EML1HM330F07OT
EML1HM330F07OT
    AISHI(艾华集团)
    插件,D8xL7mm
    直插铝电解电容 插件,D8xL7mm 33µF ±20% Ф8.00 x 7.00mm 50V 75mA 5000Hrs@105℃
EML1HM330F07OT 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS ML series Long life with 5mm to 9mm height. ML 105 C 1808 Endurance:+105°C 3,000~5,000 hours RoHS Compliant SPECIFICATIONS Items Characteristics Category Temperature Range -40~+105°C Rated Voltage Range 6.3~50 V dc Capacitance Tolerance ±20%(M) Leakage Current I≤0.01CV or 3μA, whichever is greater. Where, I:Max.leakage current (μA),C:Nominal capacitance (μF),V: Rated voltage (V) (at 20°C,120Hz) Rated Voltage(V dc ) Dissipation Factor (tanδ) 6.3 10 16 25 35 0.40 0.35 0.30 0.25 0.20 tanδ (max.) (at 20°C after 2 minutes) 50 0.20 When nominal capacitance exceeds 1,000μF, add 0.02 to the value above for each 1,000μF increase. (at 20°C,120Hz) Low Temperature Characteristics (Max. Impedance Ratio) Rated Voltage(V dc ) 6.3 10 16 25 35 50 Z(-25°C)/Z(+20°C) 6 4 4 3 2 2 Z(-40°C)/Z(+20°C) 12 10 8 6 4 4 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20°C after DC voltage plus the rated ripple current is applied for a specified period of time at 105°C. Endurance Capacitance Change ≤±30% of the initial value D.F. (tanδ) ≤300% of the initial specified value Leakage Current ≤The initial specified value Size L=5mm L≥7mm Load life (hours) 3,000 5,000 The following specifications shall be satisfied when the capacitors are restored to 20°C after exposing them for 1,000 hours at 105°C without voltage applied. Shelf Life Capacitance Change ≤±30% of the initial value D.F. (tanδ) ≤300% of the initial specified value Leakage Current ≤200% of the initial specified value DIMENSIONS[mm] Sleeve(Black) Ød ØD' F±0.5 L' 4min. 15min. ( Ø 4~ Ø 10) 6.3 ØD 4 5 Ød 0.45 0.45 0.45 F 1.5 2.0 2.5 ØD' L' 8 6.3×5 6.3×7 10×9 8×5 8×7 8×9 0.5 0.45 0.5 0.5 0.6 2.5 3.5 3.5 3.5 5.0 Ø D+0.5max. L+2max. E ML 1H M 220 F05 O- - Radial Type PART NUMBERING SYSTEM T Sleeve Code: “C” for PVC, “T” for PET Terminal code Size code Capacitance code Capacitance tolerance code Voltage code Series code Category code RATED RIPPLE CURRENT MULTIPLIERS Frequency correction factor for ripple current Freq.(Hz) Cap.(μF) 60(50) 120 500 1k 10k≤ Cap.
EML1HM330F07OT 价格&库存
很抱歉,暂时无法提供与“EML1HM330F07OT”相匹配的价格&库存,您可以联系我们找货
EML1HM330F07OT
    • 10+0.27962
    • 100+0.22108
    • 600+0.19181
    库存:594
