LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS
LM series
Downsized, longer life
Endurance: 3,000 hours at 105°C
RoHS Compliant
SPECIFICATIONS
Items
Characteristics
Category Temperature Range
-25~+105°C
Rated Voltage Range
160~550V.DC
Capacitance Tolerance
±20%(M)
Leakage Current
I≤3 CV
Where, I:Max.leakage current (μA),C:Nominal capacitance (μF),V: Rated voltage (V)
(at 20°C,120Hz)
160 to 400
420 to 550
0.15
0.20
Rated Voltage(V dc )
160 to 250
315 to 550
Z(-25°C)/Z(+20°C)
4
8
Dissipation Factor (tanδ)
tanδ (max.)
Low Temperature
Characteristics
(Max. Impedance Ratio)
(at 20°C after 5 minutes)
(at 20°C,120Hz)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20°C after DC voltage plus the rated ripple
current is applied for 3,000 hours at 105 °C.
Endurance
Capacitance Change
≤±20% of the initial value
D.F. (tanδ)
≤200% of the initial specified value
Leakage Current
≤The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20°C after exposing them for 1,000 hours
at 105°C without voltage applied.
Shelf Life
Capacitance Change
≤±15% of the initial value
D.F. (tanδ)
≤150% of the initial specified value
Leakage Current
DIMENSIONS[mm]
Terminal Code : K (Φ22 to Φ35) : Standard
Terminal Code : L ( Φ35)
PART NUMBERING SYSTEM
E
LM 2E
M 181 O25
T
K
Sleeve Code: “C” for PVC, “T” for PET
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
RATED RIPPLE CURRENT MULTIPLIERS
Frequency correction factor for ripple current
Freq.(Hz)
Rated
voltage(Vdc)
120
160~250
315~550
1k
10k
100k
1.00
1.32
1.45
1.50
1.00
1.30
1.41
1.43
The endurance of capacitors is shortened with internal heating produced by ripple
current at the rate of halving the lifetime with every 5°C rise. When long life
performance is required in actual use, the rms ripple current has to be reduced.
199
LM series
WV
(V dc )
Cap
(µF)
Size
ΦDxL(mm)
tanδ
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
220
270
22×20
25×20
22×25
25×20
22×25
25×25
30×20
22×30
25×25
30×20
22×35
25×30
30×25
35×20
22×40
25×30
30×25
35×20
22×45
25×35
30×30
35×25
22×50
25×40
30×30
35×25
25×45
30×35
35×30
25×60
30×40
35×30
30×45
35×35
30×60
35×45
35×50
35×60
22×20
25×20
22×25
25×20
22×25
25×25
30×20
22×30
25×25
30×20
22×35
25×30
30×25
35×20
22×40
25×30
30×25
35×20
22×45
25×35
30×30
35×25
22×50
25×40
30×30
35×25
25×45
30×35
35×30
25×50
30×40
35×30
30×45
35×35
30×60
35×40
35×50
35×60
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.81
