LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS
LX series
Extremely long life
Endurance: 7,000 hours at 105°C
RoHS Compliant
SPECIFICATIONS
Items
Characteristics
Category Temperature Range
-25~+105°C
Rated Voltage Range
160~450V.DC
Capacitance Tolerance
±20%(M)
Leakage Current
I≤3 CV
Where, I:Max.leakage current (μA),C:Nominal capacitance (μF),V: Rated voltage (V)
(at 20°C,120Hz)
Rated Voltage(V dc )
Dissipation Factor (tanδ)
160~400
420~450
0.15
0.20
160~400
420~450
Z(-25°C)/Z(+20°C)
4
8
tanδ (max.)
Low Temperature
Characteristics
(Max. Impedance Ratio)
(at 20°C after 5 minutes)
(at 20°C,120Hz)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20°C after DC voltage plus the rated ripple
current is applied for 7,000 hours at 105 °C.
Endurance
Capacitance Change
≤±20% of the initial value
D.F. (tanδ)
≤250% of the initial specified value
Leakage Current
≤The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20°C after exposing them for 1,000 hours at
105°C without voltage applied.
Shelf Life
Capacitance Change
≤±15% of the initial value
D.F. (tanδ)
≤150% of the initial specified value
Leakage Current
DIMENSIONS[mm]
Terminal Code : K (Φ22 to Φ35) : Standard
Terminal Code : L ( Φ35)
PART NUMBERING SYSTEM
E
LX 2G
M 101 P25
T
K
Sleeve Code: “C” for PVC, “T” for PET
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
RATED RIPPLE CURRENT MULTIPLIERS
Frequency correction factor for ripple current
Freq.(Hz)
Rated
voltage(Vdc)
120
1k
10k
100k
160~250
1.00
1.32
1.45
1.50
315~450
1.00
1.30
1.41
1.43
The endurance of capacitors is shortened with internal heating produced by ripple
current at the rate of halving the lifetime with every 5°C rise. When long life
performance is required in actual use, the rms ripple current has to be reduced.
215
LX series
WV
(V dc )
Part Number
Size
ΦDxL(mm)
tanδ
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
0.15
1.11
ELX2CM331O25KT
0.15
1.26
ELX2CM391O30KT
25×40
0.15
1.83
ELX2DM681P40KT
30×30
0.15
1.79
22×30
0.15
1.39
ELX2CM471O30KT
ELX2DM681Q30KT
25×45
0.15
2.06
25×25
0.15
1.38
ELX2CM471P25KT
ELX2DM821P45KT
30×35
0.15
2.04
22×35
0.15
1.55
ELX2CM561O35KT
ELX2DM821Q35KT
30×45
0.15
2.42
25×30
0.15
1.55
ELX2CM561P30KT
ELX2DM102Q45KT
35×30
0.15
2.30
22×40
0.15
1.75
ELX2CM681O40KT
ELX2DM102R30KT
30×50
0.15
2.71
25×35
0.15
1.78
ELX2CM681P35KT
ELX2DM122Q50KT
35×40
0.15
2.70
30×25
0.15
1.74
ELX2CM681Q25KT
ELX2DM122R40KT
1500
35×45
0.15
3.11
22×50
0.15
1.97
ELX2DM152R45KT
ELX2CM821O50KT
1800
