3300
3900
4700
50(1H)
5600
6800
8200
10000
63(1J)
1800
2200
188
Snap-in&Lug
Terminal Type
STANDARD RATINGS
LH series
STANDARD RATINGS
WV
(V dc )
Size
ΦDxL(mm)
tanδ
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
30×50
0.20
3.60
ELH1KM392Q50KT
35×40
0.20
3.67
ELH1KM392R40KT
4700
35×45
0.20
3.80
ELH1KM472R45KT
ELH1JM332O45KT
5600
35×50
0.20
4.05
ELH1KM562R50KT
2.27
ELH1JM332P35KT
220
22×25
0.15
0.92
ELH2CM221O25KT
0.30
2.24
ELH1JM332Q30KT
330
22×25
0.15
1.03
ELH2CM331O25KT
0.30
2.51
ELH1JM392P40KT
390
22×30
0.15
1.17
ELH2CM391O30KT
30×35
0.30
2.55
ELH1JM392Q35KT
22×30
0.15
1.28
ELH2CM471O30KT
25×50
0.30
2.97
ELH1JM472P50KT
25×25
0.15
1.29
ELH2CM471P25KT
30×40
0.30
2.86
ELH1JM472Q40KT
22×35
0.15
1.45
ELH2CM561O35KT
35×30
0.30
2.80
ELH1JM472R30KT
25×30
0.15
1.49
ELH2CM561P30KT
30×40
0.30
3.22
ELH1JM562Q40KT
22×40
0.15
1.64
ELH2CM681O40KT
35×35
0.30
3.20
ELH1JM562R35KT
25×35
0.15
1.70
ELH2CM681P35KT
30×50
0.30
3.65
ELH1JM682Q50KT
30×25
0.15
1.63
ELH2CM681Q25KT
35×40
0.30
3.65
ELH1JM682R40KT
22×45
0.15
1.85
ELH2CM821O45KT
8200
35×45
0.30
4.04
ELH1JM822R45KT
25×40
0.15
1.92
ELH2CM821P40KT
10000
35×50
0.30
4.48
ELH1JM103R50KT
30×30
0.15
1.91
ELH2CM821Q30KT
1000
22×25
0.25
1.19
ELH1BM102O25KT
25×45
0.15
2.17
ELH2CM102P45KT
1200
22×30
0.25
1.44
ELH1BM122O30KT
30×35
0.15
2.19
ELH2CM102Q35KT
22×30
0.25
1.59
ELH1BM152O30KT
25×50
0.15
2.43
ELH2CM122P50KT
25×25
0.25
1.59
ELH1BM152P25KT
30×40
0.15
2.48
ELH2CM122Q40KT
22×35
0.25
1.79
ELH1BM182O35KT
35×30
0.15
2.25
ELH2CM122R30KT
25×30
0.25
1.71
ELH1BM182P30KT
30×45
0.15
2.82
ELH2CM152Q45KT
22×40
0.25
2.03
ELH1BM222O40KT
35×35
0.15
2.62
ELH2CM152R35KT
25×35
0.25
1.98
ELH1BM222P35KT
30×50
0.15
3.13
ELH2CM182Q50KT
30×25
0.25
1.98
ELH1BM222Q25KT
35×40
0.15
2.97
ELH2CM182R40KT
22×45
0.25
2.39
ELH1BM272O45KT
2200
35×45
0.15
3.34
ELH2CM222R45KT
25×40
0.25
2.35
ELH1BM272P40KT
270
22×25
0.15
0.97
ELH2LM271O25KT
30×30
0.25
2.35
ELH1BM272Q30KT
330
22×30
0.15
1.13
ELH2LM331O30KT
25×45
0.25
2.64
ELH1BM332P45KT
22×30
0.15
1.32
ELH2LM391O30KT
30×35
0.25
2.61
ELH1BM332Q35KT
25×25
0.15
1.33
ELH2LM391P25KT
35×30
0.25
2.74
ELH1BM332R30KT
22×35
0.15
1.39
ELH2LM471O35KT
25×50
0.25
2.92
ELH1BM392P50KT
25×30
0.15
1.43
ELH2LM471P30KT
30×40
0.25
2.82
ELH1BM392Q40KT
22×40
0.15
1.56
ELH2LM561O40KT
35×30
0.25
2.97
ELH1BM392R30KT
25×30
