ELX2WM151P40KT
ELX2WM151P40KT
    AISHI(艾华集团)
    插件,D25xL40mm
    直插铝电解电容 插件,D25xL40mm 150µF ±20% Ф25.00 x 40.00mm 450V 940mA 7000Hrs@105℃
ELX2WM151P40KT 数据手册
LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS LX series Extremely long life Endurance: 7,000 hours at 105°C RoHS Compliant SPECIFICATIONS Items Characteristics Category Temperature Range -25~+105°C Rated Voltage Range 160~450V.DC Capacitance Tolerance ±20%(M) Leakage Current I≤3 CV Where, I:Max.leakage current (μA),C:Nominal capacitance (μF),V: Rated voltage (V) (at 20°C,120Hz) Rated Voltage(V dc ) Dissipation Factor (tanδ) 160~400 420~450 0.15 0.20 Rated Voltage(V dc ) 160~400 420~450 Z(-25°C)/Z(+20°C) 4 8 tanδ (max.) Low Temperature Characteristics (Max. Impedance Ratio) (at 20°C after 5 minutes) (at 20°C,120Hz) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20°C after DC voltage plus the rated ripple current is applied for 7,000 hours at 105 °C. Endurance Capacitance Change ≤±20% of the initial value D.F. (tanδ) ≤250% of the initial specified value Leakage Current ≤The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20°C after exposing them for 1,000 hours at 105°C without voltage applied. Shelf Life Capacitance Change ≤±15% of the initial value D.F. (tanδ) ≤150% of the initial specified value Leakage Current ≤150% of the initial specified value DIMENSIONS[mm] Terminal Code : K (Φ22 to Φ35) : Standard Terminal Code : L ( Φ35) PART NUMBERING SYSTEM E LX 2G M 101 P25 T K Sleeve Code: “C” for PVC, “T” for PET Terminal code Size code Capacitance code Capacitance tolerance code Voltage code Series code Category code RATED RIPPLE CURRENT MULTIPLIERS Frequency correction factor for ripple current Freq.(Hz) Rated voltage(Vdc) 120 1k 10k 100k 160~250 1.00 1.32 1.45 1.50 315~450 1.00 1.30 1.41 1.43 The endurance of capacitors is shortened with internal heating produced by ripple current at the rate of halving the lifetime with every 5°C rise. When long life performance is required in actual use, the rms ripple current has to be reduced. 215 LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS LX series WV (V dc ) Part Number Size ΦDxL(mm) tanδ Rated ripple current (Arms/105°C, 120Hz) Part Number 0.15 1.11 ELX2CM331O25KT 0.15 1.26 ELX2CM391O30KT 25×40 0.15 1.83 ELX2DM681P40KT 30×30 0.15 1.79 22×30 0.15 1.39 ELX2CM471O30KT ELX2DM681Q30KT 25×45 0.15 2.06 25×25 0.15 1.38 ELX2CM471P25KT ELX2DM821P45KT 30×35 0.15 2.04 22×35 0.15 1.55 ELX2CM561O35KT ELX2DM821Q35KT 30×45 0.15 2.42 25×30 0.15 1.55 ELX2CM561P30KT ELX2DM102Q45KT 35×30 0.15 2.30 22×40 0.15 1.75 