MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
RK series
Endurance: +105°C 2,000 hours
Especially designed for charger
Upgrade
Miniaturized,high voltage
RK 105 C
1808
RoHS Compliant
SPECIFICATIONS
Items
Characteristics
Category Temperature Range
-40~+105°C(400 V dc )
Rated Voltage Range
400~550 V dc
Capacitance Tolerance
±20%(M)
(at 20°C,120Hz)
400~450 V dc
Leakage Current
-25~+105°C(450~550 V dc )
500~550 V dc
I≤0.02CV+10μA
I≤0.03CV+10μA
Where, I:Max.leakage current (μA),C:Nominal capacitance (μF),
V: Rated voltage (V)
(at 20°C after 2 minutes)
Rated Voltage(V dc )
400
450
500
550
tanδ (max.)
0.15
0.20
0.24
0.24
400
450
500
550
Z(-25°C)/Z(+20°C)
3
5
6
15
Z(-40°C)/Z(+20°C)
6
Dissipation Factor (tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
(at 20°C,120Hz)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20°C after DC voltage plus the rated
ripple current is applied for 2,000 hours at 105°C.
Rated voltage(V dc )
Endurance
400~500 V dc
550 V dc
Capacitance Change
≤±20% of the initial value
≤±30% of the initial value
D.F. (tanδ)
≤200% of the initial specified value
≤300% of the initial specified value
Leakage Current
≤The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20°C after exposing them for 1,000 hours
at 105°C without voltage applied.
Shelf Life
Capacitance Change
D.F. (tanδ)
Leakage Current
DIMENSIONS[mm]
Ød
ØD'
F±0.5
L'
4min.
15min.
( Ø 6.3~ Ø 18)
ØD
6.3
Ød
F
ØD'
L'
0.5
2.5
8
0.5
0.6
3.5
10
12.5
16
18
0.6
0.6
5.0
5.0
0.8
7.5
0.8
7.5
Ø D+0.5max.
L+2max.
Radial Type
Sleeve(Black)
PART NUMBERING SYSTEM
E
RK 2G
M 3R3 F12 O- -
T
Sleeve Code: “C” for PVC, “T” for PET
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
RATED RIPPLE CURRENT MULTIPLIERS
Frequency correction factor for ripple current
Freq.(Hz)
WV(Vdc)
400~550
120
1k
10k
100k
0.50
0.80
0.90
1.00
The endurance of capacitors is shortened with internal heating produced by ripple
current at the rate of halving the lifetime with every 5°C rise. When long life
performance is required in actual use, the rms ripple current has to be reduced.
154
RK series
STANDARD RATINGS
WV
(V dc )
Cap
(µF)
2.2
3.3
4.7
6.8
8.2
400(2G)
10
15
22
33
47
56
68
2.2
3.3
450(2W)
4.7
6.8
8.2
tanδ
Rated ripple
current
(mArms/105°C,
100kHz)
Part Number
tanδ
Rated ripple
current
(mArms/105°C,
100kHz)
Part Number
6.3×9
0.15
64
ERK2GM2R2E09OT
8×7
0.15
66
ERK2GM2R2F07OT
8×16
0.20
220
ERK2WM100F16OT
10×12
0.20
230
6.3×11
0.15
74
ERK2WM100G12OT
ERK2GM3R3E11OT
10×14
0.20
250