0.15
1.53
ELH2LM561P30KT
30×45
0.25
3.34
ELH1BM472Q45KT
30×25
0.15
1.56
ELH2LM561Q25KT
35×35
0.25
3.38
ELH1BM472R35KT
22×45
0.15
1.76
ELH2LM681O45KT
30×50
0.25
3.80
ELH1BM562Q50KT
25×35
0.15
1.76
ELH2LM681P35KT
35×40
0.25
3.80
ELH1BM562R40KT
30×30
0.15
1.74
ELH2LM681Q30KT
6800
35×45
0.25
3.90
ELH1BM682R45KT
22×50
0.15
1.97
ELH2LM821O50KT
8200
35×50
0.25
4.20
ELH1BM822R50KT
25×40
0.15
1.99
ELH2LM821P40KT
680
22×25
0.20
1.09
ELH1KM681O25KT
30×30
0.15
1.93
ELH2LM821Q30KT
820
22×30
0.20
1.32
ELH1KM821O30KT
25×45
0.15
2.24
ELH2LM102P45KT
22×30
0.20
1.47
ELH1KM102O30KT
30×35
0.15
2.24
ELH2LM102Q35KT
25×25
0.20
1.45
ELH1KM102P25KT
35×30
0.15
2.20
ELH2LM102R30KT
22×35
0.20
1.69
ELH1KM122O35KT
30×40
0.15
2.53
ELH2LM122Q40KT
25×30
0.20
1.68
ELH1KM122P30KT
35×35
0.15
2.54
ELH2LM122R35KT
22×40
0.20
1.97
ELH1KM152O40KT
30×50
0.15
3.03
ELH2LM152Q50KT
25×35
0.20
1.98
ELH1KM152P35KT
35×40
0.15
2.91
ELH2LM152R40KT
30×25
0.20
1.95
ELH1KM152Q25KT
1800
35×45
0.15
3.25
ELH2LM182R45KT
22×45
0.20
2.23
ELH1KM182O45KT
2200
35×50
0.15
3.62
ELH2LM222R50KT
25×40
0.20
2.20
ELH1KM182P40KT
270
22×25
0.15
0.99
ELH2DM271O25KT
30×30
0.20
2.20
ELH1KM182Q30KT
22×30
0.15
1.20
ELH2DM331O30KT
25×45
0.20
2.53
ELH1KM222P45KT
25×25
0.15
1.20
ELH2DM331P25KT
30×35
0.20
2.55
ELH1KM222Q35KT
22×35
0.15
1.30
ELH2DM391O35KT
35×30
0.20
2.50
ELH1KM222R30KT
25×30
0.15
1.34
ELH2DM391P30KT
25×50
0.20
2.82
ELH1KM272P50KT
22×40
0.15
1.44
ELH2DM471O40KT
30×40
0.20
2.86
ELH1KM272Q40KT
25×30
0.15
1.44
ELH2DM471P30KT
35×35
0.20
2.89
ELH1KM272R35KT
30×25
0.15
1.48
ELH2DM471Q25KT
30×45
0.20
3.30
ELH1KM332Q45KT
35×35
0.20
3.25
ELH1KM332R35KT
Cap
(µF)
2700
3300
3900
63(1J)
4700
5600
6800
1500
1800
2200
80(1B)
2700
3300
3900
4700
5600
1000
1200
1500
100(1K)
1800
2200
2700
3300
Size
ΦDxL(mm)
tanδ
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
22×40
0.30
2.07
ELH1JM272O40KT
25×35
0.30
2.11
ELH1JM272P35KT
30×25
0.30
1.72
ELH1JM272Q25KT
22×45
0.30
2.33
25×35
0.30
30×30
25×40
WV
(V dc )
Cap
(µF)
3900
100(1K)
470
560
680
160(2C)
820
1000
1200
1500
1800
390
470
560
680
180(2L)
820
1000
1200
1500
330
200(2D)
390
470
189
LH series
WV
(V dc )
Cap
(µF)
560
680
200(2D)
820
tanδ
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
22×45
0.15
1.60
ELH2DM561O45KT
25×35
0.15
1.60
ELH2DM561P35KT
30×30
0.15
1.60
ELH2DM561Q30KT