35×50
0.15
3.50
25×40
0.15
ELX2DM182R50KT
2.01
ELX2CM821P40KT
220
22×25
0.15
0.90
30×30
ELX2NM221O25KT
0.15
1.96
ELX2CM821Q30KT
270
22×30
0.15
1.05
ELX2NM271O30KT
25×45
0.15
2.27
ELX2CM102P45KT
22×35
0.15
1.19
ELX2NM331O35KT
30×35
0.15
2.26
ELX2CM102Q35KT
25×25
0.15
1.16
ELX2NM331P25KT
25×50
0.15
2.54
ELX2CM122P50KT
22×40
0.15
1.33
ELX2NM391O40KT
30×40
0.15
2.56
ELX2CM122Q40KT
25×30
0.15
1.29
ELX2NM391P30KT
35×30
0.15
2.52
ELX2CM122R30KT
22×45
0.15
1.49
ELX2NM471O45KT
30×45
0.15
2.96
ELX2CM152Q45KT
25×35
0.15
1.48
ELX2NM471P35KT
35×35
0.15
2.89
ELX2CM152R35KT
30×25
0.15
1.45
ELX2NM471Q25KT
30×50
0.15
3.32
ELX2CM182Q50KT
22×50
0.15
1.63
ELX2NM561O50KT
35×40
0.15
3.30
ELX2CM182R40KT
25×40
0.15
1.71
ELX2NM561P40KT
2200
35×50
0.15
3.87
ELX2CM222R50KT
30×30
0.15
1.62
ELX2NM561Q30KT
270
22×25
0.15
1.00
ELX2LM271O25KT
25×45
0.15
1.87
ELX2NM681P45KT
330
22×30
0.15
1.16
ELX2LM331O30KT
30×35
0.15
1.86
ELX2NM681Q35KT
22×30
0.15
1.26
ELX2LM391O30KT
25×50
0.15
2.10
ELX2NM821P50KT
25×25
0.15
1.26
ELX2LM391P25KT
30×40
0.15
2.12
ELX2NM821Q40KT
22×35
0.15
1.42
ELX2LM471O35KT
35×30
0.15
2.08
ELX2NM821R30KT
25×30
0.15
1.42
ELX2LM471P30KT
30×50
0.15
2.48
ELX2NM102Q50KT
22×40
0.15
1.59
ELX2LM561O40KT
35×40
0.15
2.46
ELX2NM102R40KT
25×30
0.15
1.55
ELX2LM561P30KT
1200
35×45
0.15
2.78
ELX2NM122R45KT
30×25
0.15
1.58
ELX2LM561Q25KT
1500
35×50
0.15
3.20
ELX2NM152R50KT
22×45
0.15
1.79
ELX2LM681O45KT
180
22×25
0.15
0.82
ELX2EM181O25KT
25×35
0.15
1.78
ELX2LM681P35KT
220
22×30
0.15
0.95
ELX2EM221O30KT
30×30
0.15
1.79
ELX2LM681Q30KT
22×35
0.15
1.08
ELX2EM271O35KT
25×40
0.15
2.01
ELX2LM821P40KT
25×25
0.15
1.05
ELX2EM271P25KT
30×35
0.15
2.04
ELX2LM821Q35KT
22×40
0.15
1.22
ELX2EM331O40KT
25×50
0.15
2.32
ELX2LM102P50KT
25×30
0.15
1.19
ELX2EM331P30KT
30×35
0.15
2.26
ELX2LM102Q35KT
22×45
0.15
1.36
ELX2EM391O45KT
35×30
0.15
2.30
ELX2LM102R30KT
25×35
0.15
1.35
ELX2EM391P35KT
30×45
0.15
2.65
ELX2LM122Q45KT
30×25
0.15
1.32
ELX2EM391Q25KT
35×35
0.15
2.58
ELX2LM122R35KT
22×50
0.15
1.49
ELX2EM471O50KT
30×50
0.15
3.03
ELX2LM152Q50KT
25×40
0.15
1.52
ELX2EM471P40KT
35×40
0.15
3.01
ELX2LM152R40KT
30×30
0.15
1.49
ELX2EM471Q30KT
1800
35×45
0.15
3.41
ELX2LM182R45KT
25×45
0.15
1 70
ELX2EM561P45KT
2200
35×50
0.15
3.87
ELX2LM222R50KT
30×35
0.15
1.69
ELX2EM561Q35KT
220
22×25
0.15
0.90
ELX2DM221O25KT
25×50
0.15
1.91
ELX2EM681P50KT
270
22×30
0.15
1.05
ELX2DM271O30KT
30×40
0.15
1.93
ELX2EM681Q40KT
22×30
0.15
1.16
ELX2DM331O30KT
35×30
0.15
1.90
ELX2EM681R30KT
25×25
0.15
1.16
