PTVS12VU1UPAZ
PTVS12VU1UPAZ
    NEXPERIA(安世)
    DFN2020-3
    ESD抑制器/TVS二极管 VRWM=12V VBR(Min)=13.3V VC=19.9V@IPP=15.1A DFN2020-3
PTVS12VU1UPAZ 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia N3 PTVSxU1UPA series HU SO 300 W Transient Voltage Suppressor Rev. 1 — 6 March 2014 Product data sheet 1. Product profile 1.1 General description 300 W unidirectional Transient Voltage Suppressor (TVS) in a DFN2020-3 (SOT1061) leadless medium power Surface-Mounted Device (SMD) plastic package, designed for transient overvoltage protection. 1.2 Features and benefits  Rated peak pulse power: PPPM = 300 W  Reverse current: IRM = 1 nA  Very low package height: 0.65 mm  Reverse standoff voltage range: VRWM = 7.5 V to 26 V  AEC-Q101 qualified 1.3 Applications  Power supply protection  Industrial application  Power management 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter PPPM rated peak pulse power VRWM reverse standoff voltage Conditions [1][2] [1] In accordance with IEC 61643-321 (10/1000 s current waveform). [2] Measured from pin 1 and 2 to pin 3. Min Typ Max Unit - - 300 W 7.5 - 26 V PTVSxU1UPA series NXP Semiconductors 300 W Transient Voltage Suppressor 2. Pinning information Table 2. Pinning Pin Description 1 and 2 anode 3 cathode Simplified outline Graphic symbol 3 3 1, 2 006aab838 1 2 Transparent top view 3. Ordering information Table 3. Ordering information Type number[1] Package Name PTVSxU1UPA series [1] Description Version DFN2020-3 plastic thermal enhanced ultra thin small outline package; no leads; 3 terminals; body 2  2  0.65 mm SOT1061 The series consists of 6 types with reverse standoff voltages from 7.5 V to 26 V. 4. Marking Table 4. PTVSXU1UPA_SER Product data sheet Marking codes Type number Marking code PTVS7V5U1UPA CX PTVS10VU1UPA CY PTVS12VU1UPA CZ PTVS15VU1UPA D1 PTVS18VU1UPA D2 PTVS26VU1UPA D3 All information provided in this document is subject to legal disclaimers. Rev. 1 — 6 March 2014 © NXP B.V. 2014. All rights reserved. 2 of 12 PTVSxU1UPA series NXP Semiconductors 300 W Transient Voltage Suppressor 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol PPPM Parameter Conditions [1][3] rated peak pulse power [2][3] Min Max Unit - 300 W W - 3000 IPPM rated peak pulse current - see Table 8 Tj junction temperature - 150 C Tamb ambient temperature 55 +150 C Tstg storage temperature 65 +150 C [1] In accordance with IEC 61643-321 (10/1000 s current waveform). [2] In accordance with IEC 61000-4-5 and IEC 61643-321 (8/20 s current waveform). [3] Measured from pin 1 and 2 to pin 3. Table 6. ESD maximum ratings Tamb = 25 C unless otherwise specified. Symbol VESD PTVSXU1UPA_SER Product data sheet Parameter Conditions electrostatic discharge voltage Min Max Unit IEC 61000-4-2 (contact discharge) [1][2] - 30 kV IEC 61000-4-2 (air discharge) [1][2] - 30 kV [1] Device stressed with ten non-repetitive ElectroStatic Discharge (ESD) pulses. [2] Measured from pin 1 and 2 to pin 3. All information provided in this document is subject to legal disclaimers. Rev. 1 — 6 March 2014 © NXP B.V. 2014. All rights reserved. 3 of 12 PTVSxU1UPA series NXP Semiconductors 300 W Transient Voltage Suppressor 006aab319 150 001aaa630 120 IPP (%) 100 % IPP; 8 µs IPP (%) 100 % IPP; 10 μs 100 80 e-t 50 % IPP; 20 µs 50 % IPP; 1000 μs 50 40 0 0 1.0 2.0 3.0 0 4.0 0 tp (ms) Fig 1. 10 20 30 40 tp (ms) 10/1000 s pulse waveform according to IEC 61643-321 Fig 2. 8/20 s pulse waveform according to IEC 61000-4-5 and IEC 61643-321 001aaa631 IPP 100 % 90 % 10 % tr = 0.6 ns to 1 ns t 30 ns 60 ns Fig 3. ESD pulse waveform according to IEC 61000-4-2 PTVSXU1UPA_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 6 March 2014 © NXP B.V. 2014. All rights reserved. 4 of 12 PTVSxU1UPA series NXP Semiconductors 300 W Transient Voltage Suppressor 6. Thermal characteristics Table 7. Symbol Rth(j-a) Rth(j-sp) Thermal characteristics Parameter Conditions thermal resistance from junction to ambient in free air thermal resistance from junction to solder point Min Typ Max Unit [1] - - 240 K/W [2] - - 120 K/W [3] - - 65 K/W [4] - - 10 K/W [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2. [3] Device mounted on a ceramic PCB, Al2O3, standard footprint. [4] Soldering point of cathode tab. 7. Characteristics Table 8. Characteristics per type; PTVS7V5U1UPA to PTVS26VU1UPA Tj = 25 C unless otherwise specified. Type number Reverse standoff voltage Breakdown voltage VBR (V) IR = 1 mA VRWM (V) Max Reverse Rated leakage current peak pulse IRM (nA) at VRWM current IPPM (A) Rated peak pulse current IPPM (A) [1][3] [2][3] Clamping voltage VCL (V); at IPPM (A)[1][3] Clamping voltage VCL (V); at IPPM (A)[2][3] Min Typ Max Typ Max Max Max Max Max PTVS7V5U1UPA 7.5 8.33 8.77 9.21 200 1000 178 23.3 19.7 12.9 PTVS10VU1UPA 10 11.10 11.70 12.30 2 50 148 17.6 23.0 17.0 PTVS12VU1UPA 12 13.30 14.00 14.70 1 50 131 15.1 25.2 19.9 PTVS15VU1UPA 15 16.70 17.60 18.50 1 50 111 12.3 28.8 24.4 PTVS18VU1UPA 18 20.00 21.00 22.10 1 50 97 10.3 32.0 29.2 PTVS26VU1UPA 26 28.90 30.40 31.90 1 50 69 7.0 43.5 42.1 [1] In accordance with IEC 61000-4-5 and IEC 61643-321 (8/20 s current waveform). [2] In accordance with IEC 61643-321 (10/1000 s current waveform). [3] Measured from pin 1 and 2 to pin 3. PTVSXU1UPA_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 6 March 2014 © NXP B.V. 2014. All rights reserved. 