ELX2CM681O40KT ELX2DM102R30KT 30×50 0.15 2.71 25×35 0.15 1.78 ELX2CM681P35KT ELX2DM122Q50KT 35×40 0.15 2.70 30×25 0.15 1.74 ELX2CM681Q25KT ELX2DM122R40KT 1500 35×45 0.15 3.11 22×50 0.15 1.97 ELX2DM152R45KT ELX2CM821O50KT 1800 35×50 0.15 3.50 25×40 0.15 ELX2DM182R50KT 2.01 ELX2CM821P40KT 220 22×25 0.15 0.90 30×30 ELX2NM221O25KT 0.15 1.96 ELX2CM821Q30KT 270 22×30 0.15 1.05 ELX2NM271O30KT 25×45 0.15 2.27 ELX2CM102P45KT 22×35 0.15 1.19 ELX2NM331O35KT 30×35 0.15 2.26 ELX2CM102Q35KT 25×25 0.15 1.16 ELX2NM331P25KT 25×50 0.15 2.54 ELX2CM122P50KT 22×40 0.15 1.33 ELX2NM391O40KT 30×40 0.15 2.56 ELX2CM122Q40KT 25×30 0.15 1.29 ELX2NM391P30KT 35×30 0.15 2.52 ELX2CM122R30KT 22×45 0.15 1.49 ELX2NM471O45KT 30×45 0.15 2.96 ELX2CM152Q45KT 25×35 0.15 1.48 ELX2NM471P35KT 35×35 0.15 2.89 ELX2CM152R35KT 30×25 0.15 1.45 ELX2NM471Q25KT 30×50 0.15 3.32 ELX2CM182Q50KT 22×50 0.15 1.63 ELX2NM561O50KT 35×40 0.15 3.30 ELX2CM182R40KT 25×40 0.15 1.71 ELX2NM561P40KT 2200 35×50 0.15 3.87 ELX2CM222R50KT 30×30 0.15 1.62 ELX2NM561Q30KT 270 22×25 0.15 1.00 ELX2LM271O25KT 25×45 0.15 1.87 ELX2NM681P45KT 330 22×30 0.15 1.16 ELX2LM331O30KT 30×35 0.15 1.86 ELX2NM681Q35KT 22×30 0.15 1.26 ELX2LM391O30KT 25×50 0.15 2.10 ELX2NM821P50KT 25×25 0.15 1.26 ELX2LM391P25KT 30×40 0.15 2.12 ELX2NM821Q40KT 22×35 0.15 1.42 ELX2LM471O35KT 35×30 0.15 2.08 ELX2NM821R30KT 25×30 0.15 1.42 ELX2LM471P30KT 30×50 0.15 2.48 ELX2NM102Q50KT 22×40 0.15 1.59 ELX2LM561O40KT 35×40 0.15 2.46 ELX2NM102R40KT 25×30 0.15 1.55 ELX2LM561P30KT 1200 35×45 0.15 2.78 ELX2NM122R45KT 30×25 0.15 1.58 ELX2LM561Q25KT 1500 35×50 0.15 3.20 ELX2NM152R50KT 22×45 0.15 1.79 ELX2LM681O45KT 180 22×25 0.15 0.82 ELX2EM181O25KT 25×35 0.15 1.78 ELX2LM681P35KT 220 22×30 0.15 0.95 ELX2EM221O30KT 30×30 0.15 1.79 ELX2LM681Q30KT 22×35 0.15 1.08 ELX2EM271O35KT 25×40 0.15 2.01 ELX2LM821P40KT 25×25 0.15 1.05 ELX2EM271P25KT 30×35 0.15 2.04 ELX2LM821Q35KT 22×40 0.15 1.22 ELX2EM331O40KT 25×50 0.15 2.32 ELX2LM102P50KT 25×30 0.15 1.19 ELX2EM331P30KT 30×35 0.15 2.26 ELX2LM102Q35KT 22×45 0.15 1.36 ELX2EM391O45KT 35×30 0.15 2.30 ELX2LM102R30KT 25×35 0.15 1.35 ELX2EM391P35KT 30×45 0.15 2.65 ELX2LM122Q45KT 30×25 0.15 1.32 ELX2EM391Q25KT 35×35 0.15 2.58 ELX2LM122R35KT 22×50 0.15 1.49 ELX2EM471O50KT 30×50 0.15 3.03 ELX2LM152Q50KT 25×40 0.15 1.52 ELX2EM471P40KT 35×40 0.15 3.01 ELX2LM152R40KT 30×30 0.15 1.49 ELX2EM471Q30KT 1800 35×45 0.15 3.41 ELX2LM182R45KT 25×45 0.15 1 70 ELX2EM561P45KT 2200 35×50 0.15 3.87 ELX2LM222R50KT 30×35 0.15 1.69 ELX2EM561Q35KT 220 22×25 0.15 0.90 ELX2DM221O25KT 25×50 0.15 1.91 ELX2EM681P50KT 270 22×30 0.15 1.05 ELX2DM271O30KT 