PESD5V0U1UA;
PESD5V0U1UB; PESD5V0U1UL
Ultra low capacitance unidirectional ESD protection diodes
Rev. 01 — 30 October 2008
Product data sheet
1. Product profile
1.1 General description
Ultra low capacitance unidirectional ElectroStatic Discharge (ESD) protection diodes in
small Surface-Mounted Device (SMD) plastic packages designed to protect one signal
line from the damage caused by ESD and other transients.
Table 1.
Product overview
Type number
Package
Package configuration
Nexperia
JEITA
PESD5V0U1UA
SOD323
SC-76
very small
PESD5V0U1UB
SOD523
SC-79
ultra small and flat lead
PESD5V0U1UL
SOD882
leadless ultra small
1.2 Features
n Unidirectional ESD protection of one line n ESD protection up to 9 kV
n Ultra low diode capacitance: Cd = 2 pF n IEC 61000-4-2; level 4 (ESD)
n Very low leakage current: IRM = 1 nA
n AEC-Q101 qualified
1.3 Applications
n
n
n
n
n
USB interfaces
10/100/1000 Mbit/s Ethernet
FireWire
High-speed data lines
Subscriber Identity Module (SIM) card
protection
n
n
n
n
n
Cellular handsets and accessories
Portable electronics
Communication systems
Computers and peripherals
Audio and video equipment
1.4 Quick reference data
Table 2.
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
VRWM
reverse standoff voltage
Conditions
Min
Typ
Max
Unit
5
V
PESD5V0U1UA/UB/UL
Nexperia
Table 2.
Quick reference data …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Cd
diode capacitance
f = 1 MHz
VR = 0 V
2
2.6
pF
VR = 5 V
1.7
2.3
pF
2. Pinning information
Table 3.
Pinning
Pin
Description
Simplified outline
Graphic symbol
PESD5V0U1UA; PESD5V0U1UB
1
cathode
2
anode
[1]
1
2
1
2
006aaa152
001aab540
PESD5V0U1UL
1
cathode
2
anode
[1]
1
2
1
2
006aaa152
Transparent
top view
[1]
The marking bar indicates the cathode.
3. Ordering information
Table 4.
Type number
Package
Name
Description
Version
PESD5V0U1UA
SC-76
plastic surface-mounted package; 2 leads
SOD323
PESD5V0U1UB
SC-79
SOD523
PESD5V0U1UL
leadless ultra small plastic package; 2 terminals;
body 1.0 × 0.6 × 0.5 mm
SOD882
4. Marking
Table 5.
Marking codes
Type number
Marking code
PESD5V0U1UA
C7
PESD5V0U1UB
LA
PESD5V0U1UL
L1
PESD5V0U1UA_UB_UL
Product data sheet
© Nexperia B.V. 2008. All rights reserved.
2 of 12
PESD5V0U1UA/UB/UL
Nexperia
5. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Tj
Conditions
Min
Max
Unit
junction temperature
150
°C
Tamb
ambient temperature
−55
+150
°C
Tstg
storage temperature
−65
+150
°C
Table 7.
ESD maximum ratings
Symbol
Parameter
Conditions
VESD
electrostatic discharge voltage
IEC 61000-4-2
(contact discharge)
[1]
MIL-STD-883 (human
body model)
[1]
Min
Max
Unit
9
kV
10
kV
Device stressed with ten non-repetitive ESD pulses.
Table 8.
ESD standards compliance
Standard
Conditions
> 8 kV (contact)
MIL-STD-883; class 3 (human body model)
> 4 kV
001aaa631
IPP
100 %
90 %
10 %
tr = 0.7 ns to 1 ns
t
30 ns
60 ns
Fig 1.
ESD pulse waveform according to IEC 61000-4-2
PESD5V0U1UA_UB_UL
Product data sheet
3 of 12
PESD5V0U1UA/UB/UL
Nexperia
6. Characteristics
Table 9.