5 of 12 PTVSxU1UPA series NXP Semiconductors 300 W Transient Voltage Suppressor I 006aab321 1.2 PPPM PPPM(25°C) 0.8 −VCL −VBR −VRWM V −IRM −IR 0.4 − + P-N −IPP 0 0 50 100 150 200 −IPPM Tj (°C) Fig 4. Relative variation of rated peak pulse power as a function of junction temperature; typical values Fig 5. 006aab324 V-I characteristics for a unidirectional TVS protection diode aaa-011962 104 PPPM (W) 103 102 10 10 102 103 104 tp (µs) Tamb = 25 °C Fig 6. Rated peak pulse power as a function of a pulse duration; typical values PTVSXU1UPA_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 6 March 2014 © NXP B.V. 2014. All rights reserved. 6 of 12 PTVSxU1UPA series NXP Semiconductors 300 W Transient Voltage Suppressor 8. Application information line to be protected (positive signal polarity) line to be protected (negative signal polarity) ESD protection diode ESD protection diode GND GND unidirectional protection of one line Fig 7. aaa-004394 Application diagram 9. Test information 9.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 10. Package outline 1.3 0.65 max 0.35 0.25 1 1.05 0.95 2 0.45 0.35 1.1 0.9 0.3 0.2 2.1 1.9 3 1.6 1.4 Dimensions in mm Fig 8. PTVSXU1UPA_SER Product data sheet 2.1 1.9 09-11-12 Package outline DFN2020-3 (SOT1061) All information provided in this document is subject to legal disclaimers. Rev. 1 — 6 March 2014 © NXP B.V. 2014. All rights reserved. 7 of 12 PTVSxU1UPA series NXP Semiconductors 300 W Transient Voltage Suppressor 11. Soldering 2.1 1.3 0.5 (2×) 0.4 (2×) 0.5 (2×) 0.6 (2×) 1.05 2.3 0.6 0.55 0.25 1.1 0.25 1.2 0.25 0.4 0.5 1.6 1.7 Dimensions in mm solder paste = solder lands solder resist Fig 9. PTVSXU1UPA_SER Product data sheet occupied area sot1061_fr Reflow soldering footprint DFN2020-3 (SOT1061) All information provided in this document is subject to legal disclaimers. Rev. 1 — 6 March 2014 © NXP B.V. 2014. All rights reserved. 8 of 12 PTVSxU1UPA series NXP Semiconductors 300 W Transient Voltage Suppressor 12. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes PTVSXU1UPA_SER v.1 20140306 Product data sheet - - PTVSXU1UPA_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 6 March 2014 © NXP B.V. 2014. All rights reserved. 9 of 12 PTVSxU1UPA series NXP Semiconductors 300 W Transient Voltage Suppressor 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. NXP Semiconductors takes no responsibility for the content in this document if provided by an information source outside of NXP Semiconductors. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. PTVSXU1UPA_SER Product data sheet Suitability for use in automotive applications — This NXP Semiconductors product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors and its suppliers accept no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 6 March 2014 © NXP B.V. 2014. All rights reserved. 10 of 12 PTVSxU1UPA series NXP Semiconductors 300 W Transient Voltage Suppressor No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 13.4 Trademarks Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com PTVSXU1UPA_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 6 March 2014 © NXP B.V. 2014. All rights reserved. 11 of 12 NXP Semiconductors PTVSxU1UPA series 300 W Transient Voltage Suppressor 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 10 11 12 13 13.1 13.2 13.3 13.4 14 15 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Application information. . . . . . . . . . . . . . . . . . . 7 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 7 Quality information . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9 Legal information. . . . . . . . . . . . . . . . . . . . . . . 10 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2014. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 6 March 2014 Document identifier: PTVSXU1UPA_SER
PTVS12VU1UPAZ 价格&库存
很抱歉,暂时无法提供与“PTVS12VU1UPAZ”相匹配的价格&库存,您可以联系我们找货
PTVS12VU1UPAZ
  • 1+2.919291+0.34892
  • 10+1.9333810+0.23108
  • 100+1.30589100+0.15609
  • 500+1.02238500+0.12220
  • 1000+0.953641000+0.11398
库存:2865
PTVS12VU1UPAZ
  • 1+2.877731+0.34395
  • 10+1.9022110+0.22736
  • 100+1.28542100+0.15364
  • 500+1.00634500+0.12028
  • 1000+0.938681000+0.11220
库存:2865
PTVS12VU1UPAZ
    • 3000+0.843273000+0.10079
    • 6000+0.829346000+0.09913
    • 12000+0.8163412000+0.09757
    • 15000+0.8116915000+0.09702
    • 45000+0.7847645000+0.09380
    库存:3000
    PTVS12VU1UPAZ
    • 3000+0.803383000+0.09602
    • 6000+0.800216000+0.09565
    库存:2865