8×9
0.15
ERK2WM100G14OT
76
ERK2GM3R3F09OT
10×16
0.20
230
8×11
ERK2WM150G16OT
0.15
80
ERK2GM3R3F11OT
12.5×16
0.20
250
ERK2WM150W16OT
6.3×11
0.15
90
ERK2GM4R7E11OT
12.5×20
0.20
295
ERK2WM220W20OT
8×9
0.15
94
ERK2GM4R7F09OT
16×16
0.20
320
ERK2WM220L16OT
8×11
0.15
98
ERK2GM4R7F11OT
12.5×22
0.20
495
ERK2WM330W22OT
8×11
0.15
126
ERK2GM6R8F11OT
16×16
0.20
495
ERK2WM330L16OT
10×9
0.15
132
ERK2GM6R8G09OT
16×20
0.20
550
ERK2WM330L20OT
8×11
0.15
145
ERK2GM8R2F11OT
16×20
0.20
640
ERK2WM470L20OT
10×9
0.15
150
ERK2GM8R2G09OT
16×25
0.20
710
ERK2WM470L25OT
10×10
0.15
158
ERK2GM8R2G10OT
18×20
0.20
870
ERK2WM680M20OT
8×12
0.15
165
ERK2GM100F12OT
18×25
0.20
970
ERK2WM680M25OT
8×14
0.15
180
ERK2GM100F14OT
8×12
0.24
85
ERK2HM3R3F12OT
10×9
0.15
172
ERK2GM100G09OT
8×12
0.24
110
ERK2HM4R7F12OT
10×12
0.15
210
ERK2GM150G12OT
10×9
0.24
110
ERK2HM4R7G09OT
10×14
0.15
230
ERK2GM150G14OT
5.6
10×9
0.24
130
ERK2HM5R6G09OT
10×16
0.15
250
ERK2GM220G16OT
6.8
10×10
0.24
150
ERK2HM6R8G10OT
12.5×16
0.15
300
ERK2GM220W16OT
8.2
10×12
0.24
190
ERK2HM8R2G12OT
12.5×16
0.15
520
ERK2GM330W16OT
10
10×16
0.24
225
ERK2HM100G16OT
12.5×22
0.15
650
ERK2GM470W22OT
12
10×16
0.24
230
ERK2HM120G16OT
16×16
0.15
670
ERK2GM470L16OT
15
10×18
0.24
250
ERK2HM150G18OT
13×25
0.15
780
ERK2GM560K25OT
22
12.5×20
0.24
280
ERK2HM220W20OT
16×23
0.15
880
ERK2GM680L23OT
3.3
8×12
0.24
85
ERK2JM3R3F12OT
18×18
0.15
880
ERK2GM680M18OT
10×10
0.24
110
ERK2JM4R7G10OT
18×20
0.15
920
ERK2GM680M20OT
10×12
0.24
120
ERK2JM4R7G12OT
6.3×11
0.20
65
ERK2WM2R2E11OT
5.6
10×12
0.24
130
ERK2JM5R6G12OT
8×9
0.20
72
ERK2WM2R2F09OT
6.8
10×12
0.24
150
ERK2JM6R8G12OT
8×9
0.20
82
ERK2WM3R3F09OT
8.2
10×14
0.24
190
ERK2JM8R2G14OT
8×11
0.20
100
ERK2WM4R7F11OT
10
10×16
0.24
225
ERK2JM100G16OT
10×9
0.20
110
ERK2WM4R7G09OT
12
10×20
0.24
235
ERK2JM120G20OT
10×9
0.20
130
ERK2WM6R8G09OT
15
12.5×20
0.24
250
ERK2JM150W20OT
10×10
0.20
148
ERK2WM6R8G10OT
22
12.5×25
0.24
280
ERK2JM220W25OT
10×10
0.20
190
ERK2WM8R2G10OT
10×12
0.20
210
ERK2WM8R2G12OT
Size
ΦDxL(mm)
WV
(V dc )
Cap
(µF)
10
15
22
450(2W)
33
47
68
3.3
4.7
500(2H)
4.7
550(2J)
Size
ΦDxL(mm)
155
很抱歉,暂时无法提供与“ERK2GM100F12OT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.43670
- 50+0.25630
- 500+0.23100
- 国内价格
- 10+0.46090
- 100+0.38030
- 500+0.30440
- 1000+0.27100
- 5000+0.25930
- 10000+0.25150
- 国内价格
- 10+0.27696
- 50+0.25524
- 200+0.23713
- 600+0.21903
- 1500+0.20455
- 3000+0.19550
- 国内价格
- 10+0.46170
- 100+0.38319
- 500+0.30672
- 1000+0.27335
- 5000+0.26180
- 10000+0.25391