22×50
0.15
1.75
ELH2DM681O50KT
25×40
0.15
1.76
ELH2DM681P40KT
30×30
0.15
1.74
ELH2DM681Q30KT
25×45
0.15
2.10
ELH2DM821P45KT
30×35
0.15
2.11
ELH2DM821Q35KT
35×30
0.15
2.10
ELH2DM821R30KT
25×50
0.15
2.36
ELH2DM102P50KT
30×40
0.15
2.40
ELH2DM102Q40KT
35×35
0.15
2.30
ELH2DM102R35KT
30×45
0.15
2.69
ELH2DM122Q45KT
35×35
0.15
2.53
ELH2DM122R35KT
1500
35×40
0.15
2.97
ELH2DM152R40KT
1800
35×50
0.15
3.45
ELH2DM182R50KT
220
22×25
0.15
0.94
ELH2NM221O25KT
270
22×30
0.15
1.09
ELH2NM271O30KT
22×35
0.15
1.24
ELH2NM331O35KT
25×25
0.15
1.14
22×35
0.15
1.30
25×25
0.15
1.26
ELH2NM391P25KT
22×40
0.15
1.41
ELH2NM471O40KT
1000
1200
330
390
470
220(2N)
Size
ΦDxL(mm)
560
680
0.15
0.56
ELH2FM121O25KT
22×30
0.15
0.66
150
ELH2FM151O30KT
25×25
0.15
0.65
ELH2FM151P25KT
22×35
0.15
0.78
ELH2FM181O35KT
180
25×30
0.15
0.71
ELH2FM181P30KT
22×40
0.15
0.89
ELH2FM221O40KT
220
270
315(2F)
330
25×30
0.15
0.85
ELH2FM221P30KT
30×25
0.15
0.83
ELH2FM221Q25KT
22×45
0.15
1.01
ELH2FM271O45KT
25×35
0.15
0.98
ELH2FM271P35KT
30×30
0.15
1.01
ELH2FM271Q30KT
22×50
0.15
1.14
ELH2FM331O50KT
25×40
0.15
1.12
ELH2FM331P40KT
30×35
0.15
1.21
ELH2FM331Q35KT
35×30
0.15
1.23
ELH2FM391R30KT
30×40
0.15
1.53
ELH2FM471Q40KT
35×35
0.15
1.47
ELH2FM471R35KT
30×45
0.15
1.65
ELH2FM561Q45KT
390
470
560
25×30
0.15
1.39
ELH2NM471P30KT
35×40
0.15
1.66
ELH2FM561R40KT
30×25
0.15
1.37
ELH2NM471Q25KT
680
35×45
0.15
1.96
ELH2FM681R45KT
22×45
0.15
1.60
ELH2NM561O45KT
820
35×50
0.15
2.19
ELH2FM821R50KT
25×35
0.15
1.56
ELH2NM561P35KT
100
22×25
0.15
0.53
ELH2VM101O25KT
30×30
0.15
1.61
ELH2NM561Q30KT
22×30
0.15
0.61
ELH2VM121O30KT
35×25
0.15
1.52
ELH2NM561R25KT
25×25
0.15
0.62
ELH2VM121P25KT
25×40
0.15
1.75
ELH2NM681P40KT
22×35
0.15
0.73
ELH2VM151O35KT
30×35
0.15
1.76
ELH2NM681Q35KT
25×30
0.15
0.73
ELH2VM151P30KT
35×30
0.15
1.72
ELH2NM681R30KT
22×40
0.15
0.83
ELH2VM181O40KT
0.15
1.95
ELH2NM821R30KT
0.15
2.44
ELH2NM102Q45KT
35×35
0.15
2.20
ELH2NM102R35KT
1200
35×40
0.15
2.37
ELH2NM122R40KT
1500
30×45
0.15
2.64
ELH2NM152Q45KT
180
22×25
0.15
0.84
ELH2EM181O25KT
22×30
0.15
0.97
ELH2EM221O30KT
25×25
0.15
0.99
ELH2EM221P25KT
22×35
0.15
1.11
25×30
0.15
1.15
22×40
0.15
1.26
ELH2EM331O40KT
820
ELH2EM122R45KT
22×25
120
ELH2NM331P25KT
30×45
680
2.88
ELH2NM391O35KT
35×30
560
0.15
ELH2FM391P45KT
ELH2NM821P45KT
470
ELH2EM102R40KT
35×45
1200