Characteristics
Symbol
Parameter
Conditions
VRWM
IRM
reverse leakage current
VBR
breakdown voltage
Cd
diode capacitance
f = 1 MHz
differential resistance
rdif
Min
Typ
Max
Unit
5
V
VRWM = 5 V
1
100
nA
IR = 5 mA
5.8
6.8
8.8
V
VR = 0 V
2
2.6
pF
VR = 5 V
1.7
2.3
pF
100
Ω
IR = 1 mA
I
006aab348
2.0
Cd
(pF)
1.9
−VCL −VBR −VRWM
V
−IRM
−IR
1.8
1.7
P-N
−IPP
1.6
2
3
4
5
VR (V)
006aaa407
f = 1 MHz; Tamb = 25 °C
Fig 2.
Diode capacitance as a function of reverse
voltage; typical values
Fig 3.
V-I characteristics for a unidirectional
PESD5V0U1UA_UB_UL
Product data sheet
4 of 12
PESD5V0U1UA/UB/UL
Nexperia
ESD TESTER
450 Ω
RZ
RG 223/U
50 Ω coax
4 GHz DIGITAL
OSCILLOSCOPE
10×
ATTENUATOR
50 Ω
CZ
IEC 61000-4-2 network
CZ = 150 pF; RZ = 330 Ω
DUT
(DEVICE
UNDER
TEST)
vertical scale = 2 kV/div
horizontal scale = 15 ns/div
vertical scale = 20 V/div
horizontal scale = 100 ns/div
GND
GND
unclamped +8 kV ESD pulse waveform
(IEC 61000-4-2 network)
(IEC 61000-4-2 network) pin 1 to 2
GND
GND
unclamped −8 kV ESD pulse waveform
Fig 4.
006aab350
ESD clamping test setup and waveforms
PESD5V0U1UA_UB_UL
Product data sheet
5 of 12
PESD5V0U1UA/UB/UL
Nexperia
7. Application information
The PESD5V0U1Ux series is designed for the protection of one unidirectional data or
signal line from the damage caused by ESD. The devices may be used on lines where the
signal polarities are either positive or negative with respect to ground.
line to be protected
(positive signal polarity)
(negative signal polarity)
DUT
DUT
GND
GND
unidirectional protection of one line
006aab251
Fig 5.
Application diagram
Circuit board layout and protection device placement
Circuit board layout is critical for the suppression of ESD and Electrical Fast
Transient (EFT). The following guidelines are recommended:
1. Place the device as close to the input terminal or connector as possible.
2. The path length between the device and the protected line should be minimized.
3. Keep parallel signal paths to a minimum.
4. Avoid running protected conductors in parallel with unprotected conductors.
5. Minimize all Printed-Circuit Board (PCB) conductive loops including power and
ground loops.
6. Minimize the length of the transient return path to ground.
7. Avoid using shared transient return paths to a common ground point.
8. Ground planes should be used whenever possible. For multilayer PCBs, use ground
vias.
8. Test information
8.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
PESD5V0U1UA_UB_UL
Product data sheet
6 of 12
PESD5V0U1UA/UB/UL
Nexperia
9. Package outline
1.35
1.15
0.45
0.15
1
2.7
2.3
0.85
0.75
1.1
0.8
1
1.65 1.25
1.55 1.15
1.8
1.6
2
2
0.40
0.25
0.25
0.10
0.34
0.26
Dimensions in mm
Fig 6.
03-12-17
Package outline
PESD5V0U1UA (SOD323/SC-76)
0.17
0.11
Dimensions in mm
Fig 7.
02-12-13
Package outline
PESD5V0U1UB (SOD523/SC-79)
0.50
0.46
0.62
0.55
2
0.30
0.22
0.65
0.30
0.22
1.02
0.95
1
0.55
0.47
cathode marking on top side
Dimensions in mm
Fig 8.
