ENB1HM101G13OT
ENB1HM101G13OT
    AISHI(艾华集团)
    插件,D10xL13mm
    直插铝电解电容 插件,D10xL13mm 100µF ±20% Ф10.00 x 13.00mm 50V 520mA 4000Hrs@130℃
ENB1HM101G13OT 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS NB series High reliability, withstand high temperature Endurance:+130°C 2,000~5,000 hours Upgrade NB 130 C 1808 RoHS Compliant SPECIFICATIONS Items Characteristics Category Temperature Range -40~+130°C Rated Voltage Range 10~120 V dc Capacitance Tolerance ±20%(M) Leakage Current I≤0.01CV or 3μA, whichever is greater. Where, I:Max.leakage current (μA),C:Nominal capacitance (μF),V: Rated voltage (V) (at 20°C,120Hz) 10 16 25 35 50 63 80 100 120 0.24 0.20 0.18 0.16 0.14 0.12 0.12 0.10 0.12 Rated Voltage(V dc ) 10 16 25 35 50 63 80 100 120 Z(-25°C)/Z(+20°C) 3 Z(-40°C)/Z(+20°C) 6 Rated Voltage(V dc ) (at 20°C after 2 minutes) Dissipation Factor (tanδ) tanδ (max.) Low Temperature Characteristics (Max. Impedance Ratio) 4 2 3 3 6 (at 20°C,120Hz) (at 120Hz) The specifications listed below shall be met when the capacitors are restored to 20°C after DC voltage plus rated ripple current is applied for a specified period of time at 130°C. Endurance Capacitance Change ≤±30% of the initial value D.F. (tanδ) ≤300% of the initial specified value Leakage Current ≤The initial specified value Dia.(mm) Load life (hours) ØD=5&6.3 2,000 ØD=8 3,000 ØD=10 4,000 ØD≥12.5 5,000 The following specifications shall be satisfied when the capacitors are restored to 20°C after leaving them under no load at 130°C for 1,000 hours. Shelf Life Capacitance Change ≤±30% of the initial value D.F. (tanδ) ≤300% of the initial specified value Leakage Current ≤500% of the initial specified value DIMENSIONS[mm] Sleeve(Black) Ød ØD' F±0.5 L' 4min. 15min. ( Ø 5~ Ø 18) ØD 5 6.3 Ød F ØD' L' 0.5 0.5 2.0 2.5 8 0.5 0.6 3.5 10 12.5 16 18 0.6 0.6 5.0 5.0 0.8 7.5 0.8 7.5 Ø D+0.5max. L+2max. E NB 1H M 3R3 F11 O- - Radial Type PART NUMBERING SYSTEM T Sleeve Code: “C” for PVC, “T” for PET Terminal code Size code Capacitance code Capacitance tolerance code Voltage code Series code Category code RATED RIPPLE CURRENT MULTIPLIERS Frequency correction factor for ripple current Freq.(Hz) Cap.(μF) 50/60 120 1k 10k 100k Cap.
ENB1HM101G13OT
1. 物料型号:AiSHi NB系列,包括不同的额定电压和电容值。 2. 器件简介:这些是小型铝电解电容器,符合RoHS标准,具有高可靠性,能承受高温,适用于+130°C下2,000至5,000小时的耐久性测试。 3. 引脚分配:文档中没有提供具体的引脚分配图,但通常电解电容器有正负两个引脚。 4. 参数特性: - 工作温度范围:-40°C 至 +130°C - 额定电压范围:10Vdc 至 120Vdc - 电容公差:+20%(M类,20°C,120Hz) - 漏电流:0.01CV或3pA,取较大者 - 损耗因子(tano):随额定电压不同而变化,最大值为0.24 - 低温特性:在-25°C和-40°C时的阻抗比 - 耐久性:在130°C下,电容器在特定时间后恢复至20°C时的性能 - 货架寿命:在130°C下1,000小时的无负载存储寿命 5. 功能详解:文档提供了电容器在不同工作条件下的性能参数,包括损耗因子、低温特性、耐久性和货架寿命。 6. 应用信息:适用于需要高可靠性和高温耐受性的应用场合。 7. 封装信息:提供了不同尺寸的电容器的外径(OD)、长度(L)和封装类型。
ENB1HM101G13OT 价格&库存
很抱歉,暂时无法提供与“ENB1HM101G13OT”相匹配的价格&库存,您可以联系我们找货
ENB1HM101G13OT
  • 10+0.48390
  • 100+0.38180
  • 250+0.33190
  • 1000+0.29410
  • 5000+0.26390
  • 10000+0.24900
库存:9002
ENB1HM101G13OT
    • 10+0.48395
    • 100+0.38394
    • 250+0.33394
    • 1000+0.29636
    • 5000+0.26633
    • 10000+0.25132
    库存:11589
    ENB1HM101G13OT
    • 10+0.31200
    • 50+0.28860
    • 200+0.26910
    • 600+0.24960
    • 1500+0.23400
    • 3000+0.22425
    库存:232
