ERJ1HM101F12OT
ERJ1HM101F12OT
    AISHI(艾华集团)
    插件,D8xL12mm
    直插铝电解电容 插件,D8xL12mm 100µF ±20% Ф8.00 x 12.00mm 50V 120mΩ 950mA 10000Hrs@105℃
ERJ1HM101F12OT 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS RJ series Miniaturized Low impedance, high ripple current,long life Endurance: +105°C 8,000 ~12,000 hours 1808 RoHS Compliant SPECIFICATIONS Items Characteristics Category Temperature Range -40~+105°C Rated Voltage Range 10~120 V dc Capacitance Tolerance ±20%(M) Leakage Current I≤0.01CV or 3μA, whichever is greater. Where, I:Max.leakage current (μA),C:Nominal capacitance (μF),V: Rated voltage (V) (at 20°C,120Hz) Rated Voltage(V dc ) Dissipation Factor (tanδ) 10 16 25 35 50 63 0.19 0.16 0.14 0.12 0.10 0.09 tanδ (max.) 80 100 120 0.09 0.08 0.12 (at 20°C after 2 minutes) When nominal capacitance exceeds 1,000μF, add 0.02 to the value above for each 1,000μF increase. Low Temperature Characteristics (Max. Impedance Ratio) Rated Voltage(V dc ) 10 16 25 35 50 63 80 100 (at 20°C,120Hz) 120 Z(-25°C)/Z(+20°C) 2 2 3 Z(-40°C)/Z(+20°C) 4 3 6 (at 120Hz) The specifications listed below shall be met when the capacitors are restored to 20°C after DC voltage plus rated ripple current is applied for a specified period of time at 105 °C,the peak voltage shall not exceed the rated voltage. Endurance Capacitance Change ≤±25% of the initial value (10V:≤±30%) D.F. (tanδ) ≤200% of the initial specified value Leakage Current ≤The initial specified value Case Dia.(mm) ØD≤6.3 ØD=8&10 ØD≥12.5 Load life (hours) 10~120V 8,000 10,000 12,000 The following specifications shall be satisfied when the capacitors are restored to 20°C after leaving them under no load at 105°C for 1,000 hours. Shelf Life Capacitance Change ≤±25% of the initial value (10V:≤±30%) D.F. (tanδ) ≤200% of the initial specified value Leakage Current ≤200% of the initial specified value DIMENSIONS[mm] Ød ØD' F±0.5 L' 4min. 15min. ( Ø 5~ Ø 18) ØD 5 6.3 Ød 0.5 0.5 F ØD' L' 2.0 2.5 8 0.5 0.6 3.5 10 12.5 16 18 0.6 0.6 0.8 0.8 5.0 5.0 7.5 7.5 Ø D+0.5max. L+2max. Radial Type Sleeve(Violet) PART NUMBERING SYSTEM E RJ 1H M 221 G16 O- - T Sleeve Code: “C” for PVC, “T” for PET Terminal code Size code Capacitance code Capacitance tolerance code Voltage code Series code Category code RATED RIPPLE CURRENT MULTIPLIERS Frequency correction factor for ripple current Freq.(Hz) Cap.(μF) 120 1k 10k 100k≤ Cap.
ERJ1HM101F12OT 价格&库存
很抱歉,暂时无法提供与“ERJ1HM101F12OT”相匹配的价格&库存,您可以联系我们找货
ERJ1HM101F12OT
    ERJ1HM101F12OT
    库存:387
    ERJ1HM101F12OT
      • 1+0.32460
      库存:3
      ERJ1HM101F12OT
      • 10+0.36150
      • 100+0.29320
      • 500+0.23810
      • 1000+0.19550
      • 5000+0.17660
      • 10000+0.16720
      库存:2976
      ERJ1HM101F12OT
      • 10+0.23380
      • 50+0.21700
      • 200+0.20300
      • 600+0.18900
      • 1500+0.17780
      • 3000+0.17080
      库存:356
      ERJ1HM101F12OT
        • 10+0.36256
        • 100+0.29430
        • 500+0.23976
        • 1000+0.21417
        • 5000+0.19365
        • 10000+0.18339
        库存:32326