0.98
1.20
1.02
1.30
1.26
1.25
1.55
1.55
1.30
1.67
1.67
1.67
1.46
1.82
1.82
1.82
1.51
2.04
2.04
2.04
2.04
2.25
2.25
2.25
2.25
2.49
2.49
2.49
2.97
2.84
2.84
3.32
3.00
3.86
3.50
4.00
4.63
0.80
0.90
1.00
0.95
1.20
1.16
1.15
1.35
1.35
1.20
1.50
1.50
1.50
1.36
1.67
1.67
1.67
1.43
1.78
1.78
1.78
1.83
2.04
2.04
2.04
2.04
2.30
2.30
2.30
2.55
2.55
2.55
2.90
2.90
3.49
3.30
3.65
4.19
ELM2CM221O20KT
ELM2CM271P20KT
ELM2CM331O25KT
ELM2CM331P20KT
ELM2CM391O25KT
ELM2CM391P25KT
ELM2CM391Q20KT
ELM2CM471O30KT
ELM2CM471P25KT
ELM2CM471Q20KT
ELM2CM561O35KT
ELM2CM561P30KT
ELM2CM561Q25KT
ELM2CM561R20KT
ELM2CM681O40KT
ELM2CM681P30KT
ELM2CM681Q25KT
ELM2CM681R20KT
ELM2CM821O45KT
ELM2CM821P35KT
ELM2CM821Q30KT
ELM2CM821R25KT
ELM2CM102O50KT
ELM2CM102P40KT
ELM2CM102Q30KT
ELM2CM102R25KT
ELM2CM122P45KT
ELM2CM122Q35KT
ELM2CM122R30KT
ELM2CM152P60KT
ELM2CM152Q40KT
ELM2CM152R30KT
ELM2CM182Q45KT
ELM2CM182R35KT
ELM2CM222Q60KT
ELM2CM222R45KT
ELM2CM272R50KT
ELM2CM332R60KT
ELM2LM181O20KT
ELM2LM221P20KT
ELM2LM271O25KT
ELM2LM271P20KT
ELM2LM331O25KT
ELM2LM331P25KT
ELM2LM331Q20KT
ELM2LM391O30KT
ELM2LM391P25KT
ELM2LM391Q20KT
ELM2LM471O35KT
ELM2LM471P30KT
ELM2LM471Q25KT
ELM2LM471R20KT
ELM2LM561O40KT
ELM2LM561P30KT
ELM2LM561Q25KT
ELM2LM561R20KT
ELM2LM681O45KT
ELM2LM681P35KT
ELM2LM681Q30KT
ELM2LM681R25KT
ELM2LM821O50KT
ELM2LM821P40KT
ELM2LM821Q30KT
ELM2LM821R25KT
ELM2LM102P45KT
ELM2LM102Q35KT
ELM2LM102R30KT
ELM2LM122P50KT
ELM2LM122Q40KT
ELM2LM122R30KT
ELM2LM152Q45KT
ELM2LM152R35KT
ELM2LM182Q60KT
ELM2LM182R40KT
ELM2LM222R50KT
ELM2LM272R60KT
330
390
470
560
680
160(2C)
820
1000
1200
1500
1800
2200
2700
3300
180
220
270
330
390
470
560
180(2L)
680
820
1000
1200
1500
1800
2200
2700
WV
(V dc )
Cap
(µF)
Size
ΦDxL(mm)
tanδ
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
150
180
220
22×20
22×20
25×20
22×25
30×20
22×30
25×25
30×20
22×30
25×25
35×20
22×35
25×30
30×25
35×20
22×40
25×30
30×25
22×45
25×35
30×30
35×25
25×45
30×30
35×25
25×50
30×35
35×30
25×60
30×40
35×35
30×50
35×40
30×60
35×45
35×50
22×20
25×20
22×25
25×20
22×30
25×25
30×20
22×35
25×25
35×20
22×35
25×30
30×25
35×20
22×40
25×35
30×25
22×45
25×40
30×30
35×25
25×45
30×35
35×25
25×50
30×40
35×30
25×60
30×45
35×35
30×50
35×40
30×60
35×45
35×50
35×60
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.73
0.80
0.85
1.10
1.05
1.25
1.25
1.10
1.35
1.35
1.30
1.50
1.50
1.50
1.41
1.67
1.67
1.67
1.78
1.78
1.78
1.78
2.04
2.04
2.04
2.30
2.30
2.30
2.66
2.65
2.65
3.08
3.08
3.49