ELH2FM391Q35KT
ELH2NM821Q40KT
250(2E)
ELH2EM102Q50KT
2.57
1.31
2.06
390
2.64
0.15
35×40
1.30
1.97
330
0.15
30×50
1000
0.15
0.15
270
Part Number
tanδ
0.15
0.15
220
Rated ripple
current
(Arms/105°C,
120Hz)
Size
ΦDxL(mm)
25×45
25×45
1000
250(2E)
Cap
(µF)
30×35
30×40
820
WV
(V dc )
120
150
180
220
350(2V)
270
25×30
0.15
0.80
ELH2VM181P30KT
30×25
0.15
0.81
ELH2VM181Q25KT
22×45
0.15
0.94
ELH2VM221O45KT
25×35
0.15
0.92
ELH2VM221P35KT
30×30
0.15
0.98
ELH2VM221Q30KT
22×50
0.15
1.07
ELH2VM271O50KT
25×40
0.15
1.05
ELH2VM271P40KT
30×30
0.15
1.03
ELH2VM271Q30KT
25×45
0.15
1.24
ELH2VM331P45KT
30×35
0.15
1.24
ELH2VM331Q35KT
ELH2EM271O35KT
35×30
0.15
1.18
ELH2VM331R30KT
ELH2EM271P30KT
25×50
0.15
1.38
ELH2VM391P50KT
30×40
0.15
1.39
ELH2VM391Q40KT
330
390
25×30
0.15
1.26
ELH2EM331P30KT
35×35
0.15
1.39
ELH2VM391R35KT
30×25
0.15
1.31
ELH2EM331Q25KT
30×45
0.15
1.57
ELH2VM471Q45KT
22×45
0.15
1.41
ELH2EM391O45KT
35×35
0.15
1.50
ELH2VM471R35KT
25×35
0.15
1.42
ELH2EM391P35KT
30×50
0.15
1.75
ELH2VM561Q50KT
30×30
0.15
1.50
ELH2EM391Q30KT
35×40
0.15
1.69
ELH2VM561R40KT
22×50
0.15
1.58
ELH2EM471O50KT
680
35×45
0.15
1.96
ELH2VM681R45KT
25×40
0.15
1.61
ELH2EM471P40KT
68
22×25
0.15
0.45
ELH3BM680O25KT
30×30
0.15
1.61
ELH2EM471Q30KT
82
22×30
0.15
0.52
ELH3BM820O30KT
25×45
0.15
1.80
ELH2EM561P45KT
22×30
0.15
0.58
ELH3BM101O30KT
30×35
0.15
1.84
ELH2EM561Q35KT
25×25
0.15
0.57
ELH3BM101P25KT
25×50
0.15
2.03
ELH2EM681P50KT
22×35
0.15
0.68
ELH3BM121O35KT
30×40
0.15
2.09
ELH2EM681Q40KT
25×30
0.15
0.68
ELH3BM121P30KT
35×30
0.15
1.96
ELH2EM681R30KT
22×40
0.15
0.79
ELH3BM151O40KT
30×45
0.15
2.35
ELH2EM821Q45KT
25×30
0.15
0.78
ELH3BM151P30KT
35×35
0.15
2.26
ELH2EM821R35KT
30×25
0.15
0.75
ELH3BM151Q25KT
470
560
100
385(3B)
120
150
190
Snap-in&Lug
Terminal Type
STANDARD RATINGS
LH series
STANDARD RATINGS
WV
(V dc )
Cap
(µF)
tanδ
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
22×45
0.15
0.89
ELH3BM181O45KT
25×35
0.15
0.86
ELH3BM181P35KT
30×30
0.15
0.88
22×50
0.15
1.01
25×40
0.15
1.00
ELH3BM221P40KT
30×30
0.15
1.00
25×45
0.15
1.13
30×40
0.15
1.14
35×30
0.15
30×45
WV
(V dc )
Rated ripple
current
(Arms/105°C,
120Hz)
Cap
(µF)
Size
ΦDxL(mm)
tanδ
25×45
0.15
1.13
ELH2TM221P45KT
220
30×35
0.15
1.09
ELH2TM221Q35KT
ELH3BM181Q30KT
35×30
0.15
1.05
ELH2TM221R30KT
ELH3BM221O50KT
25×50
0.15
1.37
ELH2TM271P50KT
