LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS
LT series
Downsized and long life series
Endurance: 5,000 hours at 105°C
RoHS Compliant
SPECIFICATIONS
Items
Characteristics
Category Temperature Range
-25~+105°C
Rated Voltage Range
160~550V.DC
Capacitance Tolerance
±20%(M)
Leakage Current
I≤3 CV
Where, I:Max.leakage current (μA),C:Nominal capacitance (μF),V: Rated voltage (V)
(at 20°C,120Hz)
Rated Voltage(V dc )
Dissipation Factor (tanδ)
160~400
420~550
0.15
0.20
160~250
315~550
Z(-25°C)/Z(+20°C)
4
8
tanδ (max.)
Low Temperature
Characteristics
(Max. Impedance Ratio)
(at 20°C after 5 minutes)
(at 20°C,120Hz)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20°C after DC voltage plus the rated ripple
current is applied for 5,000 hours at 105 °C.
Endurance
Capacitance Change
≤±20% of the initial value
D.F. (tanδ)
≤200% of the initial specified value
(500V dc :≤250%;550V dc :≤300%)
Leakage Current
≤The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20°C after exposing them for 1,000 hours at
105°C without voltage applied.
Shelf Life
Capacitance Change
≤±15% of the initial value
D.F. (tanδ)
≤150% of the initial specified value
Leakage Current
DIMENSIONS[mm]
Terminal Code : K (Φ22 to Φ35) : Standard
Terminal Code : L ( Φ35)
PART NUMBERING SYSTEM
E
LT
2G
M 221 Q25
T
K
Sleeve Code: “C” for PVC, “T” for PET
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
RATED RIPPLE CURRENT MULTIPLIERS
Frequency correction factor for ripple current
Rated
voltage(Vdc)
Freq.(Hz)
120
1k
10k
100k
160~250
1.00
1.32
1.45
1.50
315~550
1.00
1.30
1.41
1.43
The endurance of capacitors is shortened with internal heating produced by ripple
current at the rate of halving the lifetime with every 5°C rise. When long life
performance is required in actual use, the rms ripple current has to be reduced.
211
LT series
STANDARD RATINGS
WV
(V dc )
Cap
(µF)
Size
ΦDxL(mm)
tanδ
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
390
22×25
0.15
1.32
ELT2CM391O25KT
22×30
0.15
1.66
ELT2CM561O30KT
WV
(V dc )
820
1200
1500
tanδ
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
270
22×25
0.15
1.10
ELT2DM271O25KT
22×30
0.15
1.38
ELT2DM391O30KT
25×25
0.15
1.39
ELT2DM391P25KT
22×35
0.15
1.55
ELT2DM471O35KT
22×40
0.15
1.73
ELT2DM561O40KT
25×25
0.15
1.68
ELT2CM561P25KT
22×35
0.15
1.87
ELT2CM681O35KT
25×30
0.15
1.88
ELT2CM681P30KT
30×25
0.15
1.96
ELT2CM681Q25KT
25×30
0.15
1.71
ELT2DM561P30KT
22×40
0.15
2.09
ELT2CM821O40KT
30×25
0.15
1.78
ELT2DM561Q25KT
22×45
0.15
1.81
ELT2DM681O45KT
25×35
0.15
1.87
ELT2DM681P35KT
30×30
0.15
1.98
ELT2DM681Q30KT
35×25
0.15
2.10
ELT2DM681R25KT
22×50
0.15
2.18
ELT2DM821O50KT
25×40
0.15
2.09
ELT2DM821P40KT
22×50
0.15
2.41
ELT2CM102O50KT
