MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
RJ series
Miniaturized
Low impedance, high ripple current,long life
Endurance: +105°C 8,000 ~12,000 hours
1808
RoHS Compliant
SPECIFICATIONS
Items
Characteristics
Category Temperature Range
-40~+105°C
Rated Voltage Range
10~120 V dc
Capacitance Tolerance
±20%(M)
Leakage Current
I≤0.01CV or 3μA, whichever is greater.
Where, I:Max.leakage current (μA),C:Nominal capacitance (μF),V: Rated voltage (V)
(at 20°C,120Hz)
Rated Voltage(V dc )
Dissipation Factor (tanδ)
10
16
25
35
50
63
0.19 0.16 0.14 0.12 0.10 0.09
tanδ (max.)
80
100
120
0.09
0.08
0.12
(at 20°C after 2 minutes)
When nominal capacitance exceeds 1,000μF, add 0.02 to the value above for each 1,000μF increase.
Low Temperature
Characteristics
(Max. Impedance Ratio)
10
16
25
35
50
63
80
100
(at 20°C,120Hz)
120
Z(-25°C)/Z(+20°C)
2
2
3
Z(-40°C)/Z(+20°C)
4
3
6
(at 120Hz)
The specifications listed below shall be met when the capacitors are restored to 20°C after DC voltage plus rated ripple
current is applied for a specified period of time at 105 °C,the peak voltage shall not exceed the rated voltage.
Endurance
Capacitance Change
≤±25% of the initial value (10V:≤±30%)
D.F. (tanδ)
≤200% of the initial specified value
Leakage Current
≤The initial specified value
Case Dia.(mm)
ØD≤6.3
ØD=8&10
ØD≥12.5
Load life (hours)
10~120V
8,000
10,000
12,000
The following specifications shall be satisfied when the capacitors are restored to 20°C after leaving them under no load
at 105°C for 1,000 hours.
Shelf Life
Capacitance Change
D.F. (tanδ)
Leakage Current
DIMENSIONS[mm]
Ød
ØD'
F±0.5
L'
4min.
15min.
( Ø 5~ Ø 18)
ØD
5
6.3
Ød
0.5
0.5
F
ØD'
L'
2.0
2.5
8
0.5
0.6
3.5
10
12.5
16
18
0.6
0.6
0.8
0.8
5.0
5.0
7.5
7.5
Ø D+0.5max.
L+2max.
Radial Type
Sleeve(Violet)
PART NUMBERING SYSTEM
E
RJ 1H
M 221 G16 O- -
T
Sleeve Code: “C” for PVC, “T” for PET
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
RATED RIPPLE CURRENT MULTIPLIERS
Frequency correction factor for ripple current
Freq.(Hz)
Cap.(μF)
120
1k
10k
100k≤
Cap.
很抱歉,暂时无法提供与“ERJ1HM221G16OT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.61380
- 50+0.40920
- 250+0.37070
- 国内价格
- 5+0.43684
- 20+0.39664
- 100+0.35644
- 500+0.31624
- 1000+0.29748
- 2000+0.28408
- 国内价格
- 5+0.62381
- 50+0.50674
- 250+0.41343
- 500+0.36947
- 2500+0.33437
- 5000+0.31688
- 国内价格
- 5+0.62280
- 50+0.50280
- 250+0.40950
- 500+0.36590
- 2500+0.33120
- 5000+0.31380
