ERZ1CM562M25OT
ERZ1CM562M25OT
    AISHI(艾华集团)
    插件,D18xL25mm
    直插铝电解电容 插件,D18xL25mm 5.6mF ±20% Ф18.00 x 25.00mm 16V 12mΩ 3.65A 10000Hrs@105℃
ERZ1CM562M25OT 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS RZ series Miniaturized,long life, low impedance High ripple current, high reliability Endurance: +105°C 6,000~10,000 hours 1808 RoHS Compliant SPECIFICATIONS Items Characteristics Category Temperature Range -40~+105°C Rated Voltage Range 6.3~50 V dc Capacitance Tolerance ±20%(M) Leakage Current I≤0.01CV or 3μA, whichever is greater. Where, I:Max.leakage current (μA),C:Nominal capacitance (μF),V: Rated voltage (V) (at 20°C,120Hz) Rated Voltage(V dc ) Dissipation Factor (tanδ) 6.3 10 16 25 35 0.22 0.19 0.16 0.14 0.12 tanδ (max.) (at 20°C after 2 minutes) 50 0.10 When nominal capacitance exceeds 1,000μF, add 0.02 to the value above for each 1,000μF increase. Low Temperature Characteristics (Max. Impedance Ratio) Rated Voltage(V dc ) 6.3 10 6 4 2 Z(-25°C)/Z(+20°C) Z(-40°C)/Z(+20°C) (at 20°C,120Hz) 16~50 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20°C after DC voltage plus the rated ripple current is applied for a specified period of time at 105 °C. Endurance Capacitance Change ≤±25% of the initial value (6.3,10V:≤±30%) D.F. (tanδ) ≤200% of the initial specified value Leakage Current ≤The initial specified value Case Dia.(mm) ØD≤6.3 ØD=8 ØD≥10 Load life (hours) 6,000 8,000 10,000 The following specifications shall be satisfied when the capacitors are restored to 20°C after exposing them for 1,000 hours at 105°C without voltage applied. Shelf Life Capacitance Change ≤±25% of the initial value (6.3,10V:≤±30%) D.F. (tanδ) ≤200% of the initial specified value Leakage Current ≤200% of the initial specified value DIMENSIONS[mm] Sleeve(Vioelt) Ød ØD' F±0.5 L' 4min. 15min. ( Ø 5~ Ø 18) ØD 5 6.3 Ød 0.5 0.5 F ØD' L' 2.0 2.5 8 0.5 0.6 3.5 10 12.5 16 18 0.6 0.6 0.8 0.8 5.0 5.0 7.5 7.5 Ø D+0.5max. L+2max. E RZ 1H M 220 D12 O- - Radial Type PART NUMBERING SYSTEM T Sleeve Code: “C” for PVC, “T” for PET Terminal code Size code Capacitance code Capacitance tolerance code Voltage code Series code Category code RATED RIPPLE CURRENT MULTIPLIERS Frequency correction factor for ripple current Freq.(Hz) Cap.(μF) 120 1k 10k 100k Cap.
ERZ1CM562M25OT 价格&库存
很抱歉,暂时无法提供与“ERZ1CM562M25OT”相匹配的价格&库存,您可以联系我们找货
ERZ1CM562M25OT
    • 1+3.92040
    • 10+3.14280
    • 30+2.74320
    • 250+2.35440
    • 500+2.12760
    库存:549