25×35
0.15
2.38
ELT2CM102P35KT
30×30
0.15
2.40
ELT2CM102Q30KT
470
560
680
1000
160(2C)
Size
ΦDxL(mm)
390
560
680
Cap
(µF)
35×25
0.15
2.55
ELT2CM102R25KT
25×45
0.15
2.71
ELT2CM122P45KT
200(2D)
820
30×40
0.15
2.77
ELT2CM122Q40KT
35×30
0.15
2.86
ELT2CM122R30KT
30×35
0.15
2.22
ELT2DM821Q35KT
25×50
0.15
3.08
ELT2CM152P50KT
25×50
0.15
2.39
ELT2DM102P50KT
30×45
0.15
3.17
ELT2CM152Q45KT
30×40
0.15
2.53
ELT2DM102Q40KT
35×35
0.15
3.22
ELT2CM152R35KT
35×30
0.15
2.61
ELT2DM102R30KT
30×50
0.15
3.53
ELT2CM182Q50KT
30×50
0.15
2.88
ELT2DM122Q50KT
1000
1200
1800
35×40
0.15
3.66
ELT2CM182R40KT
35×35
0.15
2.88
ELT2DM122R35KT
2200
35×45
0.15
4.14
ELT2CM222R45KT
1500
35×40
0.15
3.34
ELT2DM152R40KT
2700
35×50
0.15
4.68
ELT2CM272R50KT
1800
35×50
0.15
3.82
ELT2DM182R50KT
330
22×25
0.15
1.21
ELT2LM331O25KT
270
22×25
0.15
1.10
ELT2NM271O25KT
22×30
0.15
1.52
ELT2LM471O30KT
330
22×30
0.15
1.19
ELT2NM331O30KT
25×25
0.15
1.52
ELT2LM471P25KT
390
25×25
0.15
1.39
ELT2NM391P25KT
22×35
0.15
1.70
ELT2LM561O35KT
22×35
0.15
1.55
ELT2NM471O35KT
25×30
0.15
1.56
ELT2NM471P30KT
470
560
470
25×30
0.15
1.78
ELT2LM561P30KT
22×40
0.15
1.91
ELT2LM681O40KT
30×25
0.15
1.63
ELT2NM471Q25KT
25×30
0.15
1.88
ELT2LM681P30KT
22×40
0.15
1.73
ELT2NM561O40KT
680
560
22×45
0.15
1.99
ELT2LM821O45KT
30×30
0.15
1.79
ELT2NM561Q30KT
25×35
0.15
2.16
ELT2LM821P35KT
22×50
0.15
1.99
ELT2NM681O50KT
30×30
0.15
2.17
ELT2LM821Q30KT
25×35
0.15
1.96
ELT2NM681P35KT
35×25
0.15
2.31
ELT2LM821R25KT
30×35
0.15
2.02
ELT2NM681Q35KT
22×50
0.15
2.25
ELT2LM102O50KT
35×25
0.15
2.10
ELT2NM681R25KT
25×45
0.15
2.47
ELT2LM102P45KT
25×45
0.15
2.24
ELT2NM821P45KT
30×35
0.15
2.46
ELT2LM102Q35KT
30×40
0.15
2.29
ELT2NM821Q40KT
25×50
0.15
2.75
ELT2LM122P50KT
35×30
0.15
2.36
ELT2NM821R30KT
30×40
0.15
2.77
ELT2LM122Q40KT
25×50
0.15
2.51
ELT2NM102P50KT
35×30
0.15
2.86
ELT2LM122R30KT
30×45
0.15
2.59
ELT2NM102Q45KT
35×35
0.15
2.63
ELT2NM102R35KT
30×50
0.15
2.88
ELT2NM122Q50KT
35×40
0.15
2.98
ELT2NM122R40KT
1500
35×45
0.15
3.41
ELT2NM152R45KT
1800
35×50
0.15
3.82
ELT2NM182R50KT
820
1000
1200
1500
30×50
0.15
3.22
ELT2LM152Q50KT
35×35
0.15
3.22
ELT2LM152R35KT
1800
35×45
0.15
3.74
ELT2LM182R45KT
2200
35×50
0.15
4.22
ELT2LM222R50KT
220(2N)
820
1000
1200
212
Snap-in&Lug
Terminal Type
180(2L)
680
LT series
STANDARD RATINGS
WV
(V dc )
Cap
(µF)
Size
ΦDxL(mm)
tanδ
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
220
22×25
0.15
1.01
270
22×30
0.15
1.20
330
25×25
0.15
22×35
390
470
560
250(2E)
680
820
1000
Cap
(µF)
Size
ΦDxL(mm)
tanδ
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
ELT2EM221O25KT
120
22×25
0.15
0.72
ELT2VM121O25KT
ELT2EM271O30KT
150
22×30
0.15
0.84
ELT2VM151O30KT
1.32
ELT2EM331P25KT
180
25×25
0.15
0.94