30×40 0.15 1.93 ELX2EM681Q40KT 22×30 0.15 1.16 ELX2DM331O30KT 35×30 0.15 1.90 ELX2EM681R30KT 25×25 0.15 1.16 ELX2DM331P25KT 30×45 0.15 2.19 ELX2EM821Q45KT 22×35 0.15 1.29 ELX2DM391O35KT 35×35 0.15 2.13 ELX2EM821R35KT 25×30 0.15 1.29 ELX2DM391P30KT 1000 35×40 0.15 2.46 ELX2EM102R40KT 22×40 0.15 1.46 ELX2DM471O40KT 1200 35×50 0.15 2.86 ELX2EM122R50KT 25×30 0.15 1.42 ELX2DM471P30KT 100 22×25 0.15 0.67 ELX2FM101O25KT 30×25 0.15 1.45 ELX2DM471Q25KT 120 22×30 0.15 0.77 ELX2FM121O30KT 22×45 0.15 1.63 ELX2DM561O45KT 22×30 0.15 0.86 ELX2FM151O30KT 25×35 0.15 1.62 ELX2DM561P35KT 25×25 0.15 0.85 ELX2FM151P25KT 30×30 0.15 1.62 ELX2DM561Q30KT Size ΦDxL(mm) tanδ 330 22×25 390 22×30 470 560 680 160(2C) Rated ripple current (Arms/105°C, 120Hz) Cap (µF) 820 1000 1200 1500 1800 390 470 560 680 180(2L) 820 1000 1200 1500 330 390 200(2D) 470 560 WV (V dc ) Cap (µF) 680 820 200(2D) 1000 1200 330 390 470 220(2N) 560 680 820 1000 270 330 390 250(2E) 470 560 680 820 315(2F) 150 216 Snap-in&Lug Terminal Type STANDARD RATINGS LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS LX series STANDARD RATINGS WV (V dc ) Size ΦDxL(mm) tanδ Rated ripple current (Arms/105°C, 120Hz) Part Number 25×50 0.15 1.32 ELX2GM271P50KT 30×40 0.15 1.33 ELX2GM271Q40KT ELX2FM221O40KT 35×30 0.15 1.31 ELX2GM271R30KT 1.06 ELX2FM221P30KT 30×45 0.15 1.52 ELX2GM331Q45KT 0.15 1.08 ELX2FM221Q25KT 35×35 0.15 1.48 ELX2GM331R35KT 22×45 0.15 1.24 ELX2FM271O45KT 30×50 0.15 1.69 ELX2GM391Q50KT 25×35 0.15 1.23 ELX2FM271P35KT 35×40 0.15 1.68 ELX2GM391R40KT 30×30 0.15 1.23 ELX2FM271Q30KT 470 35×45 0.15 1.91 ELX2GM471R45KT 25×40 0.15 1.40 ELX2FM331P40KT 560 35×50 0.15 2.14 ELX2GM561R50KT 30×35 0.15 1.42 ELX2FM331Q35KT 56 22×25 0.20 0.50 ELX2TM560O25KT 35×30 0.15 1.45 ELX2FM331R30KT 68 22×30 0.20 0.58 ELX2TM680O30KT 25×50 0.15 1.59 ELX2FM391P50KT 22×30 0.20 0.63 ELX2TM820O30KT 30×35 0.15 1.54 ELX2FM391Q35KT 25×25 0.20 0.63 ELX2TM820P25KT 35×30 0.15 1.57 ELX2FM391R30KT 22×35 0.20 0.72 ELX2TM101O35KT 30×45 0.15 1.81 ELX2FM471Q45KT 25×30 0.20 0.72 ELX2TM101P30KT 35×35 0.15 1.77 ELX2FM471R35KT 22×40 0.20 0.81 ELX2TM121O40KT 30×50 0.15 2.03 ELX2FM561Q50KT 25×30 0.20 0.79 ELX2TM121P30KT 35×40 0.15 2.02 ELX2FM561R40KT 30×25 0.20 0.80 ELX2TM121Q25KT 680 35×45 0.15 2.29 ELX2FM681R45KT 22×45 0.20 0.92 ELX2TM151O45KT 820 35×50 0.15 2.59 ELX2FM821R50KT 25×35 0.20 0.92 ELX2TM151P35KT 100 22×25 0.15 0.67 ELX2VM101O25KT 30×30 0.20 0.92 ELX2TM151Q30KT 22×30 0.15 0.77 ELX2VM121O30KT 25×40 0.20 1.03 ELX2TM181P40KT 25×25 0.15 0.76 ELX2VM121P25KT 30×35 0.20 1.05 ELX2TM181Q35KT 22×35 0.15 0.88 ELX2VM151O35KT 