MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
RR series
High frequency,low impedance,high reliability
RR 105 C
1808
Endurance: +105°C 2,000 hours
Suitable for switching power, UPS, power sources,etc.
RoHS Compliant
SPECIFICATIONS
Items
Characteristics
Category Temperature Range
-40~+105°C
Rated Voltage Range
6.3~50 V dc
Capacitance Tolerance
±20%(M)
Leakage Current
I≤0.01CV or 3μA, whichever is greater.
Where, I:Max.leakage current (μA),C:Nominal capacitance (μF),V: Rated voltage (V)
(at 20°C,120Hz)
Rated Voltage(V dc )
Dissipation Factor (tanδ)
6.3
10
16
25
35
0.22 0.18 0.14 0.12 0.10
tanδ (max.)
(at 20°C after 2 minutes)
50
0.08
When nominal capacitance exceeds 1,000μF, add 0.02 to the value above for each 1,000μF increase.
Low Temperature
Characteristics
(Max. Impedance Ratio)
6.3
10
16
25
35
(at 20°C,120Hz)
50
2
Z(-25°C)/Z(+20°C)
(at 120Hz)
The specifications listed below shall be met when the capacitors are restored to 20°C after DC voltage plus rated ripple
current is applied for 2,000 hours at 105 °C.
Endurance
Capacitance Change
≤±20% of the initial value (6.3,10V:≤±30%)
D.F. (tanδ)
≤200% of the initial specified value
Leakage Current
≤The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20°C after leaving them under no load
at 105°C for 1,000 hours.
Shelf Life
Capacitance Change
D.F. (tanδ)
Leakage Current
DIMENSIONS[mm]
Sleeve(Violet)
ØD
Ød
Ød
ØD'
F±0.5
L'
4min.
15min.
( Ø 5~ Ø 16)
F
ØD'
L'
5
0.45
6.3
0.5
2.0
0.5
2.5
8
0.5
0.6
3.5
10
12.5
16
0.6
0.6
0.8
5.0
5.0
7.5
Ø D+0.5max.
L+2max.
PART NUMBERING SYSTEM
E
RR 1H
M 220 D11 O- -
T
Sleeve Code: “C” for PVC, “T” for PET
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
RATED RIPPLE CURRENT MULTIPLIERS
Frequency correction factor for ripple current
Freq.(Hz)
Cap.(μF)
120
1k
10k
100k
Cap.
很抱歉,暂时无法提供与“ERR1HM102L25OT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.12102
- 50+1.65834
- 200+1.46006
- 500+1.21274