ELT2VM181P25KT
0.15
1.44
ELT2EM391O35KT
22×40
0.15
1.06
ELT2VM221O40KT
25×30
0.15
1.43
ELT2EM391P30KT
25×30
0.15
1.07
ELT2VM221P30KT
30×25
0.15
1.51
ELT2EM391Q25KT
30×25
0.15
1.13
ELT2VM221Q25KT
22×40
0.15
1.62
ELT2EM471O40KT
22×45
0.15
1.20
ELT2VM271O45KT
22×50
0.15
1.84
ELT2EM561O50KT
25×35
0.15
1.24
ELT2VM271P35KT
25×35
0.15
1.78
ELT2EM561P35KT
30×30
0.15
1.27
ELT2VM271Q30KT
30×30
0.15
1.83
ELT2EM561Q30KT
35×25
0.15
1.35
ELT2VM271R25KT
35×25
0.15
1.91
ELT2EM561R25KT
22×50
0.15
1.36
ELT2VM331O50KT
25×45
0.15
2.04
ELT2EM681P45KT
25×40
0.15
1.39
ELT2VM331P40KT
30×35
0.15
2.06
ELT2EM681Q35KT
30×35
0.15
1.43
ELT2VM331Q35KT
35×30
0.15
2.15
ELT2EM681R30KT
25×45
0.15
1.55
ELT2VM391P45KT
25×50
0.15
2.28
ELT2EM821P50KT
30×40
0.15
1.60
ELT2VM391Q40KT
30×45
0.15
2.39
ELT2EM821Q45KT
35×30
0.15
1.66
ELT2VM391R30KT
35×35
0.15
2.38
ELT2EM821R35KT
25×50
0.15
1.72
ELT2VM471P50KT
30×50
0.15
2.68
ELT2EM102Q50KT
30×45
0.15
1.81
ELT2VM471Q45KT
WV
(V dc )
220
270
350(2V)
330
390
470
35×40
0.15
2.72
ELT2EM102R40KT
35×35
0.15
1.83
ELT2VM471R35KT
1200
35×45
0.15
3.05
ELT2EM122R45KT
30×50
0.15
2.00
ELT2VM561Q50KT
1500
35×50
0.15
3.49
ELT2EM152R50KT
35×40
0.15
2.07
ELT2VM561R40KT
150
22×25
0.15
0.80
ELT2FM151O25KT
680
35×45
0.15
2.34
ELT2VM681R45KT
22×30
0.15
0.92
ELT2FM181O30KT
820
35×50
0.15
2.62
ELT2VM821R50KT
25×25
0.15
0.94
ELT2FM181P25KT
100
22×25
0.15
0.66
ELT2GM101O25KT
22×35
0.15
1.04
ELT2FM221O35KT
120
22×30
0.15
0.75
ELT2GM121O30KT
30×25
0.15
1.17
ELT2FM221Q25KT
22×35
0.15
0.86
ELT2GM151O35KT
25×25
0.15
0.86
ELT2GM151P25KT
22×40
0.15
0.96
ELT2GM181O40KT
560
180
220
150
22×40
0.15
1.18
ELT2FM271O40KT
25×30
0.15
1.19
ELT2FM271P30KT
22×45
0.15
1.33
ELT2FM331O45KT
25×30
0.15
0.97
ELT2GM181P30KT
25×35
0.15
1.37
ELT2FM331P35KT
30×25
0.15
1.02
ELT2GM181Q25KT
30×30
0.15
1.40
ELT2FM331Q30KT
22×45
0.15
1.09
ELT2GM221O45KT
35×25
0.15
1.49
ELT2FM331R25KT
25×35
0.15
1.12
ELT2GM221P35KT
22×50
0.15
1.48
ELT2FM391O50KT
30×25
0.15
1.22
ELT2GM221Q25KT
25×40
0.15
1.52
ELT2FM391P40KT
22×50
0.15
1.23
ELT2GM271O50KT
25×45
0.15
1.29
ELT2GM271P45KT
30×30
0.15
1.27
ELT2GM271Q30KT
25×50
0.15
1.44
ELT2GM331P50KT
30×35
0.15
1.43
ELT2GM331Q35KT
35×30
0.15
1.52
ELT2GM331R30KT
30×40
0.15
1.60
ELT2GM391Q40KT
35×35
0.15
1.67
ELT2GM391R35KT
30×50
0.15
1.84
ELT2GM471Q50KT
35×40
0.15
1.90
ELT2GM471R40KT
560
35×45
0.15
2.12
ELT2GM561R45KT
680
35×50
0.15
2.39
ELT2GM681R50KT
270
330
315(2F)
390
25×45
0.15
1.70
ELT2FM471P45KT
30×35
0.15
1.71
ELT2FM471Q35KT
35×30
0.15
1.82
ELT2FM471R30KT
25×50
0.15
1.88
ELT2FM561P50KT
30×45
0.15
1.97
ELT2FM561Q45KT
35×35
0.15
2.00
ELT2FM561R35KT
30×50
0.15
2.21
ELT2FM681Q50KT
35×40
0.15
2.29
ELT2FM681R40KT
820
35×45
0.15
2.57
ELT2FM821R45KT
1000
35×50