25×50 0.20 1.19 ELX2TM221P50KT 25×30 0.15 0.88 ELX2VM151P30KT 30×35 0.20 1.16 ELX2TM221Q35KT 22×40 0.15 0.99 ELX2VM181O40KT 35×30 0.20 1.18 ELX2TM221R30KT 25×30 0.15 0.96 ELX2VM181P30KT 30×45 0.20 1.38 ELX2TM271Q45KT 30×25 0.15 0.98 ELX2VM181Q25KT 35×35 0.20 1.34 ELX2TM271R35KT 22×45 0.15 1.12 ELX2VM221O45KT 30×50 0.20 1.56 ELX2TM331Q50KT 25×35 0.15 1.11 ELX2VM221P35KT 35×40 0.20 1.55 ELX2TM331R40KT 30×30 0.15 1.11 ELX2VM221Q30KT 390 35×45 0.20 1.74 ELX2TM391R45KT 25×40 0.15 1.26 ELX2VM271P40KT 470 35×50 0.20 1.96 ELX2TM471R50KT 30×35 0.15 1.28 ELX2VM271Q35KT 47 22×25 0.20 0.46 ELX2WM470O25KT 25×45 0.15 1.40 ELX2VM331P45KT 56 22×30 0.20 0.52 ELX2WM560O30KT 30×35 0.15 1.42 ELX2VM331Q35KT 22×30 0.20 0.58 ELX2WM680O30KT 35×30 0.15 1.45 ELX2VM331R30KT 25×25 0.20 0.58 ELX2WM680P25KT 30×40 0.15 1.60 ELX2VM391Q40KT 22×35 0.20 0.65 ELX2WM820O35KT 35×35 0.15 1.61 ELX2VM391R35KT 25×30 0.20 0.65 ELX2WM820P30KT 30×50 0.15 1.86 ELX2VM471Q50KT 22×40 0.20 0.74 ELX2WM101O40KT 35×40 0.15 1.85 ELX2VM471R40KT 25×30 0.20 0.72 ELX2WM101P30KT 560 35×40 0.15 2.02 ELX2VM561R40KT 30×25 0.20 0.73 ELX2WM101Q25KT 680 35×50 0.15 2.36 ELX2VM681R50KT 22×45 0.20 0.83 ELX2WM121O45KT 68 22×25 0.15 0.55 ELX2GM680O25KT 25×35 0.20 0.82 ELX2WM121P35KT 82 22×30 0.15 0.63 ELX2GM820O30KT 30×30 0.20 0.82 ELX2WM121Q30KT 22×30 0.15 0.70 ELX2GM101O30KT 25×40 0.20 0.94 ELX2WM151P40KT 25×25 0.15 0.70 ELX2GM101P25KT 30×35 0.20 0.96 ELX2WM151Q35KT 22×35 0.15 0.79 ELX2GM121O35KT 25×45 0.20 1.06 ELX2WM181P45KT 25×30 0.15 0.79 ELX2GM121P30KT 30×35 0.20 1.05 ELX2WM181Q35KT 22×40 0.15 0.90 ELX2GM151O40KT 35×30 0.20 1.07 ELX2WM181R30KT 25×30 0.15 0.88 ELX2GM151P30KT 30×40 0.20 1.20 ELX2WM221Q40KT 30×25 0.15 0.90 ELX2GM151Q25KT 35×35 0.20 1.21 ELX2WM221R35KT 22×45 0.15 0.99 ELX2GM181O45KT 30×50 0.20 1.41 ELX2WM271Q50KT 25×35 0.15 1.01 ELX2GM181P35KT 35×40 0.20 1.40 ELX2WM271R40KT 30×30 0.15 1.01 ELX2GM181Q30KT 330 35×45 0.20 1.60 ELX2WM331R45KT 25×40 0.15 1.14 ELX2GM221P40KT 390 35×50 0.20 1.79 ELX2WM391R50KT 30×35 0.15 1.16 ELX2GM221Q35KT Cap (µF) 180 220 270 315(2F) 330 390 470 560 120 150 180 220 350(2V) 270 330 390 470 100 120 400(2G) 150 180 220 Size ΦDxL(mm) tanδ Rated ripple current (Arms/105°C, 120Hz) Part Number 22×35 0.15 0.96 ELX2FM181O35KT 25×30 0.15 0.96 ELX2FM181P30KT 22×40 0.15 1.09 25×30 0.15 30×25 WV (V dc ) Cap (µF) 270 400(2G) 330 390 82 100 120 150 420(2T) 180 220 270 330 68 82 100 120 450(2W) 150 180 220 270 217
ELX2WM151P40KT 价格&库存
很抱歉,暂时无法提供与“ELX2WM151P40KT”相匹配的价格&库存,您可以联系我们找货
ELX2WM151P40KT
    • 1+12.93840
    • 10+11.04840
    • 30+9.87120
    库存:82