3.48
3.78
0.67
0.76
1.00
0.84
1.15
1.08
0.98
1.25
1.25
1.13
1.40
1.40
1.36
1.23
1.51
1.54
1.50
1.70
1.72
1.70
1.71
1.94
1.93
1.89
2.18
2.19
2.16
2.54
2.50
2.44
2.81
2.79
3.30
3.22
3.63
4.23
ELM2DM151O20KT
ELM2DM181O20KT
ELM2DM221P20KT
ELM2DM271O25KT
ELM2DM271Q20KT
ELM2DM331O30KT
ELM2DM331P25KT
ELM2DM331Q20KT
ELM2DM391O30KT
ELM2DM391P25KT
ELM2DM391R20KT
ELM2DM471O35KT
ELM2DM471P30KT
ELM2DM471Q25KT
ELM2DM471R20KT
ELM2DM561O40KT
ELM2DM561P30KT
ELM2DM561Q25KT
ELM2DM681O45KT
ELM2DM681P35KT
ELM2DM681Q30KT
ELM2DM681R25KT
ELM2DM821P45KT
ELM2DM821Q30KT
ELM2DM821R25KT
ELM2DM102P50KT
ELM2DM102Q35KT
ELM2DM102R30KT
ELM2DM122P60KT
ELM2DM122Q40KT
ELM2DM122R35KT
ELM2DM152Q50KT
ELM2DM152R40KT
ELM2DM182Q60KT
ELM2DM182R45KT
ELM2DM222R50KT
ELM2NM151O20KT
ELM2NM181P20KT
ELM2NM221O25KT
ELM2NM221P20KT
ELM2NM271O30KT
ELM2NM271P25KT
ELM2NM271Q20KT
ELM2NM331O35KT
ELM2NM331P25KT
ELM2NM331R20KT
ELM2NM391O35KT
ELM2NM391P30KT
ELM2NM391Q25KT
ELM2NM391R20KT
ELM2NM471O40KT
ELM2NM471P35KT
ELM2NM471Q25KT
ELM2NM561O45KT
ELM2NM561P40KT
ELM2NM561Q30KT
ELM2NM561R25KT
ELM2NM681P45KT
ELM2NM681Q35KT
ELM2NM681R25KT
ELM2NM821P50KT
ELM2NM821Q40KT
ELM2NM821R30KT
ELM2NM102P60KT
ELM2NM102Q45KT
ELM2NM102R35KT
ELM2NM122Q50KT
ELM2NM122R40KT
ELM2NM152Q60KT
ELM2NM152R45KT
ELM2NM182R50KT
ELM2NM222R60KT
270
330
390
470
560
200(2D)
680
820
1000
1200
1500
1800
2200
150
180
220
270
330
390
470
220(2N)
560
680
820
1000
1200
1500
1800
2200
200
Snap-in&Lug
Terminal Type
STANDARD RATINGS
LM series
STANDARD RATINGS
WV
(V dc )
Cap
(µF)
Size
ΦDxL(mm)
tanδ
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
120
150
22×20
25×20
22×25
25×20
22×25
25×25
30×20
22×30
25×25
30×20
22×35
25×30
30×25
35×20
22×40
25×35
30×25
22×45
25×35
30×30
35×25
22×50
25×40
30×30
35×25
25×50
30×35
35×30
25×60
30×40
35×35
30×50
35×40
30×60
35×45
35×50
35×60
22×20
22×20
22×25
25×20
22×25
25×20
30×20
22×30
25×25
30×20
35×20
22×35
25×25
30×25
35×20
22×40
25×30
30×25
35×20
22×45
25×35
30×25
35×25
22×50
25×40
30×30
35×25
25×45
30×35
35×30
25×50
30×40
35×30
30×45
35×35
30×50
35×40
35×45
35×60
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.60
0.74
0.78
0.75
1.00
0.95
0.95
1.18
1.18
1.00
1.30
1.30
1.30
1.16
1.49
1.49
1.49
1.65
1.65
1.65
1.65
1.67
1.80
1.80
1.80
2.00
2.00
2.00
2.20
2.30
2.30
2.47
2.47
2.85
2.60
3.00
3.42
0.45
0.47
0.61
0.56
0.75
0.62
0.65
0.82
0.82
0.70
0.76
0.92
0.92
0.90
0.85
1.04
1.04
1.04
0.90
1.16
1.16
1.16
1.15
1.33
1.33
1.33
1.33
1.47
1.47