ELX2DM331P25KT
30×45
0.15
2.19
ELX2EM821Q45KT
22×35
0.15
1.29
ELX2DM391O35KT
35×35
0.15
2.13
ELX2EM821R35KT
25×30
0.15
1.29
ELX2DM391P30KT
1000
35×40
0.15
2.46
ELX2EM102R40KT
22×40
0.15
1.46
ELX2DM471O40KT
1200
35×50
0.15
2.86
ELX2EM122R50KT
25×30
0.15
1.42
ELX2DM471P30KT
100
22×25
0.15
0.67
ELX2FM101O25KT
30×25
0.15
1.45
ELX2DM471Q25KT
120
22×30
0.15
0.77
ELX2FM121O30KT
22×45
0.15
1.63
ELX2DM561O45KT
22×30
0.15
0.86
ELX2FM151O30KT
25×35
0.15
1.62
ELX2DM561P35KT
25×25
0.15
0.85
ELX2FM151P25KT
30×30
0.15
1.62
ELX2DM561Q30KT
Size
ΦDxL(mm)
tanδ
330
22×25
390
22×30
470
560
680
160(2C)
Rated ripple
current
(Arms/105°C,
120Hz)
Cap
(µF)
820
1000
1200
1500
1800
390
470
560
680
180(2L)
820
1000
1200
1500
330
390
200(2D)
470
560
WV
(V dc )
Cap
(µF)
680
820
200(2D)
1000
1200
330
390
470
220(2N)
560
680
820
1000
270
330
390
250(2E)
470
560
680
820
315(2F)
150
216
Snap-in&Lug
Terminal Type
STANDARD RATINGS
LX series
STANDARD RATINGS
WV
(V dc )
Size
ΦDxL(mm)
tanδ
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
25×50
0.15
1.32
ELX2GM271P50KT
30×40
0.15
1.33
ELX2GM271Q40KT
ELX2FM221O40KT
35×30
0.15
1.31
ELX2GM271R30KT
1.06
ELX2FM221P30KT
30×45
0.15
1.52
ELX2GM331Q45KT
0.15
1.08
ELX2FM221Q25KT
35×35
0.15
1.48
ELX2GM331R35KT
22×45
0.15
1.24
ELX2FM271O45KT
30×50
0.15
1.69
ELX2GM391Q50KT
25×35
0.15
1.23
ELX2FM271P35KT
35×40
0.15
1.68
ELX2GM391R40KT
30×30
0.15
1.23
ELX2FM271Q30KT
470
35×45
0.15
1.91
ELX2GM471R45KT
25×40
0.15
1.40
ELX2FM331P40KT
560
35×50
0.15
2.14
ELX2GM561R50KT
30×35
0.15
1.42
ELX2FM331Q35KT
56
22×25
0.20
0.50
ELX2TM560O25KT
35×30
0.15
1.45
ELX2FM331R30KT
68
22×30
0.20
0.58
ELX2TM680O30KT
25×50
0.15
1.59
ELX2FM391P50KT
22×30
0.20
0.63
ELX2TM820O30KT
30×35
0.15
1.54
ELX2FM391Q35KT
25×25
0.20
0.63
ELX2TM820P25KT
35×30
0.15
1.57
ELX2FM391R30KT
22×35
0.20
0.72
ELX2TM101O35KT
30×45
0.15
1.81
ELX2FM471Q45KT
25×30
0.20
0.72
ELX2TM101P30KT
35×35
0.15
1.77
ELX2FM471R35KT
22×40
0.20
0.81
ELX2TM121O40KT
30×50
0.15
2.03
ELX2FM561Q50KT
25×30
0.20
0.79
ELX2TM121P30KT
35×40
0.15
2.02
ELX2FM561R40KT
30×25
0.20
0.80
ELX2TM121Q25KT
680
35×45
0.15
2.29
ELX2FM681R45KT
22×45
0.20
0.92
ELX2TM151O45KT
820
35×50
0.15
2.59
ELX2FM821R50KT
25×35
0.20
0.92
ELX2TM151P35KT
100
22×25
0.15
0.67
ELX2VM101O25KT
30×30
0.20
0.92
ELX2TM151Q30KT
22×30
0.15
0.77
ELX2VM121O30KT
25×40
0.20
1.03
ELX2TM181P40KT
25×25
0.15
0.76
ELX2VM121P25KT
30×35
0.20
1.05
ELX2TM181Q35KT
22×35
0.15
0.88
ELX2VM151O35KT
25×50
0.20
1.19
ELX2TM221P50KT
25×30
0.15
0.88
ELX2VM151P30KT
30×35