0.65
0.58
03-04-17
Package outline PESD5V0U1UL (SOD882)
10. Packing information
Table 10. Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number
Package
PESD5V0U1UA
SOD323
PESD5V0U1UB
SOD523
PESD5V0U1UL
[1]
SOD882
Description
4 mm pitch, 8 mm tape and reel
3000
8000
10000
-115
2 mm pitch, 8 mm tape and reel
-115
-315
For further information and the availability of packing methods, see http://www.nexperia.com.
PESD5V0U1UA_UB_UL
Product data sheet
Packing quantity
7 of 12
PESD5V0U1UA/UB/UL
Nexperia
11. Soldering
3.05
2.1
solder lands
solder resist
0.5 (2×)
1.65 0.95
0.6 (2×)
solder paste
occupied area
2.2
Dimensions in mm
0.5
(2×)
0.6
(2×)
Fig 9.
sod323_fr
Reflow soldering footprint PESD5V0U1UA (SOD323/SC-76)
5
2.9
1.5 (2×)
solder lands
solder resist
occupied area
2.75
1.2
(2×)
Dimensions in mm
preferred transport
direction during soldering
sod323_fw
Fig 10. Wave soldering footprint PESD5V0U1UA (SOD323/SC-76)
PESD5V0U1UA_UB_UL
Product data sheet
8 of 12
PESD5V0U1UA/UB/UL
Nexperia
2.15
1.1
solder lands
solder resist
0.5 0.6
(2×) (2×)
1.2
solder paste
occupied area
Dimensions in mm
0.7
(2×)
0.8
(2×)
sod523_fr
Reflow soldering is the only recommended soldering method.
Fig 11. Reflow soldering footprint PESD5V0U1UB (SOD523/SC-79)
1.3
0.7
R0.05 (8×)
solder lands
0.6 0.7
(2×) (2×)
0.9
solder resist
solder paste
occupied area
0.3
(2×)
Dimensions in mm
0.4
(2×)
sod882_fr
Fig 12. Reflow soldering footprint PESD5V0U1UL (SOD882)
PESD5V0U1UA_UB_UL
Product data sheet
9 of 12
PESD5V0U1UA/UB/UL
Nexperia
12. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PESD5V0U1UA_UB_UL
20081030
Product data sheet
PESD5V0U1UA_UB_UL
Product data sheet
10 of 12
PESD5V0U1UA/UB/UL
Nexperia
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
13.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or warranties,
expressed or implied, as to the accuracy or completeness of such information
Right to make changes — Nexperia reserves the right to make changes to
information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in medical, military, aircraft, space or life
support equipment, nor in applications where failure or malfunction of an
Nexperia product can reasonably be expected to result in personal injury,
death or severe property or environmental damage. Nexperia accepts no
liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold subject to the
general terms and conditions of commercial sale, as published at http://
www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of any
inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
ESD protection devices — These products are only intended for protection
against ElectroStatic Discharge (ESD) pulses and are not intended for any
other usage including, without limitation, voltage regulation applications.
Nexperia accepts no liability for use in such applications and therefore such
use is at the customer’s own risk.
13.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
PESD5V0U1UA_UB_UL
Product data sheet
11 of 12
PESD5V0U1UA/UB/UL
Nexperia
14. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
8.1
9
10
11
12
13
13.1
13.2
13.3
13.4
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description. . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data. . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Application information. . . . . . . . . . . . . . . . . . . 6
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 6
Quality information . . . . . . . . . . . . . . . . . . . . . . 6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7
Packing information. . . . . . . . . . . . . . . . . . . . . . 7
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10
Legal information. . . . . . . . . . . . . . . . . . . . . . . 11
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
14
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to:
salesaddresses@nexperia.com
Date of release: 30 October 2008
Document identifier: PESD5V0U1UA_UB_UL
很抱歉,暂时无法提供与“PESD5V0U1UL,315”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10000+0.5071710000+0.06574
- 20000+0.4622120000+0.05991
- 30000+0.4393030000+0.05694
- 50000+0.4135550000+0.05361
- 70000+0.3982970000+0.05163
- 100000+0.38348100000+0.04971