1.47
1.70
1.70
1.70
2.05
2.05
2.17
2.17
2.20
2.55
ELM2EM121O20KT
ELM2EM151P20KT
ELM2EM181O25KT
ELM2EM181P20KT
ELM2EM221O25KT
ELM2EM221P25KT
ELM2EM221Q20KT
ELM2EM271O30KT
ELM2EM271P25KT
ELM2EM271Q20KT
ELM2EM331O35KT
ELM2EM331P30KT
ELM2EM331Q25KT
ELM2EM331R20KT
ELM2EM391O40KT
ELM2EM391P35KT
ELM2EM391Q25KT
ELM2EM471O45KT
ELM2EM471P35KT
ELM2EM471Q30KT
ELM2EM471R25KT
ELM2EM561O50KT
ELM2EM561P40KT
ELM2EM561Q30KT
ELM2EM561R25KT
ELM2EM681P50KT
ELM2EM681Q35KT
ELM2EM681R30KT
ELM2EM821P60KT
ELM2EM821Q40KT
ELM2EM821R35KT
ELM2EM102Q50KT
ELM2EM102R40KT
ELM2EM122Q60KT
ELM2EM122R45KT
ELM2EM152R50KT
ELM2EM182R60KT
ELM2FM680O20KT
ELM2FM820O20KT
ELM2FM101O25KT
ELM2FM101P20KT
ELM2FM121O25KT
ELM2FM121P20KT
ELM2FM121Q20KT
ELM2FM151O30KT
ELM2FM151P25KT
ELM2FM151Q20KT
ELM2FM151R20KT
ELM2FM181O35KT
ELM2FM181P25KT
ELM2FM181Q25KT
ELM2FM181R20KT
ELM2FM221O40KT
ELM2FM221P30KT
ELM2FM221Q25KT
ELM2FM221R20KT
ELM2FM271O45KT
ELM2FM271P35KT
ELM2FM271Q25KT
ELM2FM271R25KT
ELM2FM331O50KT
ELM2FM331P40KT
ELM2FM331Q30KT
ELM2FM331R25KT
ELM2FM391P45KT
ELM2FM391Q35KT
ELM2FM391R30KT
ELM2FM471P50KT
ELM2FM471Q40KT
ELM2FM471R30KT
ELM2FM561Q45KT
ELM2FM561R35KT
ELM2FM681Q50KT
ELM2FM681R40KT
ELM2FM821R45KT
ELM2FM102R60KT
180
220
270
330
390
250(2E)
470
560
680
820
1000
1200
1500
1800
68
82
100
120
150
180
220
315(2F)
270
330
390
470
560
680
820
1000
WV
(V dc )
Cap
(µF)
Size
ΦDxL(mm)
tanδ
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
56
68
22×20
25×20
22×25
25×20
22×30
30×20
22×30
25×25
30×20
22×35
25×30
30×25
35×20
22×40
25×30
30×25
22×45
25×35
30×30
35×25
22×50
25×40
30×30
35×25
25×45
30×35
35×30
25×50
30×40
35×35
25×60
30×45
35×35
30×50
35×40
30×60
35×50
35×60
22×20
25×20
22×25
25×20
22×25
30×20
22×30
25×25
30×20
22×35
25×25
30×25
35×20
22×40
25×30
30×25
35×20
22×45
25×35
30×30
35×25
22×50
25×40
30×30
35×25
25×45
30×35
35×30
25×50
30×40
35×30
25×60
30×45
35×35
30×50
35×40
30×60
35×45
35×60
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.41
0.46
0.55
0.51
0.69
0.60
0.75
0.75
0.65
0.82
0.83
0.82
0.76
0.92
0.92
0.90
1.05
1.04
1.02
1.04
1.16
1.18
1.17
1.20
1.29
1.34
1.22
1.51
1.51
1.47
1.66
1.65
1.69
1.85
1.90
2.15
1.99
2.31
0.37
0.42
0.50
0.46
0.64
0.55
0.70
0.70
0.60
0.75
0.75
0.73
0.75
0.88
0.88
0.88
0.80
0.98
0.98
0.98
0.98
1.10
1.10
1.10
1.10
1.22
1.22
1.22
1.44
1.44
1.44
1.51
1.60
1.60
1.90
1.90
2.10
2.12
2.27
ELM2VM560O20KT
ELM2VM680P20KT
ELM2VM820O25KT
ELM2VM820P20KT
ELM2VM101O30KT
ELM2VM101Q20KT