30×40
0.15
1.25
ELH2TM271Q40KT
ELH3BM221Q30KT
35×35
0.15
1.25
ELH2TM271R35KT
ELH3BM271P45KT
30×45
0.15
1.49
ELH2TM331Q45KT
ELH3BM271Q40KT
35×35
0.15
1.42
ELH2TM331R35KT
1.10
ELH3BM271R30KT
30×50
0.15
1.67
ELH2TM391Q50KT
0.15
1.31
ELH3BM331Q45KT
35×40
0.15
1.61
ELH2TM391R40KT
35×35
0.15
1.32
ELH3BM331R35KT
470
35×45
0.15
1.86
ELH2TM471R45KT
30×50
0.15
1.48
ELH3BM391Q50KT
560
35×50
0.15
2.02
ELH2TM561R50KT
35×40
0.15
1.48
ELH3BM391R40KT
680
35×50
0.15
2.20
ELH2TM681R50KT
470
35×45
0.15
1.76
ELH3BM471R45KT
820
35×60
0.15
2.45
ELH2TM821R60KT
560
35×50
0.15
1.95
ELH3BM561R50KT
35×70
0.15
2.82
ELH2TM102R70KT
68
22×25
0.15
0.49
ELH2GM680O25KT
40×60
0.15
2.80
ELH2TM102Y60PT
82
22×30
0.15
0.56
ELH2GM820O30KT
1200
40×70
0.15
3.20
ELH2TM122Y70PT
22×30
0.15
0.62
ELH2GM101O30KT
1500
40×85
0.15
3.56
ELH2TM152Y85PT
25×25
0.15
0.61
ELH2GM101P25KT
1800
40×100
0.15
4.31
ELH2TM182YA0PT
22×35
0.15
0.73
ELH2GM121O35KT
56
22×25
0.15
0.42
ELH2WM560O25KT
25×30
0.15
0.73
ELH2GM121P30KT
22×30
0.15
0.50
ELH2WM680O30KT
22×40
0.15
0.85
ELH2GM151O40KT
25×25
0.15
0.50
ELH2WM680P25KT
25×35
0.15
0.85
ELH2GM151P35KT
22×35
0.15
0.56
ELH2WM820O35KT
30×25
0.15
0.79
ELH2GM151Q25KT
25×30
0.15
0.57
ELH2WM820P30KT
22×45
0.15
0.95
ELH2GM181O45KT
22×40
0.15
0.64
ELH2WM101O40KT
180
385(3B)
220
270
330
390
100
120
150
180
220
400(2G)
Size
ΦDxL(mm)
270
330
390
25×35
0.15
0.92
ELH2GM181P35KT
30×30
0.15
0.95
ELH2GM181Q30KT
22×50
0.15
1.08
ELH2GM221O50KT
25×40
0.15
1.05
ELH2GM221P40KT
30×35
0.15
1.24
ELH2GM221Q35KT
25×50
0.15
1.29
ELH2GM271P50KT
30×40
0.15
1.30
ELH2GM271Q40KT
35×30
0.15
1.18
ELH2GM271R30KT
30×45
0.15
1.47
ELH2GM331Q45KT
35×35
0.15
1.40
ELH2GM331R35KT
30×50
0.15
1.64
ELH2GM391Q50KT
35×40
0.15
1.59
ELH2GM391R40KT
270
330
420(2T)
390
1000
68
82
100
120
150
180
450(2W)
220
Part Number
25×30
0.15
0.63
ELH2WM101P30KT
30×25
0.15
0.67
ELH2WM101Q25KT
22×45
0.15
0.72
ELH2WM121O45KT
25×35
0.15
0.71
ELH2WM121P35KT
30×30
0.15
0.77
ELH2WM121Q30KT
22×50
0.15
0.80
ELH2WM151O50KT
25×40
0.15
0.82
ELH2WM151P40KT
30×30
0.15
0.85
ELH2WM151Q30KT
25×45
0.15
0.93
ELH2WM181P45KT
30×35
0.15
0.97
ELH2WM181Q35KT
25×50
0.15
1.05
ELH2WM221P50KT
30×40
0.15
1.10
ELH2WM221Q40KT
470
35×45
0.15
1.68
ELH2GM471R45KT
35×30
0.15
1.01
ELH2WM221R30KT
560
35×50
0.15
1.90
ELH2GM561R50KT
30×45
0.15
1.25
ELH2WM271Q45KT