0.15
2.89
ELT2FM102R50KT
470
560
180
220
400(2G)
270
330
390
680
470
213
LT series
STANDARD RATINGS
Cap
(µF)
Size
ΦDxL(mm)
tanδ
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
Size
ΦDxL(mm)
tanδ
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
100
22×25
0.20
0.66
ELT2TM101O25KT
22×30
0.20
0.75
ELT2TM121O30KT
25×45
0.20
1.16
ELT2WM221P45KT
30×35
0.20
1.17
ELT2WM221Q35KT
25×25
0.20
0.77
22×35
0.20
0.86
ELT2TM121P25KT
35×30
0.20
1.24
ELT2WM221R30KT
ELT2TM151O35KT
25×50
0.20
1.31
22×45
0.20
0.98
ELT2TM181O45KT
ELT2WM271P50KT
25×35
0.20
1.01
ELT2TM181P35KT
30×40
0.20
1.33
ELT2WM271Q40KT
35×35
0.20
1.39
30×25
0.20
1.02
ELT2TM181Q25KT
ELT2WM271R35KT
30×45
0.20
1.51
22×50
0.20
1.11
ELT2WM331Q45KT
ELT2TM221O50KT
25×40
0.20
1.14
ELT2TM221P40KT
30×50
0.20
1.67
ELT2WM391Q50KT
35×45
0.20
1.77
30×30
0.20
1.14
ELT2TM221Q30KT
ELT2WM391R45KT
35×25
0.20
1.22
ELT2TM221R25KT
470
35×50
0.20
1.98
ELT2WM471R50KT
100
30×25
0.20
0.82
25×45
0.20
1.29
ELT2TM271P45KT
ELT2HM101Q25KT
30×35
0.20
1.30
ELT2TM271Q35KT
30×30
0.20
0.91
ELT2HM121Q30KT
35×25
0.20
0.88
35×30
0.20
1.38
ELT2TM271R30KT
ELT2HM121R25KT
30×35
0.20
1.04
25×50
0.20
1.44
ELT2TM331P50KT
ELT2HM151Q35KT
30×40
0.20
1.48
ELT2TM331Q40KT
30×40
0.20
1.17
ELT2HM181Q40KT
35×30
0.20
1.10
35×35
0.20
1.54
ELT2TM331R35KT
ELT2HM181R30KT
30×45
0.20
1.64
ELT2TM391Q45KT
30×45
0.20
1.33
ELT2HM221Q45KT
35×35
0.20
1.23
35×40
0.20
1.73
ELT2TM391R40KT
ELT2HM221R35KT
30×50
0.20
1.50
30×50
0.20
1.84
ELT2TM471Q50KT
ELT2HM271Q50KT
35×45
0.20
1.94
ELT2TM471R45KT
330
35×40
0.20
1.42
ELT2HM271R40KT
35×45
0.20
1.60
560
35×50
0.20
2.17
ELT2TM561R50KT
ELT2HM331R45KT
82
22×25
0.20
0.59
ELT2WM820O25KT
390
35×50
0.20
1.78
ELT2HM391R50KT
470
35×60
0.20
2.03
22×30
0.20
0.69
ELT2HM471R60KT
ELT2WM101O30KT
120
30×30
0.20
0.91
25×25
0.20
ELT2JM121Q30KT
0.70
22×35
ELT2WM101P25KT
150
30×35
0.20
1.04
ELT2JM151Q35KT
0.20
0.77
ELT2WM121O35KT
30×40
0.20
1.17
ELT2JM181Q40KT
22×45
0.20
0.90
ELT2WM151O45KT
35×30
0.20
1.10
ELT2JM181R30KT
25×35
0.20
0.92
ELT2WM151P35KT
30×50
0.20
1.35
ELT2JM221Q50KT
30×25
0.20
0.93
ELT2WM151Q25KT
35×40
0.20
1.28
ELT2JM221R40KT
22×50
0.20
1.01
ELT2WM181O50KT
270
35×45
0.20
1.45
ELT2JM271R45KT
25×40
0.20
1.03
ELT2WM181P40KT
330
35×50
0.20
1.64
ELT2JM331R50KT
30×30
0.20
1.03
ELT2WM181Q30KT
390
35×60
0.20
1.85
ELT2JM391R60KT
35×25
0.20
1.10
ELT2WM181R25KT
WV
(V dc )
Cap
(µF)
220
120
150
270
450(2W)
180
220
420(2T)
270
330
390
470
100
120
330
390
120
150
180
500(2H)
220
270
180
450(2W)
150
180
550(2J)
220
Snap-in&Lug
Terminal Type
WV
(V dc )
214
很抱歉,暂时无法提供与“ELT2DM821P40KT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+14.46120
- 10+12.34440
- 30+11.02680
- 100+8.51580
- 500+7.93098
- 1000+7.67448