ELM2VM121O30KT
ELM2VM121P25KT
ELM2VM121Q20KT
ELM2VM151O35KT
ELM2VM151P30KT
ELM2VM151Q25KT
ELM2VM151R20KT
ELM2VM181O40KT
ELM2VM181P30KT
ELM2VM181Q25KT
ELM2VM221O45KT
ELM2VM221P35KT
ELM2VM221Q30KT
ELM2VM221R25KT
ELM2VM271O50KT
ELM2VM271P40KT
ELM2VM271Q30KT
ELM2VM271R25KT
ELM2VM331P45KT
ELM2VM331Q35KT
ELM2VM331R30KT
ELM2VM391P50KT
ELM2VM391Q40KT
ELM2VM391R35KT
ELM2VM471P60KT
ELM2VM471Q45KT
ELM2VM471R35KT
ELM2VM561Q50KT
ELM2VM561R40KT
ELM2VM681Q60KT
ELM2VM681R50KT
ELM2VM821R60KT
ELM2GM470O20KT
ELM2GM560P20KT
ELM2GM680O25KT
ELM2GM680P20KT
ELM2GM820O25KT
ELM2GM820Q20KT
ELM2GM101O30KT
ELM2GM101P25KT
ELM2GM101Q20KT
ELM2GM121O35KT
ELM2GM121P25KT
ELM2GM121Q25KT
ELM2GM121R20KT
ELM2GM151O40KT
ELM2GM151P30KT
ELM2GM151Q25KT
ELM2GM151R20KT
ELM2GM181O45KT
ELM2GM181P35KT
ELM2GM181Q30KT
ELM2GM181R25KT
ELM2GM221O50KT
ELM2GM221P40KT
ELM2GM221Q30KT
ELM2GM221R25KT
ELM2GM271P45KT
ELM2GM271Q35KT
ELM2GM271R30KT
ELM2GM331P50KT
ELM2GM331Q40KT
ELM2GM331R30KT
ELM2GM391P60KT
ELM2GM391Q45KT
ELM2GM391R35KT
ELM2GM471Q50KT
ELM2GM471R40KT
ELM2GM561Q60KT
ELM2GM561R45KT
ELM2GM681R60KT
82
100
120
150
180
220
350(2V)
270
330
390
470
560
680
820
47
56
68
82
100
120
150
400(2G)
180
220
270
330
390
470
560
680
201
LM series
STANDARD RATINGS
Cap
(µF)
Size
ΦDxL(mm)
tanδ
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
47
56
22×20
25×20
22×25
25×20
22×25
25×25
30×20
22×30
25×25
30×20
22×35
25×30
30×25
35×20
22×40
25×35
30×25
22×45
25×35
30×30
35×25
22×50
25×45
30×35
35×25
25×50
30×40
35×30
25×60
30×45
35×35
30×50
35×40
30×60
35×45
35×50
35×60
22×25
22×30
25×25
22×30
25×25
22×35
25×30
30×25
22×40
25×30
30×25
35×25
22×45
25×35
30×30
35×25
22×50
25×40
30×30
25×45
30×35
35×30
25×60
30×40
35×35
30×50
35×40
30×60
35×40
35×50
35×60
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.37
0.42
0.50
0.46
0.64
0.58
0.53
0.70
0.70
0.59
0.75
0.75
0.73
0.67
0.88
0.88
0.88
0.95
0.95
0.95
0.94
1.10
1.10
1.10
1.10
1.22
1.22
1.22
1.41
1.45
1.45
1.55
1.55
1.79
1.90
2.15
2.27
0.40
0.53
0.50
0.64
0.64
0.69
0.69
0.64
0.80
0.80
0.80
0.73
0.88
0.88
0.88
0.75
1.00
1.00
1.00
1.12
1.12
1.12
1.18
1.28
1.28
1.45
1.45
1.51
1.55
1.85
1.91
ELM2TM470O20KT
ELM2TM560P20KT
ELM2TM680O25KT
ELM2TM680P20KT
ELM2TM820O25KT
ELM2TM820P25KT
ELM2TM820Q20KT
ELM2TM101O30KT
ELM2TM101P25KT
ELM2TM101Q20KT
ELM2TM121O35KT
ELM2TM121P30KT
ELM2TM121Q25KT
ELM2TM121R20KT
ELM2TM151O40KT
ELM2TM151P35KT
ELM2TM151Q25KT
ELM2TM181O45KT
ELM2TM181P35KT
ELM2TM181Q30KT
ELM2TM181R25KT