680
35×50
0.15
2.03
ELH2GM681R50KT
35×35
0.15
1.26
ELH2WM271R35KT
820
35×60
0.15
2.36
ELH2GM821R60KT
30×50
0.15
1.42
ELH2WM331Q50KT
35×70
0.15
2.65
ELH2GM102R70KT
35×40
0.15
1.44
ELH2WM331R40KT
40×60
0.15
2.60
ELH2GM102Y60PT
390
35×45
0.15
1.61
ELH2WM391R45KT
1200
40×70
0.15
2.97
ELH2GM122Y70PT
470
35×50
0.15
1.80
ELH2WM471R50KT
1500
40×80
0.15
3.48
ELH2GM152Y80PT
560
35×50
0.15
1.90
ELH2WM561R50KT
1800
40×100
0.15
4.31
ELH2GM182YA0PT
35×55
68
22×25
0.15
0.50
0.15
2.12
ELH2WM681R55KT
ELH2TM680O25KT
680
22×30
0.15
0.56
ELH2TM820O30KT
820
35×65
0.15
2.55
ELH2WM821R65KT
35×80
0.15
2.85
ELH2WM102R80KT
40×70
0.15
2.82
ELH2WM102Y70PT
1200
40×80
0.15
3.22
ELH2WM122Y80PT
1000
82
100
120
420(2T)
150
180
25×25
0.15
0.56
270
330
ELH2TM820P25KT
1000
22×30
0.15
0.63
25×25
0.15
0.63
ELH2TM101P25KT
22×35
0.15
0.73
ELH2TM121O35KT
1500
40×100
0.15
3.63
ELH2WM152YA0PT
45×100
0.15
4.35
ELH2WM182IA0PT
ELH2TM101O30KT
25×30
0.15
0.72
ELH2TM121P30KT
1800
30×25
0.15
0.75
ELH2TM121Q25KT
47
22×25
0.20
0.41
ELH2HM470O25KT
22×45
0.15
0.86
ELH2TM151O45KT
56
22×30
0.20
0.43
ELH2HM560O30KT
25×35
0.15
0.83
ELH2TM151P35KT
68
22×30
0.20
0.52
ELH2HM680O30KT
30×25
0.15
0.83
ELH2TM151Q25KT
25×25
0.20
0.55
ELH2HM680P25KT
22×50
0.15
1.02
ELH2TM181O50KT
22×35
0.20
0.62
ELH2HM820O35KT
25×40
0.15
0.94
ELH2TM181P40KT
25×30
0.20
0.57
ELH2HM820P30KT
30×30
0.15
0.95
ELH2TM181Q30KT
22×45
0.20
0.68
ELH2HM101O45KT
35×25
0.15
0.90
ELH2TM181R25KT
25×30
0.20
0.72
ELH2HM101P30KT
500(2H)
82
100
191
LH series
WV
(V dc )
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
0.20
0.76
ELH2HM121O50KT
0.20
0.79
ELH2HM121P35KT
30×30
0.20
0.91
ELH2HM121Q30KT
Cap
(µF)
Size
ΦDxL(mm)
tanδ
22×50
120
25×35
150
500(2H)
180
220
270
25×45
0.20
1.08
ELH2HM151P45KT
30×35
0.20
1.04
ELH2HM151Q35KT
35×25
0.20
0.99
ELH2HM151R25KT
25×50
0.20
1.20
ELH2HM181P50KT
30×40
0.20
1.17
ELH2HM181Q40KT
35×30
0.20
1.10
ELH2HM181R30KT
30×45
0.20
1.33
ELH2HM221Q45KT
35×35
0.20
1.23
ELH2HM221R35KT
30×50
0.20
1.50
ELH2HM271Q50KT
35×40
0.20
1.42
ELH2HM271R40KT
330
35×45
0.20
1.60
ELH2HM331R45KT
390
35×50
0.20
1.78
ELH2HM391R50KT
470
35×60
0.20
2.03
ELH2HM471R60KT
Snap-in&Lug
Terminal Type
STANDARD RATINGS
192
很抱歉,暂时无法提供与“ELH2WM471R50KT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+20.15280
- 10+19.77480
- 30+19.52640
- 100+19.26720