0.20
1.16
ELX2TM221Q35KT
22×40
0.15
0.99
ELX2VM181O40KT
35×30
0.20
1.18
ELX2TM221R30KT
25×30
0.15
0.96
ELX2VM181P30KT
30×45
0.20
1.38
ELX2TM271Q45KT
30×25
0.15
0.98
ELX2VM181Q25KT
35×35
0.20
1.34
ELX2TM271R35KT
22×45
0.15
1.12
ELX2VM221O45KT
30×50
0.20
1.56
ELX2TM331Q50KT
25×35
0.15
1.11
ELX2VM221P35KT
35×40
0.20
1.55
ELX2TM331R40KT
30×30
0.15
1.11
ELX2VM221Q30KT
390
35×45
0.20
1.74
ELX2TM391R45KT
25×40
0.15
1.26
ELX2VM271P40KT
470
35×50
0.20
1.96
ELX2TM471R50KT
30×35
0.15
1.28
ELX2VM271Q35KT
47
22×25
0.20
0.46
ELX2WM470O25KT
25×45
0.15
1.40
ELX2VM331P45KT
56
22×30
0.20
0.52
ELX2WM560O30KT
30×35
0.15
1.42
ELX2VM331Q35KT
22×30
0.20
0.58
ELX2WM680O30KT
35×30
0.15
1.45
ELX2VM331R30KT
25×25
0.20
0.58
ELX2WM680P25KT
30×40
0.15
1.60
ELX2VM391Q40KT
22×35
0.20
0.65
ELX2WM820O35KT
35×35
0.15
1.61
ELX2VM391R35KT
25×30
0.20
0.65
ELX2WM820P30KT
30×50
0.15
1.86
ELX2VM471Q50KT
22×40
0.20
0.74
ELX2WM101O40KT
35×40
0.15
1.85
ELX2VM471R40KT
25×30
0.20
0.72
ELX2WM101P30KT
560
35×40
0.15
2.02
ELX2VM561R40KT
30×25
0.20
0.73
ELX2WM101Q25KT
680
35×50
0.15
2.36
ELX2VM681R50KT
22×45
0.20
0.83
ELX2WM121O45KT
68
22×25
0.15
0.55
ELX2GM680O25KT
25×35
0.20
0.82
ELX2WM121P35KT
82
22×30
0.15
0.63
ELX2GM820O30KT
30×30
0.20
0.82
ELX2WM121Q30KT
22×30
0.15
0.70
ELX2GM101O30KT
25×40
0.20
0.94
ELX2WM151P40KT
25×25
0.15
0.70
ELX2GM101P25KT
30×35
0.20
0.96
ELX2WM151Q35KT
22×35
0.15
0.79
ELX2GM121O35KT
25×45
0.20
1.06
ELX2WM181P45KT
25×30
0.15
0.79
ELX2GM121P30KT
30×35
0.20
1.05
ELX2WM181Q35KT
22×40
0.15
0.90
ELX2GM151O40KT
35×30
0.20
1.07
ELX2WM181R30KT
25×30
0.15
0.88
ELX2GM151P30KT
30×40
0.20
1.20
ELX2WM221Q40KT
30×25
0.15
0.90
ELX2GM151Q25KT
35×35
0.20
1.21
ELX2WM221R35KT
22×45
0.15
0.99
ELX2GM181O45KT
30×50
0.20
1.41
ELX2WM271Q50KT
25×35
0.15
1.01
ELX2GM181P35KT
35×40
0.20
1.40
ELX2WM271R40KT
30×30
0.15
1.01
ELX2GM181Q30KT
330
35×45
0.20
1.60
ELX2WM331R45KT
25×40
0.15
1.14
ELX2GM221P40KT
390
35×50
0.20
1.79
ELX2WM391R50KT
30×35
0.15
1.16
ELX2GM221Q35KT
Cap
(µF)
180
220
270
315(2F)
330
390
470
560
120
150
180
220
350(2V)
270
330
390
470
100
120
400(2G)
150
180
220
Size
ΦDxL(mm)
tanδ
Rated ripple
current
(Arms/105°C,
120Hz)
Part Number
22×35
0.15
0.96
ELX2FM181O35KT
25×30
0.15
0.96
ELX2FM181P30KT
22×40
0.15
1.09
25×30
0.15
30×25
WV
(V dc )
Cap
(µF)
270
400(2G)
330
390
82
100
120
150
420(2T)
180
220
270
330
68
82
100
120
450(2W)
150
180
220
270
217
很抱歉,暂时无法提供与“ELX2WM121Q30KT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+7.29000
- 10+7.11720
- 30+6.99840