ELM2TM221O50KT
ELM2TM221P45KT
ELM2TM221Q35KT
ELM2TM221R25KT
ELM2TM271P50KT
ELM2TM271Q40KT
ELM2TM271R30KT
ELM2TM331P60KT
ELM2TM331Q45KT
ELM2TM331R35KT
ELM2TM391Q50KT
ELM2TM391R40KT
ELM2TM471Q60KT
ELM2TM471R45KT
ELM2TM561R50KT
ELM2TM681R60KT
ELM2WM560O25KT
ELM2WM680O30KT
ELM2WM680P25KT
ELM2WM820O30KT
ELM2WM820P25KT
ELM2WM101O35KT
ELM2WM101P30KT
ELM2WM101Q25KT
ELM2WM121O40KT
ELM2WM121P30KT
ELM2WM121Q25KT
ELM2WM121R25KT
ELM2WM151O45KT
ELM2WM151P35KT
ELM2WM151Q30KT
ELM2WM151R25KT
ELM2WM181O50KT
ELM2WM181P40KT
ELM2WM181Q30KT
ELM2WM221P45KT
ELM2WM221Q35KT
ELM2WM221R30KT
ELM2WM271P60KT
ELM2WM271Q40KT
ELM2WM271R35KT
ELM2WM331Q50KT
ELM2WM331R40KT
ELM2WM391Q60KT
ELM2WM391R40KT
ELM2WM471R50KT
ELM2WM561R60KT
68
82
100
120
150
420(2T)
180
220
270
330
390
470
560
680
56
68
82
100
120
150
450(2W)
180
220
270
330
390
470
560
WV
(V dc )
Cap
(µF)
Size
ΦDxL(mm)
tanδ
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
47
56
68
22×25
22×30
25×25
22×35
25×30
22×45
30×25
22×50
25×35
30×30
25×45
30×35
35×25
25×50
30×40
35×30
30×45
35×35
30×50
35×40
35×45
35×50
35×60
22×35
25×30
22×45
25×35
30×25
22×50
25×40
30×30
35×25
25×45
30×35
25×50
30×40
35×30
30×45
35×35
30×50
35×40
35×45
35×50
35×60
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.51
0.58
0.65
0.72
0.74
0.83
0.82
0.93
0.93
0.91
1.08
1.04
0.99
1.20
1.17
1.10
1.33
1.23
1.50
1.42
1.60
1.78
2.03
0.72
0.74
0.83
0.85
0.82
0.93
0.95
0.91
0.88
1.08
1.04
1.20
1.17
1.10
1.33
1.23
1.50
1.42
1.60
1.64
2.03
ELM2HM470O25KT
ELM2HM560O30KT
ELM2HM680P25KT
ELM2HM820O35KT
ELM2HM820P30KT
ELM2HM101O45KT
ELM2HM101Q25KT
ELM2HM121O50KT
ELM2HM121P35KT
ELM2HM121Q30KT
ELM2HM151P45KT
ELM2HM151Q35KT
ELM2HM151R25KT
ELM2HM181P50KT
ELM2HM181Q40KT
ELM2HM181R30KT
ELM2HM221Q45KT
ELM2HM221R35KT
ELM2HM271Q50KT
ELM2HM271R40KT
ELM2HM331R45KT
ELM2HM391R50KT
ELM2HM471R60KT
ELM2JM820O35KT
ELM2JM820P30KT
ELM2JM101O45KT
ELM2JM101P35KT
ELM2JM101Q25KT
ELM2JM121O50KT
ELM2JM121P40KT
ELM2JM121Q30KT
ELM2JM121R25KT
ELM2JM151P45KT
ELM2JM151Q35KT
ELM2JM181P50KT
ELM2JM181Q40KT
ELM2JM181R30KT
ELM2JM221Q45KT
ELM2JM221R35KT
ELM2JM271Q50KT
ELM2JM271R40KT
ELM2JM331R45KT
ELM2JM391R50KT
ELM2JM471R60KT
82
100
120
500(2H)
150
180
220
270
330
390
470
82
100
120
550(2J)
150
180
220
270
330
390
470
Snap-in&Lug
Terminal Type
WV
(V dc )
202
很抱歉,暂时无法提供与“ELM2DM681P35KT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+11.00520
- 10+9.30960
- 30+8.25120
- 100+7.17120
- 500+6.67440
- 1000+6.46920
